8P side indicator remove/refit
ByronM Mar 13, 2009
  1. ByronM
    ByronM Member
    How easy is it to remove and refit the indicators on the wings?
    I have some silvertec bulbs to fit, but im not familiar with Audi indicator lenses etc..Are there any 'lugs' I should be aware of, or it is a case of prising carefully?
    Any hints and tips welcomed.
    Byron
  2. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    i took mine out to tint em there pretty hard to pop out but i got mine out with a fine screw driver and started from towards the back of the car if you know what i mean you got to be carefull not you scratch the paint though they should pop out
  3. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,487
    633
    Just push them towards the front of the car - there is a metal clip which holds the light in place on the rear end, push on that and the indicator should just pop out! Easy enough
  4. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    You'll have some fun if you decide to do the fronts Byron. I did mine through the inner wheel arch liner.
