8L S2 2002 - Ticking from top end of engine - what could it be?
Mi7rennie Nov 28, 2012
  1. Mi7rennie
    Mi7rennie Member
    82
    Hi Folks,
    Any suggestions what a ticking noise from the top end of my engine could be.
    Just started and appears to be there at all revs and with or without the car moving / clutch engaged.
    Car is driving fine.
    I have VAG com, any suggestion what I could log to point me in the right direction?
  2. voorhees
    voorhees Moderator Staff Member Moderator DSG
    16,154
    1,986
  3. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Vvt. Worn pads...
  4. Mi7rennie
    Mi7rennie Member
    82
    I don't think it's the carbon canister as per Voorhees reply, it made that carbon canister tick already. This is an extra ticking noise, it never goes away and is definitely revs related.
    VVT pads? Is this the same as the cam chain tensioner?
  5. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,266
    360
    yeah, the pads are the parts that actually contact the chain
    I had my chain tensioner replaced last week because my car sounded like a diesel on idle.
  6. Mi7rennie
    Mi7rennie Member
    82
    How much was the part, what was the part number or did you get a garage to fit it?
    Cheers!
  7. Alex C
    3,266
    360
    not sure of the part number, got a independant audi specialist to fit it. The part was over £300....
    The problem with mine was the fine piece of gauze that filters the oil before entering the cam chain tensioner had broken which fouled the mechanism
  8. Mi7rennie
    Mi7rennie Member
    82
    Bloody hell, I hope mine isn't going to cost that. I assume that's not the normal failure mode...
    If it is a worn VVT pad I hope the pad can be changed.
    Can anyone point me to a thread for replacing this bit?
    Stumacs3 likes this.
  9. Eddie S3
    Eddie S3 Member
    128
    9
  10. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
  11. Eddie S3
    Eddie S3 Member
    128
    9
    Was it only apparent you needed new pads after having it out?
    When i took my car to audi for a health check all it said was
    To replace leaking camshaft adjuster, seal and rocker cover gasket.
    Just wondering if my adjuster actually needs replaced or if its just the half moon seal that leaking
  12. s3dave
    10,110
    736
    I was getting my head refurbed with new valves etc... and they phoned me up and said the chain tensioner had gone at a cost of £330 so i thought bugger that and went down, it turned out to be the pads that were worn, and they said you cannot buy them seperatly so i scoured the net and got them...
  13. Mi7rennie
    Mi7rennie Member
    82
    S3 Dave, you are a legend. I'm going to order these now.
    I assume I need both and they will fit my BAM engine, I can't see any reference other than 1.8t.
    Cheers again!
  14. s3dave
    10,110
    736
    Yes both top and bottom...
  15. Mi7rennie
    Mi7rennie Member
    82
    Good man, I'm now looking for the correct seals to finish the job, could you point me in the right direction?
  16. Eddie S3
    Eddie S3 Member
    128
    9
    Half moon seal: 058198217
    Rocker Cover Gasket: 058198025a
  17. Mi7rennie
    Mi7rennie Member
    82
    Appreciated lads, thanks for the prompt replies and the excellent info.
    I also read about a tool required to lock something or other, any idea what it's called?
    Full of questions :)
  18. s3dave
    10,110
    736
  19. Mi7rennie
    Mi7rennie Member
    82
    Ok, thanks so much. Got it all ordered.
    Anything else I should think about replacing while I'm in there?
    Mike
  20. s3dave
    10,110
    736
    half moon gasket and rocker cover gasket... unless you have them...
  21. Mi7rennie
    Mi7rennie Member
    82
    yeah I'll get them from Audi when the runners arrive from the states.
    I think thats me sorted.
    I'm going to keep driving the car in the mean time, I doubt it'll do much damage, just a bit noisy.
    Cheers again
  22. Mi7rennie
    Mi7rennie Member
    82
    What about the cam chain, the car has done 100,000 miles, would this be worth changing at the same time?
    Cheers,
    Mike
  23. Mi7rennie
    Mi7rennie Member
    82
    So I eventually got round to replacing my VVT tensioner pads while I was doing the alternator at the weekend. Unfortunately it hasn't fixed the noise!
    Bugger.
    What eles could it be? I'll get a short video and stick it up here...
  24. Mi7rennie
    Mi7rennie Member
    82
    I'm still chasing this noise, I dropped the sump at the weekend and replaced the pick up pipe, o ring and sump pan. Nice new oil and filter and a forte oil treat flush before hand..... it's still chapping away.
    I guess I could just leave it until it breaks... whatever it is. That may be the easiest option, but it depends if it fails in an expensive way....
    I also think I have a wee oil leak from the sump.... double bugger!
  25. Alex C
    3,266
    360
    it could be the cam chain tensioner, i am guessing you only replaced the pads and not the unit itself. When mine failed it wasn't the pads it was the mechanism itself. Could check the tappets?
  26. [Dave B]
    [Dave B] Daddy
    2,027
    145
    Are you sure this isn't just the injectors ticking?
  27. Mi7rennie
    Mi7rennie Member
    82
    I only replaced the tensioner pads.....
    I guess it could be an injector. I'll try removing one harness at a time and see if it goes away.
  28. [Dave B]
    [Dave B] Daddy
    2,027
    145
    I only raised it as I can hear all my injectors ticking and at first I cacked myself thinking it was a tapping not a ticking!
