'97 A3 Centre Dash Question
portsA318T Nov 15, 2006
  1. portsA318T
    portsA318T 'The boat can leave now, tell the crew'
    51
    Just a quick question. Are the heater controls meant to light up with the rest of the dash? Mine don't and was wondering is it just a single bulb replacment? and how to remove the trim. Is it just pull the knobs off and a couple of screws? (No innuendo intended). Thanks
  2. steve1975l
    steve1975l Member
    595
    I assume you don't have AC. From memory you have to take quite a lot apart ie radio out to get to the screws to get the heater controls out. Then take the heater controls module apart to get to a small bulb.
  3. garratt83
    garratt83 Member
    244
    Hi don't know if its the same on the facelift as yours, but the controls are supposed to light-up.
    The bulb is behind the middle control (fan level), get a pair of tweezers and put some cotton wool on the end, then wriggle the bulb out. They are about £2 from halfaulds.
    Hope this helps
    by the way I had to change mine and removed everything only to find I could just do that.
  4. portsA318T
    51
    Thanks for the info. I'll have to take a look when i get some time.
