8P - rear washer
sprout99 Nov 25, 2008
  1. sprout99
    sprout99 Member
    373
    has anyone else had a rear washer problem?
    Washer has suddenly become very poor. I have taken panel off expecting to see the pipe off due to cold weather.
    Instead it seems that the problem is inside the mechanism and water is
    pi55ing out of it.
    any pointers?
  2. dollface
    dollface Member
    33
    i have same problem now with mine too , thought it could be that i didnt dilute washer cleaner enough , i will try more water . hope we find out problem
  3. VRStu
    VRStu Just Looking VCDS Map User
    1,073
    Do you use the VAG screen wash for Fan Jets?
  4. sprout99
    sprout99 Member
    373
    panel is off and it's going to dealer in morn
  5. kaz219
    kaz219 Active Member VCDS Map User
    1,808
    Mine seems to squirt out around 2 inches of water...
    I think it may have dirt or something in it so i might put a pin down it to open the hole up..
    but its still freezingg so I'm going to wait till it warms up a bit :D !!
  6. RS84
    RS84 R15 - TDI Power
    168
    Mine doesn't seem to work properly at all (only have the car a week now, my 1st A3, could be the cold), does the jet come out of the actual wiper arm?
    The wiper reservoir is heated yes?
  7. emzino
    emzino Active Member
    1,231
    Mine doesn't come out much neither and the wiper doesn't even make full contact with the arm. It leaves a gap in the shape of an arch. Wiper arm fault maybe?
  8. VRStu
    1,073
    As I eluded to above you really need to be using the OEM stuff. It is designed not to crystalise in the jets and also has antifreeze.
  9. Igdos
    Igdos Member
    323
    Also had my A3 for a week and have to say rear wash wipe isn't very impressive - a dribble comes out from the wiper arm BEFORE the wiper arm moves so more screenwash on boot lid than on windscreen. It then wipes away a couple of times to smear up the screen, got to say that's the only gripe with the new car so far though!!
  10. JohnS3
    JohnS3 Active Member
    3,032
    Sounds similar to the problems on the 8L cars. Goes searching.....
  11. JohnS3
    3,032
    This thread may be of some help.
  12. RS84
    168
    Sprout99,
    any update on your washer?
  13. kaz219
    1,808
    I had a quick look at mine and i think it may just be blocked. it was really dirty but going to poke a needle in it and see what that does :D
    I'm at uni till xmas hols so wont get time to do it soon as the A3s in a secure car park (not my heated garage!) and i dont have a needle :S
  14. NHN
    29,345
    1,719
    Fan jets arent on the 8P mate as I actually got some for the front from the passat to fit, are you telling me the later 8P has fan jets on it now or just rear?
  15. JohnS3
    3,032
    Nige, there's no fan jets on the front of my 07 S3. Would like to fit them though, thought they were great on my wifes last Golf! I imagine they are not a direct swop.
  16. NHN
    29,345
    1,719
    They were on the golf? is that the 4 or 5 mate as thats got me intrigued now if the golf ones are direct swap, the passat ones arent as deep as the existing 8P pin holes version so its kinda loose which can easily be fixed in place with glue & sealant underside so its invisible to eye, but the pipes & wiring are a direct fit, one side might need the wire made slightly longer but still fits just the same, havnt fitted 100% yet as got other things to do but did test momentarily for wiring etc.
  17. JohnS3
    3,032
    It was a good old mk 4. Hope they are a direct swop as that will be going to the top of my to do list!
  18. NHN
    29,345
    1,719
    gonna hunt down a mk4 golf now, probably get nicked for trying to steal a car, lol
  19. JohnS3
    3,032
    VAGPARTS do the mk4 heated washer jets for 11.88 each +VAT. Does this pic help?
  20. JohnS3
    3,032
    Non heated version. A complete bargain at 1.93 +VAT!
  21. Khufu
    Khufu Well-Known Member
    5,704
    31
    they were on a polo i had as a courtesy car when my old A3 was in the bodyshop. Cant remember what year it was though. I'd be up for a direct swap option too!
  22. emzino
    1,231
    What's so good about Fan Jets?
  23. JohnS3
    3,032
    They spray water across the width of the windscreen, not just in two streams.
  24. emzino
    1,231
    Ah cool. Thanks JohnS3
  25. JohnS3
    3,032
    Nige, did you find a mk 4 golf to play with?
  26. h5djr
    9,414
    1,740
    With the rear wiper the screen wash comes out of the actual wiper arm. My current A3 squirts 4 streams of screen wash onto the front screen, well up and into the moddle of the screen and makes a reasonable job when I want to clear the screen. As far as I'm aware only the actaul jets are heated but there is only one reservoir for both front and rear wipers which is located in the engine compartment so it will obviously be warmed to some degree from the heat of the engine. My wife has a new Polo and I pretty sure the jets are the Fan type. I will have a look later and see if I think they would be interchangable in any way.
  27. JohnS3
    3,032
    Top man Dave!
  28. Fast,not furious
    Fast,not furious Dealing with an OCD
    416
    I got some heated ones with 3 jets (fitted to latest A3 models) from Stoke Audi for £13.30 (see my post,Stoke Audi,Sept 1st)
    They're not an exact fit,but go on with a good shove,leaving a slight gap top and bottom (about 1mm),but work no probs.
  29. JohnS3
    3,032
  30. sprout99
    sprout99 Member
    373
    Yup..... car goes back into dealer in the morning for a new motor to be fitted, under warranty too! :)
  31. sprout99
    sprout99 Member
    373
    all done and not a penny to pay.
    Wish i could say same for the 4 months i've had the beemer.
    :shrug: Very annoying and expensive sporadic fault
