8P S3 Anyone had problems with the fuel relief valve on the fuel rail?
elgan Dec 8, 2010
  1. elgan
    elgan New Member
    26
    been having problems with the car, fuel pressure jumping from good 120+ pressure to as low as 7 bar at the rail.
    i was told a fuel relief valve on the fuel rail maybe at fault. i bought part from audi at 19+vat. its a threaded piece that goes in below the inlet manifold and accepts fuel line. I havnt changed it yet as it looks in an awkward place!
    anyone had to change one of these before?
    I looked to change the sensor/valve on top of the fuel pump (32mm spanner fixing), but they said this comes complete with a fuel pump only?
    current fault code reads Low fuel pressure.
    Help, im missing the car big time! ​
  2. gynads
    gynads Member
    314
    Apparently there is an easy way of doing this, i suggested it to my tuning company to save me some labour costs of having to remove the inlet mani. What you need is a small spanner with a 'V' shaped notch cut out of it.
  3. elgan
    elgan New Member
    26
    u mean like a ring spanner with a notch cut out of it?
    whats the sensor on top of the hpfp called? its part of a 32mm fixing. does this control fuel pressure also?
  4. JamesS4cab
    JamesS4cab Well-Known Member
    1,191
    94
    Maybe worth taking the std S3 valve back to audi and getting the Rs4 one if you are thinking of doing any future mods to your car? Its supposed to be worth doing from what I have read and while you're changing it, may as well get the uprated one!!
    Just an idea.......
  5. dc240969
    dc240969 Member VCDS Map User
    927
    There is an easy way to do it, but it needs custom parts. The long way is to remove the manifold. If your modding your motor you should go for the RS4 one.
  6. drsilviuro
    drsilviuro Member
    121
    That might not be your problem... Have you checked your cam follower?
  7. elgan
    elgan New Member
    26
    ive got that valve changed without removing the manifold. pig of a job. i just stuck a new s3 one in.
    need a new sensor for the top of the HPFP now, audi will only sell the pump complete. any one got one spare? 06F 127 025 H 7428. its built into like a 32mm bolt.
    also fitted autotech internals.
  8. S3Alex
    10,858
    4,844
    I had an RS4 regulator fitted to mine when I was having the turbo kit fitted.
    For what it's worth,it will hold the rail pressure more reliably than the standard S3 item.
