'99 a6 steering wheel on '96 a4
fARQUARE Jun 21, 2011
  1. fARQUARE
    fARQUARE Member
    228
    hello, just a quick question, will this physically fit?
    if so will i have any headaches with airbag wiring or is it plug and play?
    thanks in advance.
  2. B5NUT
    B5NUT Well-Known Member VCDS Map User quattro Audi A6 Audi Avant Owner Group S-line owners group
    3,757
    659
    Early a4 steering wheels were held on with a nut, but i'm sure ( could be wrong) later models 98/99 and onwards were held on with a splined head bolt.
    However not sure when the a6 model changed to splined head bolt
  3. fARQUARE
    fARQUARE Member
    228
    Different thread on the column I guess then...
    Sent from my U20i using Tapatalk
  4. adamss24
    adamss24 Well-Known Member
    4,584
    406
    Totally different but you can get adaptors from vw dealer to fit the later steering wheel to the early steering column.
  5. B5NUT
    3,757
    659
    You may be able to change the column, they must go for peanuts on eBay as don't think I've heard of one breaking.
  6. fARQUARE
    fARQUARE Member
    228
    What about airbag wiring, plug and play or pain in the rump?
  7. B5NUT
    3,757
    659
    Good point. They are both single stage so you are ok in that respect, the plugs my be different but they can be changed, with little cost
  8. fARQUARE
    fARQUARE Member
    228
    any idea on the part number of if you need to change anything else?
  9. fARQUARE
    fARQUARE Member
    228
    Looks like part number 8a0 419 787b
    I'll keep scratching about.....
  10. Oranoco
    Oranoco Well-Known Member
    3,954
    402
    Interested in this adapter as I have a mint splined A4 sport wheel sitting on the shelf by my front door but my A4 has the old nutted fitment.
  11. Jason.s
    Jason.s Active Member
    2,879
    348
    Well on ETKA its just listed as a spacer sleeve and costs £22.09 + vat
  12. Oranoco
    3,954
    402
    Can't find an image of it for the life of me :(
  13. Oranoco
    3,954
    402
    Anybody progressed further with this?
  14. aragorn
    18,380
    831
  15. aragorn
    18,380
    831
    Whats not very clear though is if that allows the early A4 wheel to fit later A4's, or the early A4 wheel to fit even earlier cars...
  16. Oranoco
    3,954
    402
  17. fARQUARE
    fARQUARE Member
    228
    Im still looking for an aswer to this too. Ii need to take my wheel off this weekend to replace a faulty wiper stalk so i'll have a poke about while i've got it off to see if this adaptor would do the job or not
  18. fARQUARE
    fARQUARE Member
    228
    well, i've had the wheel off a few times this week. Here are a few shots of the wheel and the new wheel which doesnt seem to fit....
    not sure if the adaptor mentioned above would be any good as the airbag wires look different.
  19. B5NUT
    3,757
    659
    It's a single stage airbag so it should be ok, but you will have to change the plug on the wiring harness.Wiyh taking any airbag from another/later model of car there is always a Risk it won't fire in an accident.
