8P2 front bumper conversion question
roston100 Apr 10, 2011
  1. roston100
    roston100 Member
    370
  2. AudiMafia
    AudiMafia Member
    403
    13
    only if you go for s3 conversion but then you can cut small sizes on bothsides, but if you go for S-line then you dont need to. there are few threads that explains this look at Sara's A3 conversion thread
  3. roston100
    roston100 Member
    370
  4. AudiMafia
    AudiMafia Member
    403
    13
  5. RU55SSO
    RU55SSO Member
    792
    24
    I converted to sline and never modified the bar at all
  6. Ash B
    Ash B Well-Known Member
    5,831
    84
    As said your only suppose to change the bar if you do the S3 conversion. If your doing the s-line conversion you dont need to change it :)
    Get some photo up once you done it
  7. Ads
    Ads License to drive
    8,230
    608
    Ahhh see, i'm all confused again!
    This is what I thought:
    8P1 --> 8P2 standard/sport = no need for new bar or to modify existing bar.
    8P1 --> 8P2 s-line/S3 = need a new bar or to modify existing bar.
    8P2 standard/sport --> 8P2 s-line = no need for new bar or to modify existing bar.
    8P2 standard/sport --> 8P2 S3 = need a new bar or to modify existing bar.
  8. AudiMafia
    AudiMafia Member
    403
    13
    thats what it is aythreee
    8P1 --> 8P2 s-line = no need for new bar or to modify existing bar.
    sorry i forgot to past it.
    only if your going for an S3 conversion you need to change or modify the existing bar.... for all 8P1 and 8P2
  9. roston100
    roston100 Member
    370
    you told me in post 2 that i dont need a new bar but the list you say is correct says i do!!
  10. AudiMafia
    AudiMafia Member
    403
    13
    sorry Roston, forgot to past what i copied...
    If you have 8P1 or 8P2 sport or s-line and you want to go for S3 conversiont then you have to modify the existing bar
    If you are going from 8P1 sport/standard to 8P2 sport/standart no need to modify esxisting bar
    If you are going from 8P1 sport/standard to 8P2 s-line no need to modify esxisting bar
    hope this is clears
  11. roston100
    roston100 Member
    370
    fantastic! mine is an 8p1 sport and im going to the 8p2 s-line! :)
  12. Ads
    8,230
    608
    I've just checked ETKA and there is one reinforcement bar for the 8P1 (8p0 807 113 B) and two for the 8P2 (8p0 807 113 B and 8p0 807 113 D).
    ETKA doesn't say if 8p0 807 113 D is for an S3, but it does give a model code of PR-2JU, which I've seen elsewhere as being the code for the S3.
    So as said by the rest, it pretty much confirms that the only time you need to change your bar is if you go for an S3 bumper.
    Wonder why mattandrew (thread linked to above) changed his bar when going from 8P1 to 8P2 s-line??? Maybe he'd been reading the same threads/info that i'd seen saying that you need to change it for s-line bumpers too.
