8P Wirper coding "Tear Wiping active"
dantdi Nov 13, 2011
  1. dantdi
    dantdi ...
    521
    HI i Emailed ross-tech about activing the tear wipe. Like what my old a3 use to do.
    They sent me this back.
    Hello Dan,
    The instructions you found are correct. The wiper motor is a
    slave
    (sub-system) module from address 09:
    [Select]
    [09-Central
    Electronics]
    [Coding]
    Choose the Component: Wischer AU350 H01 0130 from
    the drop-down
    [Long Coding Helper]
    Tick "Tear Wiping active" and exit the
    helper
    [Do It!]
    I get to choosing Wischer AU350 H01 0130 from the drop-down
    then click on coding helper (long Coding helper not there)
    Then just get load black boxes from bit1 to bit 20 nothing about "Tear Wiping active" ??
    anyone help me out here, I'm a complete noob! with vag-com and poo myself every time i click button
    Just incase mess something up.
    The Dan
  2. Sandra
    Sandra Administrator Staff Member Administrator TeamMisano TFSI Owners Group Audi S3 quattro s tronic Platinum Supporter Audi Main Dealer
    28,037
    11,167
    Maybe try drop user NHN a pm. He should be able to advise.
  3. dantdi
    dantdi ...
    521
    Thanks, Yeah may have to bug Mr NHN :yes:
  4. NHN
    29,596
    1,782
    Show us a screen shot of the issues in coding.
  5. dantdi
    dantdi ...
    521
    Ok Will do!
  6. dantdi
    dantdi ...
    521
    This is what i get when iChoose the Component: Wischer AU350 H01 0130 from
    the drop-down (Only Coding Helper) not Long Coding Helper
    When i click on coding helper.
  7. NHN
    29,596
    1,782
    Did you press tab within the long coding window to check if byte 01 & 02 had any descriptive tick boxes given they have hex code in them.
    Also update to vcds 11.11 now as its released.
  8. dantdi
    dantdi ...
    521
    No, didn't click on tabs in long coding window. Have to check them tomorrow now. It's bloody rainning at mo.
    I will Post what i find in other tabs with screen shots.
    Yep when turned Laptop on got the 11.11 update Thanks Nigel :icon_thumright:
  9. NHN
    29,596
    1,782
    Rain doesnt stop anyone, close the door, job done, go on get on with it :p
  10. dantdi
    dantdi ...
    521
    :laugh: ! Sorry mate. Google my laptop (hp dragon laptop) and see why i can't do that, Break my bloody legs!
    Needs one these little netbooks for Vag-com me thinks!
  11. NHN
    29,596
    1,782
    It has a handle on the rear, use it :p
  12. dantdi
    dantdi ...
    521
    Ok, i've checked the tabs
    When i click on tab LCode2 from this window
    I get this
    Click ok then this window opens
    Bit0 to bit7 dosn't tell me anythink when the Cursors is over then.
  13. dantdi
    dantdi ...
    521
    If i dont Choose the Component: Wischer AU350 H01 0130 from
    the drop-down menu.
    There is the LONG coding helper
  14. NHN
    29,596
    1,782
    No man, I mean, put the cursor into the 1st box that shows 00, then press tab to go along to the box that shows F5, then press tab again so it goes to the next box that shows 10, these are the bytes I'm referring to, hence byte 00 is 1st box, byte 01 is 2nd box & so on, it says byte 0, byte 1 etc underneath the box.
  15. dantdi
    dantdi ...
    521
    Ohhhh!! i seee! ******!!
    Right ok. :undwech:
  16. dantdi
    dantdi ...
    521
    Sorry late reply internet been down :)banghead:talktalk)
    Nigel your a star mate!! Was under F5 as u said. Just taken it out for drive to try it and it Works!:yahoo:
    Thanks again Nigel:anbet:
  17. NHN
    29,596
    1,782
    Great :)
