8P 1.9 Tdi Sport fan fault?
chris c Apr 11, 2013
  1. chris c
    chris c New Member
    Hello guys
    My 2004 A3 1.9 Tdi Sport has developed a fault
    The smaller radiator fan wont turn off, even with the key removed from the car and sat for a hour or so after driving?, ive removed a fuse ( number 8) but the fan keeps going?
    What can i do?
    Chris
  2. PH1L
    PH1L Gievf Buckets
    3,851
    40
    capacitor in the fanblade goes its a common fault you can change the fans or there might be a repair kit on ebay
  3. chris c
    chris c New Member
    Do you know if its safe to just unplug the fan at the connector until i can afford the replacement, providing i keep a eye on the temperature guage?
  4. PH1L
    PH1L Gievf Buckets
    3,851
    40
    in my case when one went on my old old 1.6 i actually had no battery issues leaving it going but then it wasnt spinning all that fast you could always unplug it overnight but i wouldn't recommend running without it personally i wouldnt do it
  5. chris c
    chris c New Member
    Ok, ive ordered a new fan pack set from Audi with some discount! that should arrive tomorrow.
    I will be replacing this myself, is it best to drop the old fan pack out and remove the airbox and try lift it out?
  6. PH1L
    PH1L Gievf Buckets
    3,851
    40
    i stripped the front end off if im being honest its not the best for access someone else may say different but as i didnt attempt it this way i cant comment
