8p 3DR Speaker size
RobMorris Nov 23, 2011
  1. RobMorris
    RobMorris Member
    539
    10
    Chaps
    What size/wattage speakers are best for replacing the fronts running off the standard concert head unit
    and what size/wattage are best for replacing the rear running off the standard concert amp...the standard sub has been removed...
    and an uprated sub/amp will be fitted.
  2. AndyMac
    9,832
    45
    Fronts are 6.5" components with 1" tweeter
    Rears are 6.5" coaxials
    You'll need adapters to fit both fronts and rears
    Wattage is irrelevant as they don't make a speaker so puny that it would be overpowered by the 4 x 20w output from the HU & rear amp
    Be aware that if you have removed the stock sub then you have also removed the rear speaker amp (inside the sub), so if you are keeping the standard HU then you will have no feed to the rear speakers. You will need to either extract the amp from the old sub and reinstall it or add a small aftermarket amp to power the rears. Or better still forget about the rears altogether and spend more of your budget on front components, or even better still a decent amp to drive them.
  3. RobMorris
    RobMorris Member
    539
    10
    Cheers Andy
    Ive bought a set of 'CT25AU05 Speaker Fitting Adapter for Audi A3/A4 Front & Rear 165mm'
    Can I safely fit 6.5" 'mid bass' speakers? I know they have a larger magnet than normal speakers?
  4. AndyMac
    9,832
    45
    Should really have got the MDF ones. You need proper 2 way components, pretty much anything will fit
  5. RobMorris
    RobMorris Member
    539
    10
  6. AndyMac
    9,832
    45
    Yes, as said you need proper 2 way components and from a decent manufacturer, if you're on a budget then something like these Alpines:
    Alpine SXE-1750S
  7. RobMorris
    RobMorris Member
    539
    10
    Another waste of money ive managed!
    Cheers Andy - il go for some proper 2 way components for the front doors...
    Are the midbass ok to chuck in the rear qtrs?
