!.9 tdi just takes off
adidasandy Apr 26, 2006
  1. adidasandy
    adidasandy Member
    271
    Hi all, just bought a 1995 audi 80 tdi. I love it except the only fault it has is - driving at 30 mph in 4th no problems, but when dropping down into 3rd and planting it I take my foot off the gas and it just keeps on going(redlines), you have to turn off the engine and then start again. It's great untill you boot it and then it won't stop. A couple of diesel fitters say it maybe the electronic diesel pump but some others say turbo. Any ideas on the problem or has this happened to other people.
    Very scary when it happens. /ubbthreads/images/graemlins/mad.gif
  2. Rev-head
    Rev-head Active Member
    2,987
    Diesel pump is what i would go for ..sure there must be relay for this?
  3. adidasandy
    adidasandy Member
    271
    Yeah I thought so, I have the model no for it and there are some on Ebay but 1 or2 digits at the end different. Will I have to get the exact model no or are there several ones I could use.
    0-460-404-992
    028 130 109L
  4. Rev-head
    2,987
    Have you tried phoning www.vagparts.com to give you idea of the part?
    when looking at the pump there seems to be alot of solenoids that could be sticking as well so worth thinking about
    Partlist: narrow / wide
    injection pump / 1.9ltr. / diesel eng.:
    / AFN,AFF,AHU,
    / AHH
    (1) 028130115M
    injection pump / AFF,AHU
    (1) 028130115MX
    (1) 028130115A
    injection pump / AFN
    (1) 028130115AX
    (1) 038130107J
    injection pump / AHH
    (1) 038130107JX
    2 028130147B
    console / AFN,AFF,AHU
    (2) 028130147M
    console / AHH
    - 028199351
    support
    3 N 10226002
    hexagon socket head bolt with collar / M8X26
    5 N 01224110
    spring washer / B8X15X0,8
    6 068130173B
    arm
    7 068130174
    arm
    8 028130135F
    fuel cut-off solenoid
    9 068130139
    seal for fuel cut-off solenoid / BOSCH
    10 N 0102695
    hexagonal head bolt / M8X38
    12 111129720
    washer / 8,4
    13 068130199
    bush
    14 N 01033512
    hexagonal head bolt / M8X35X15
    16 N 90477301
    washer / B8,4X24X3
    17 068130197
    tapered nut
    19 N 0111849
    hexagon nut, self-locking / M8
    20 028130111A
    toothed belt pulley / 44Z
    21 N 0127101
    woodruff key / 4X6,5X15,72
    22 N 0122333
    spring washer / B14X28X1,6
    23 N 0110212
    hexagonal nut / M14X1,5
    25 068130787A
    seal
    26 028130795G
    union / AFF,AHU
    (26) 028130795J
    union / AFN
    (27) 028130717
    seal
    28 028130149B
    support
    29 028906040C
    temperature sensor
    30 028906283G
    solenoid valve / AFF,AHU
    (30) 028906283K
    solenoid valve / AFN
    31 028130684
    round seal
    32 046130684A
    round seal
    33 028130231
    sealing plug
    34 N 0138075
    seal / A8X11,5
    35 028130122B
    air supply valve
    36 028109244
    relay roller
    37 N 0147172
    allen key head bolt / M8X40
    /ubbthreads/images/graemlins/beerchug.gif
  5. adidasandy
    adidasandy Member
    271
    Thats spot on mate, I'll look into it now. /ubbthreads/images/graemlins/beerchug.gif
  6. Rev-head
    2,987
    Just had another look there is three different pumps that i see that fit your spec do you know which one it is?
  7. adidasandy
    adidasandy Member
    271
    just the model numbers that I have
    0460404992 or
    028130109L
