8P S3 Chrome Grille to Black HELP!!!
Zorty May 22, 2012
  1. Zorty
    Zorty Member
    47
    Hi All
    i have does a search on how to spray your Chrome S3 grille to make it look lyk the black edition grille.
    i have seen it here a long time ago but cant find it anyway.
    HELP!!!!
  2. Zorty
    Zorty Member
    47
    ANYONE !!!! :(
  3. NobberUK
    NobberUK VAG Junkie
    226
    Took mine down to a local bodyshop mate.
    Imagine it'll need rubbing down, plastic priming, keying, spraying and laquer putting on. Never done it though but imagine it would be along those lines!
  4. Zorty
    Zorty Member
    47
  5. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    You could get it wrapped
  6. essIII
    essIII Active Member
    285
    35
  7. MTRL
    MTRL Split Grill!
    459
    52
  8. Zorty
    Zorty Member
    47
    That looks amazing mate. can you do mine lol..
    how long did it take and can i just spray over the chrome grille or have to sand it down ???
  9. MTRL
    MTRL Split Grill!
    459
    52
    Its really really really easy!
    I took off the front bumper to prevent any spray going into the radiator, but you could just stick some card or newspaper behind to stop it too.
    Masked up around the grill, sprayed light even layers waiting 30 mins between each layer. Took 4 or 5 coats, half a can of plasti dip.
    Any over spray can be peeled or rubbed off, its great stuff to work with, very forgiving.
    If you do go for this method, I brought the primer and gossifier. They sent massive tins of each so if you need some of that let me know.
    I didnt use primer in the end, dont think it will hurt.
    Thinking of applying some glossifier this weekend to give it a gloss finish.
  10. MTRL
    MTRL Split Grill!
    459
    52
    Cheers mate, I was a bit worried about how the black on black would look. Thought it may make it look cheap, thats why I thought plastidip was the way to go, can peel it off if not happy with it.
    I had a lquick look if I could just take the grill off but it kind of clips in on the inside of the bumper, would have had to pull the bumper forward quite a bit to prise it off..if it could be prised off. putting it back would be a pain too I would imagine.
    To me it just looked easier to take the whole front off.
    To be honest its not hard to take the bumper off, I did it on my own in about 20 minutes. Just a few torx screws and 2 bolts.
    If your going to take the front off I can go through the steps if you need.
  11. Zak0123
    Zak0123 Active Member
    540
    77
    Mattroll that looks awesome I might have to do mine now! :yes: Did you do your fog surrounds too or where they already black?
    And how much was the stuff you bought?
  12. essIII
    285
    35
  13. Zorty
    Zorty Member
    47
    Thanks Guys
    so do i still need to sand down all the Chrome on my S3 grille and also the grey parts or just clean and whip down the grille and spray over...
    ps anyone in west yorkshire or nottingham done this before...
    :icon_thumright:
  14. foxymk1
    foxymk1 Active Member
    454
    44
  15. MTRL
    MTRL Split Grill!
    459
    52
    No need to sand, can use primer if your want to be really confident it wont peel.
    I used half a can to do all that, plus I tested it out before on a spanner
