8V VCDS Mods
i found a post DJAlix made here
How To: 8v Mods and Jobs
so i want to post my autoscan so you can tell me for sure if i have the acoustic chirp mode
Code:
01-Engine -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
5F-Information Electr. -- Status: OK 0000
Address 01: Engine (J623-CMBA) Labels: 04E-907-309-V1.clb
Part No SW: 04E 906 016 J HW: 04E 907 309 A
Component: R4 1.4l TFS H08 9017
Revision: WAH08---
Coding: 02190012230401082000
Shop #: WSC 42158 001 1048576
ASAM Dataset: EV_ECM14TSF01104E906016J 002014
ROD: N/A
VCID: 295E658B48EA85762A-807C
No ASAM data for: "EV_ECM14TSF01104E906016J" (AU37)
No fault code found.
Readiness: 0000 0000
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 907 379 AC HW: 5Q0 907 379 D
Component: ESC H75 0437
Revision: 00000000 Serial number:
Coding: 10F16AA220212A730177060001CC290856045480608094F20039000805
Shop #: WSC 53983 000 1048576
ASAM Dataset: EV_Brake1UDCSontiMK100IPB 008020
ROD: N/A
VCID: 7DF661DBECE2C9D636-8028
No ASAM data for: "EV_Brake1UDCSontiMK100IPB" (AU37)
Address 08: Auto HVAC (E87) Labels: 8V0-820-043.clb
Part No SW: 8V0 820 043 HW: 8V0 820 043
Component: AC Automat H11 0031
Revision: 20018000 Serial number: 00000000020119
Coding: 00000004000000011000000000001100
Shop #: WSC 06314 790 00021
ASAM Dataset: EV_AirCondiFrontVaAU37X 008016
ROD: EV_AirCondiFrontVaAU37X.rod
VCID: 6FEA4B93B68EAB46B4-803A
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 Q
Component: BCM MQBAB H H14 0137
Serial number: 00011230100245
Coding: 04040A42C20120DD03044004000C07A80000000000000000000000000000
ASAM Dataset: EV_BCMCONTI 013000
ROD: EV_BCMBOSCH_AU37.rod
VCID: 0008182F9B10A43E5D-8054
Slave 1:
Subsystem 1 - Part No SW: 8V1 955 119 A HW: 8V1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS370 120915 041 0580
Serial number: 121008214510
Coding: 0A47F7
Slave 3:
Subsystem 2 - Part No SW: 8V0 941 531 J HW: 8V0 941 531 J
Component: E1 - LDS MQB H05 0032
Serial number: 30 07 2012 00000090
Subsystem 3 - Part No SW: 8U0 955 559 HW: 8U0 955 559
Component: G355_FeuchteS H07 0002
Serial number: 20190123
Address 15: Airbags (J234) Labels: 5Q0-959-655.clb
Part No SW: 5Q0 959 655 L HW: 5Q0 959 655 L
Component: AirbagVW20 009 0349
Serial number: 003GER00D5B3
Coding: 98CCC0000C0000005C5400CA004800000065
ASAM Dataset: EV_AirbaVW20SMVEW37X 002126
ROD: N/A
VCID: 499EC50BE8AAA576CA-801C
Subsystem 1 - Part No SW: ----------- HW: 480 001 610 12
Component: SideSensor_Df 001 0887
Serial number: 3576700000063A540C0P
Coding: 2D2D2D
Subsystem 2 - Part No SW: ----------- HW: 480 001 210 12
Component: SideSensor_Pf 001 0887
Serial number: 3586700000028261FB0V
Coding: 2D2D2D
Subsystem 3 - Part No SW: ----------- HW: 480 401 610 12
Component: SideSensor_Dr 001 6149
Serial number: 3516502A50D19C32E1BH
Coding: 2D2D2D
Subsystem 4 - Part No SW: ----------- HW: 480 401 610 12
Component: SideSensor_Pr 001 6149
Serial number: 3526502B50D535457195
Coding: 2D2D2D
Subsystem 5 - Part No SW: ----------- HW: 480 401 610 12
Component: FrontSensor_D 001 6149
Serial number: 3556502A30D19C306186
Coding: 2D2D2D
Subsystem 6 - Part No SW: ----------- HW: 480 400 210 12
Component: PedP_Sensor_D 001 6149
Serial number: 2286502A70D19C3200D9
Coding: 2D2D2D
Subsystem 7 - Part No SW: ----------- HW: 480 400 210 12
Component: PedP_Sensor_P 001 6149
Serial number: 2296502C50D0E4710365
Coding: 2D2D2D
Subsystem 8 - Part No SW: ----------- HW: 480 400 210 12
Component: PedP_Sensor_C 001 6149
Serial number: 2306502C50D0E473A2CE
Coding: 2D2D2D
No ASAM data for: "EV_AirbaVW20SMVEW37X" (AU37)
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 8V0 953 521 HW: 5Q0 953 549 A
Component: Lenks. Modul 007 0070
Revision: -------- Serial number: 201012000300YF
Coding: 8408
ASAM Dataset: EV_SMLSKLOMQB 009001
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 77FA73F3CEDEE3866C-8022
Address 17: Instruments (J285) Labels: 5G0-920-XXX-17.clb
Part No SW: 8V0 920 870 HW: 8V0 920 870
Component: KOMBI H23 0490
Coding: 078401002A8000080100A800000000
ASAM Dataset: EV_DashBoardVDDMQBAB 008026
ROD: EV_DashBoardVDDMQBAB_AU37.rod
VCID: 78F870CFC3C0ECFE65-802C
Address 19: CAN Gateway (J533) Labels: 5Q0-907-530-V1.clb
Part No SW: 5Q0 907 530 J HW: 5Q0 907 530 F
Component: GW MQB High 122 1126
Revision: -------- Serial number: 0000137862
Coding: 030100F42B0864005B000248080B00000001000000000000000000000000
ASAM Dataset: EV_GatewElar 008010
ROD: N/A
VCID: 3878B0CF83402CFEA5-806C
Subsystem 2 - Part No SW: 8U0 951 528 A HW: 8U0 951 528 A
Component: E221 - MFL H02 0014
Serial number: 18 10 2012 D0127766
Subsystem 3 - Part No SW: 5Q0 915 181 C HW: 5Q0 915 181 C
Component: J367-BDMHella H03 8042
Serial number: 1171498401
No ASAM data for: "EV_GatewElar" (AU37)
Address 42: Door Elect, Driver (J386) Labels: 5QX-959-X93-42.clb
Part No SW: 5Q0 959 393 A HW: 5Q0 959 393 A
Component: TSG FS H12 0006
Serial number: 29091200010283
Coding: 00100E204100040100001002
ASAM Dataset: EV_DCUDriveSdieEWMINKLO 006003
ROD: N/A
VCID: 3D76A1DBAC6209D676-8068
No ASAM data for: "EV_DCUDriveSdieEWMINKLO" (AU37)
Address 44: Steering Assist (J500) Labels: 5Q0-909-144.clb
Part No SW: 5Q0 909 144 L HW: 5Q0 909 144 L
Component: EPS_MQB_ZFLS 119 1021
Coding: 81
ASAM Dataset: EV_SteerAssisMQB 008022
ROD: EV_SteerAssisMQB.rod
Address 52: Door Elect, Pass. (J687) Labels: None
Part No SW: 5T0 959 397 A HW: 5T0 959 397
Component: TVG BFS % H17 0056
Serial number: 15081200510031
Coding: 001506204100040105001002
Shop #: WSC 06314 790 00181
ASAM Dataset: ES_CDUPavseSide@WMINKLJ 056003
ROD: N/A
VCID: 4480D43FCF88781E39-8010
No ASAM data for: "ES_CDUPavseSide@WMINKLJ" (AU37)
Address 55: Headlight Range (J431) Labels: 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR-ECU 005 0070
Revision: -------- Serial number: --------------
Coding: 0198000001000000
ASAM Dataset: EV_HeadlRegulVWLWRMQB 001110
ROD: EV_HeadlRegulVWLWRMQB_AU37.rod
VCID: 75E679FBD4D291967E-8020
Address 5F: Information Electr. (J794) Labels: None
Part No SW: 8V0 035 840 A HW: 8V0 035 840
Component: MU-S--ER 039 0370
Serial number: A3E02410120067
Coding: 01730000FF00000011110001000A00002F0001040100010002
ASAM Dataset: EV_MUSdt4CPASE 002018
ROD: N/A
VCID: 336287E39A26CFA690-8066
Subsystem 1 - Part No SW: 8V0 919 603 A HW: 8V0 919 603 A
Component: DU Std H47 0013
Serial number: AUZ8Z9CG2007NM
Subsystem 2 - Part No SW: 8V0 919 614 B HW: 8V0 919 614 B
Component: ControlUnit_B H33 0037
Serial number: C1000001091200010055
No ASAM data for: "EV_MUSdt4CPASE" (AU37)
End-------------------------(Elapsed Time: 03:19)--------------------------
any advices would be appreciated! (for acoustic beam or anything else)
thnx
This is done by activating Engine Data, but I could only activate this via VCP. This is an example display on my own car, non S:
Sorry, I don't know what VCP is but are you saying that it is possible on the FL S3?
If so, would it give any meaningful figures?
Anyone figure out how to mirror a phone to the mmi ?
So far I did :
G Force meter
Unlocked Video in motion
Disabled Soundaktor
Auto door locks
Recirculation memory
So far I did :
G Force meter
Disabled Soundaktor
Auto door locks
PFL cars can use the AMI port as an external video source. If you had a PFL reverse camera then you could also use the TV / Aux input on the control module. For facelift cars I am not sure as yet. It looks like you will need a 3rd party interface which will daisy chain between the MMI and the cars cabling as AMI is no longer an option and the new reversing camera does not have a TV / Aux input. 3rd party interface example (PFL):
https://www.aliexpress.com/store/pr...o-Interface-For-AUDI/1892051_32466346414.html
VCP = VAG Can Professional
Without going in to too much detail VCP is a more advanced VCDS application. It is possible on a FL S3 but I am not sure if it would give meaningful data as it would depend on the hardware within your car.
Thanks for the reply! That is as far as i have gotten as well. I found a few videos on youtube and they showed how to do it with PFL,Pretty easy to do with the AMI setup. I'm hoping someone can figure it out for the FL S3!
Someone cracked it with the Golf R and someone found this screen on the S3 with adaption - but we still don't know if it will help or not
Golf R mirroring
http://forums.vwvortex.com/showthrea...!!)&p=99593345
S3
Golf R mirroring
S3
I have seen the settings within the link but not played with them as yet. Will give it a go when I next have some free time but only have Apple devices to test with.
That would be great if you could get it working :)
I have a iPhone as well for my main device. I ended up buying a $70 android phone strictly for the VIM and obdeleven which I use with wifi only,But works great so far.
I like ODBeleven... gives me a lot of business... i.e. broken cars to fix :) Be careful when using it.
Reactions: TMB, karb0n and BodegaBay
Really? I hope it's from people doing coding and making mistakes. I'm new to Audi so I only do the Apps which is one click and it does the coding for me
Thanks for the heads up tho !
Lol. Funny, I have both Micro-can and ODB11 but have always stayed to the tried and true VCDS.
Problem is that VCDS is becoming more limited now that VAG technology is moving forward :( I have not said very much recently, due to being very busy, but most of the FL modifications I have been finding are more or less impossible to do via VCDS :( One such example would be Visual Parking display with only rear sensors = impossible with VCDS in FL cars.
I think it s combination of people thinking that all they need to do is use the click functions and things will work, like activating lane assist without even having the needed camera lol. Also a lack of meaningful detail and descriptions does not help. The fact that many of these apps include "volume to be replenished" for the Audi A3 proves to me that they are not testing before releasing things to the public. This is a VW only feature lol
Reactions: karb0n and BodegaBay
Oh ok,That makes sense then lol. Not sure if this is a new thing or not as I just used obdeleven for the first time this week. But most of the apps that show up after you scan don't work. when you click on them it says " Vehicle not supported "
So maybe they made it so you can only code things supported from the app to eliminate mistakes ? No idea to be honest lol
I only did the few things I listed above ( Gforce meter,Vim,auto door lock,disabled soundaktor,recirculation memory,seat belts off )
Oh ok,That makes sense then lol. Not sure if this is a new thing or not as I just used obdeleven for the first time this week. But many things show up after you scan,but when you click on them it says " Vehicle not supported "
Maybe the app is moving on then, never used it myself but really should get a device and the app I guess. Ha! If I added this to my tool suite that would make 7 devices, 17 cables and 5 dongles :(
Reactions: Rob2k68, Brasso and karb0n
That's a lot of stuff !!!! Lol
Might as well get one and add it to the arsenal. If you can't figure out how to mirror with all of that,I give up lol
Reactions: Rob2k68
Without going in to too much detail VCP is a more advanced VCDS application. It is possible on a FL S3 but I am not sure if it would give meaningful data as it would depend on the hardware within your car.[/QUOTE]
Thanks for your help. I guess the S3 wouldn't have the hardware so a bit pointless, really. I wonder what hardware the FL RS3 will have to give torque and power readouts?
Code:
Revision: WAH08---
ROD: N/A
ROD: N/A
Slave 1:
Coding: 0A47F7
Slave 3:
ROD: N/A
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 2D2D2D
Coding: 8408
ROD: N/A
ROD: N/A
Coding: 81
ROD: N/A
ROD: N/A
thnx
Unfortunately your car does not have an Audi factory alarm system, which would normally show up as a slave under 09 - cent elect:
Subsystem 4 - Part No SW: 8V0 951 177 HW: 5Q0 951 172
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY1323145BH
Subsystem 5 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Component: Sirene, DWA 004 0311
Serial number: 00000000000027931362
Subsystem 6 - Part No SW: 8V3 959 591 HW: 8V3 959 591
Component: J245 PS73.009 H02 0007
Serial number: WOO23970296
Coding: 901E00
To see if you have acoustic alarm setup to work from the horn I would need to see an adaptation map of 09.
@DJAlix
Have you seen this yet ? Someone figured out how to get the RS3 gauges displayed but they don't work. I have the coding for them,But maybe it needs some tweaking ?? Lol
@DJAlix
Yup, I did this a while ago :)
  • G Meter = Acceleration Display
  • Power / Torque = Engine Data Display
You need an "S" or "RS" car for these to work, but some cars do not have the needed hardware. The single / central dial display is another story :)
Engine data display on my car (see signature):
IMG 5885 squashed
Reactions: karb0n
Nice ! Can I do the engine data display without long coding ? Through the dashboard ?
Unfortunately Engine Data Display is not possible via Long Coding or Adaptation, its activated via firmware parameters.
So it's similar to activating the Gforce meter it sounds like. Which was easily done through the dashboard and checking off a box (as you know)
The picture I sent was from someone who tried Long coding it,From a TTRS.
Not had the time to take any screen caps of the long coding for 17 but I am pretty sure its not there, could be wrong tho but I know I had to activate it via firmware editing. G Meter is in both Long Coding and firmware tho.
Reactions: karb0n
Oh ok I appreciate it man ! I'll check later although I also doubt it's there. The guy who did the Long coding said it was a pita and I'm sure he would of did it the easy way if it was there lol
So far I did :
G Force meter
Disabled Soundaktor
Auto door locks
How are you able to watch TV/dvd through your screen?
The DVD deck in the glovebox ? I think it's standard on the S3
On the pre face lift it's not standard- part of the technology pack or often called High MMI.
Reactions: karb0n
Actually thats a good point. Video on PFL cars is as follows:
  • MMI Low / Standard = Via an AMI connected device only
  • MMI High / Techpack = Via an AMI connected device, via DVD or via SD card
Reactions: Rob2k68 and karb0n
Nice,I didn't know that - I'm jealous I don't have the ami from the pre facelift. Mirroring is so easy with that
Reactions: Rob2k68
Ah, so there's a DVD reader in the glovebox on Facelift models then?
Cars with Technology Pack 100%, but not so sure on non-Techpack cars. I think all cars get one now but I cannot find anything to confirm this. Someone with a FL car and SD card based navigation can confirm.
Possible VCDS adaptations suggest that there is a blue-ray option also but am guessing this is for cars with rear seat entertainment options i.e. A4, Q5 and Q7 MLBevo platforms, which share the MMI units.
Reactions: Rob2k68
I have specced Tech Pach Adv so I should have it then hopefully. Looking forward to that, didn't know that existed. Does it have to be enabled via VCDS?
Can play DVD video from the factory :) Region change and media ripping from DVD are vcds changes tho.
Reactions: HulkRS3
What resolution is it capable out outputting do you know? e.g If I play a 1080p HD DVD will it show me it in that quality? From Karbons screenshot it looks quite decent.
It's hard to tell in the picture,But it looks like 1080p HD when I'm watching it
Reactions: Rob2k68 and HulkRS3
21
4K
6K
