8V VCDS Mods
Silky-S3 Jan 5, 2014
  1. Itguy
    Itguy Well-Known Member
    1,130
    450
  2. DJAlix
    DJAlix VAG Car Coding Site Sponsor Team Ibis VAG Can Professional VCDS Map User Gold Supporter quattro ODIS (Offboard Diagnostic System)
    3,275
    2,677
    Made some changes to my new A3 Saloon, many thanks to Dannykn9 who is a top bloke :) We found the following:
    Security Access to modules
    If certain module is locked, you should go to "Security Access" and enter the proper code:
    For [09] Central Electronics the code is 31347 - WORKED
    For [03] ABS Brakes the code is 40168 - DID NOT WORK
    For [10] Parking aid the code is 71679 - WORKED
    [09] CENTRAL ELECTRONICS
    Acoustic (Alarm Beep) on Lock - WORKED WITHOUT ISSUE
    NOTE: Car makes one chirping sound, does not use the horn.
    [09] Central Electronics -> Adaptation ->
    Acknowledgement Signals - Akustische Rueckmeldung verriegeln (Lock acoustic feedback)
    CHANGE: Set each or one of them to Yes
    Acoustic (Alarm Beep) on Unlock - WORKED WITHOUT ISSUE
    NOTE: Car makes two chirping sounds, does not use the horn.
    Acknowledgement Signals - Akustische Rueckmeldung entriegen (Un-lock acoustic feedback)
    Acoustic Lock Menu (only for lock, enable/disable using DIS) - WORKED WITHOUT ISSUE - New Menu Option in the MMI.
    NOTE: From factory there was no option to enable/disable using DIS.
    Acknowledgement Signals -Menuesteuerung akustische Rueckmeldung
    CHANGE: Set Yes
    Visual confirmation of comfort closing - DID NOT WORK
    Acknowledgement Signals – Comfort closing ack??? (need to check it back)
    CHANGE: Set Yes
    [17] INSTRUMENT CLUSTER
    Enable Pointer Test / Staging / Staging - WORKED WITHOUT ISSUE
    [17] Instruments -> Coding -> Byte 1 ->
    CHANGE: Enable Bit 0
    Set Oil Temperature on all DIS Menus - WORKED WITHOUT ISSUE
    [17] Instruments -> Long Coding -> Byte 10
    CHANGE: Tick Bit 1. Display Oil Temperature
    Activation of the lap timer / lap counter in the FIS - WORKED WITHOUT ISSUE
    NOTE: Seems to work only with Color Information System
    [17] Instruments -> Long Coding -> Byte 1 ->
    CHANGE: Enable Bit 3
    Display the oil temperature gauge in the FIS lap timer - WORKED WITHOUT ISSUE
    Disable seatbelt warning - WORKED WITHOUT ISSUE
    [17] Instruments -> Long Coding -> Byte 0 ->
    CHANGE: Set bits 2-4 using combo box
    Change start screen - TESTED BUT NO ADDITIONAL SCREENS WERE AVAILABLE
    [17] Instruments -> Long Coding -> Byte 9 ->
    CHANGE: Set bits 0-2 using combo box (not documented)
    Indirect TPMS - PART TESTED. CHANGES TO 17 WORKED AND ICON / LAMP SWITCHED ON. UNABLE TO ACCESS 3 TO COMPLETE SETUP.
    [17] Instruments -> Long Coding -> Byte 4 ->
    CHANGE: Set bit 0
    [03] Brakes -> Long Coding -> Byte ??? ->
    CHANGE: Set bits ???, ???
    Visual representation of the parking aid (Audi Parking System APS) - WORKED WITHOUT ISSUE.
    [10] Parking aid 2 -> Long coding -> Byte 2 ->
    CHANGE: Set Bit 0 - visual representation parking sensors
    We also had a go at trying to set the dial illumination on permanently but could not find the setting as all the labels were in German. Has anyone worked this out yet?
    A3_Rider likes this.
  3. h5djr
    9,465
    1,772
    I have this set on my 8P Sportback but when I tried it, with the aide of an Audi Master Tech on my wife's A1 we found it could not be done. Mind you the ODB is different on the A1 and needs a full HEX-CON cable.
    I would be very interested if any can work this out for the 8V and I'm sure I will miss it when I change.
  4. pat15312
    pat15312 Well-Known Member
    530
    252
    Could really do with an AudiSport 8V VCDS wiki to consolidate these (massive hint to the forum mods)
  5. Silky-S3
    Silky-S3 Is loving his new 8V S3!
    1,407
    343
    A1 and A3 (both 8P and 8V) both have the same CAN based system. My friend with a A1 has set his dial illumination on at all times.
    PS Its HEX-CAN, not COM.
    Scott likes this.
  6. DJAlix
    3,275
    2,677
    Any chance you could find out which label your friend used Silky-S3? My German suks :(
  7. h5djr
    9,465
    1,772
    There are three interface cables available from Ross-Tech: Micro-CAN, HEX-COM+CAN and HEX-USB+CAN. I only have a Micro-CAN cable which I understand does not work with the A1. According the VCDS Compatibility Chart on their website it looks like my existing Micro-CAN cable will also work with the 8V.
    Because I have no HEX-COM+CAN or HEX-USB+CAN cable one of the Audi Master Techs I know offered to come round with his cable and we had a look but could not find a way to change the dial illumination to on at all times. Perhaps you could let me know what settings your friend had to change and if I decide to exchange my current cable for a HEX-COM+CAN or HEX-USB+CAN interface cable I will be able to change both my new A3 and my wife's A1.
  8. Silky-S3
    1,407
    343
    Will ask him :)
    h5djr likes this.
  9. Andy1608
    Andy1608 Active Member
    615
    204
    43
    Acoustic alarm beep doesn't work on mine. 13 plate TDI
  10. vimy
    vimy Member
    104
    Anyone inside the M25 that has access to VCDS that can kindly enable a few mods on my motor? (for some beer tokens of course) lol
  11. JohnM100
    JohnM100 #teamSepang VCDS Map User Gold Supporter
    957
    394
    Have a look in the technical forum / VCDS.
    There is a sticky with the VCDS user map. You can PM someone close to you.
    John.
  12. DJAlix
    3,275
    2,677
    Did you manage to ask your friend about his dial illumination Silky?
  13. Andy1608
    615
    204
    43
    My partners dad speak Germany, might get him to sit in the car with me and translate lol
  14. papaspeter
    papaspeter New Member
    10
    Hi !
    I wonder if someone has any info about VIM(video in motion) with VCDS?
    If you go to STG:5F , Funktion 10, there is at the end of list the "test VIM speed threshhold" and "test VIM PIN"
    IF WE FIND THE PIN NUMBER then we can put the "speed" at 200 km/h for e.g.
    Another matter-question is :if someone knows how to connect a Reverse Video Camera(custom).
    I found at the plug of the Navi the pins for video input BUT doesn't work(????) with a regular camera...
    Petros
  15. visionthing
    visionthing Active Member VCDS Map User
    210
    91
    Does anyone have the coding steps for activating rear parking sensor visual display? Had a good read of this thread and seen it mentioned but not the coding itself.
  16. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Its a tickbox in the Parking module coding, usually module #10 or #76.
    SW14NY'S likes this.
  17. MatthewC
    MatthewC Member
    31
    14
    I've seen this on other parts of this forum:
  18. veeeight
    veeeight I am a very pretty girl VCDS Map User Black Edition
    6,849
    4,764
    Posts #150 and #162
  19. visionthing
    210
    91
    Thank you, obviously didn't look hard enough :huh:
  20. Andy1608
    615
    204
    43
    I've some how managed to disable one touch on the passenger window. Not sure if I've accidently changed something . can someone check the long code for there's so I can see if I have. Thanks
  21. Andy1608
    615
    204
    43
    Sorted it now
  22. Andy1608
    615
    204
    43
    Got my acoustic alarm on too for locking and unlocking which was pleasant to listen too after having on the 8p which sounds too loud
  23. illingworth22
    illingworth22 Active Member TeamMisano Audi S3 Audi A3
    476
    152
    43
  24. DJAlix
    3,275
    2,677
    Yup :) and if your MMI is turned off the screen will pop up also while in reverse.
  25. s3 owner
    s3 owner New Member
    68
    can somebody with an S3 V with TPMS fitted post a scan of their car but specifically:-
    ABS module
    instrument
    TPMS module
    canbus
    many thanks
  26. squiretolley
    squiretolley Active Member
    458
    118
    43
    Does anyone know how to reset the service indicator? I've followed these instructions:
    17-instruments
    Adaptation - 10
    ESI - Resetting ESI
    New value - reset
    It accepts it but hasn't cleared the indicator.
  27. GermanJim
    GermanJim New Member
    Hi all,
    I also posted this in the VCDS tech forum but thought it might be good to do it here too.
    I've looked on the map and not found a user with VCDS for an 8v near Guildford where I live.
    I'm willing to travel circa 30 miles to find someone who can sort the following mods for me for suitable compensation:
    Optical enabling of rear parking sensors
    Steering fog lights
    Needle sweep
    Audible locking beep
    Rear DRL's
    I speak fluent German so can help you with any other coding queries you might have yourself.
    German Jim
    Car/Make/Model
    A3 Sportback 140 TFSI COD SLine S-tronic Daytona Grey, Comfort Pack, Cruise, Rear Sensors, Aluminium Roofrails, Privacy Glass
  28. Silky-S3
    1,407
    343
    cemerson likes this.
  29. cemerson
    cemerson Well-Known Member Team Cosmos quattro Audi A3 S-line owners group TDi DSG
    4,604
    1,190
    Not only that, the auction is for an 'evaluation' or some such nonsense, not the actual VIM mod!
  30. Cruiser89
    Cruiser89 Advanced In Car Tech Site Sponsor
    1,484
    222
    I think that's to cover his back. Basically means regardless if he can get it to work or not, you still have to pay.
    -- To be fair, the internet is littered with coding dongles for 8V VIM now. Quite pricey though!!
  31. cemerson
    4,604
    1,190
    It'll get cheaper at some point. I'm not even bothered about VIM really. Would be a nice to have if I ever do it.
  32. S3 TRS
    S3 TRS Active Member
    497
    226
    43
    Had it in my mk5 golf. Only used it once.
  33. squiretolley
    458
    118
    43
    I'm selling my VCDS cable, if anyone's interested. It's in the classified section.
  34. PilotAudi
    PilotAudi New Member
    2,352
    479
    £80 or 99P ?????
  35. s3 owner
    s3 owner New Member
    68
    anybody help plz ?
  36. amped2
    amped2 Active Member quattro Audi A3 Audi Cabriolet Owner Group TDi
    220
    122
    43
    Hi Veeeight,
    im picking up my A3 tomorrow and it only has rear parking sensors,does this mod allow the display screen to show the rear distances to objects.
    cheers
    Rich
  37. DJAlix
    3,275
    2,677
    Yup :)
  38. amped2
    220
    122
    43
    cheers,can see its going to be a busy day tomorrow
  39. veeeight
    6,849
    4,764
    Yup
    Although I think this is a double edged sword - it will be very nice to have the display on the MMI, but - in reality - even with PDC sensors and beeps, surely you should be actually looking in the door mirrors, or even out of the rear window whilst reversing?
    I say this with experience - backing out of a supermarket car space - the beeps/display didn't pick up a fast approaching car not willing to stop to let me out of the space, instead choosing to just drive past (as is their right of way) - and I only slamemd the brakes on when catching sight of them whizzing past in the rear view mirror. The beeps hadn't had time to beep/register/
    Sometimes, relying on the beeps or MMI display isn't the best thing to do, especially reversing out into the open! There is the danger that with the nice visual representation on the MMI, you could be looking at that instead of out of the windows!
    amped2 likes this.
  40. amped2
    220
    122
    43
    it was more for knowing how close I'm to the garage door lol would never reverse out without looking.i have it on my transit and it just looks funky having a pic instead of the beeping.
