8L quattro eats back tyres in 23K!? Haldex issue??
jimmp Jan 14, 2011
  1. jimmp
    jimmp Member
    194
    Hello,
    following my MOT this week, I've had to replace my rear tyres on the 8L. They're finished in 23 months and 23 thousand miles.
    I've had a few quattros and I don't remember one being this aggressive on the rubber at the rear. It makes me wonder about the front/rear torque split on the standard Haldex which I've heard conflicting reports as to whether the drive is really there at the back during normal conditions or whether it's on all the time.
    Following a couple of "exciting" winters does everyone think this is normal (I know the drive changes with temperature) or do you think I've a larger DTC-invisible Haldex issue...?
    JimP
  2. fran-s3
    fran-s3 Active Member VCDS Map User
    1,103
    I don't know what everyone else thinks but personally getting 23,000 miles out of tyres seems blinking amazing to me! I'd be well happy if that was me.... (10k here)
  3. jimmp
    jimmp Member
    194
    crikey- really??!!
  4. Dane
    Dane Had an 8L S3, a B5 RS4 now I have a B8 S4
    4,086
    182
    :iagree:
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Is the car lowered? do you have adjustable arms?
  6. sportstractor
    sportstractor Chugger
    2,709
    dam right!
  7. Broken Byzan
    13,237
    465
    Thats about 3 x the miles i get.
    Sounds good to me assuming they wear evenly
  8. steve bain
    steve bain Member
    642
    sounds good to me too! i get around 12,000 normally on non quattros
  9. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,261
    357
    really! you only get 10K, 12K, 8K out of the rear tyres, thats not very good. Although yours is an A4 with Torsen 4WD Mark, is it? But still they are very low numbers. For me that would equate to a max of about 1 year of tread for the rear tyres. The fronts i could understand. At the same time i wouldn't complain if i was only getting 23K out of my rear tyres, that seems pretty good. I think i managed about 20K with my last set of rears. Although my car has since been lowered which may effect the tyre wear...
  10. <tuffty/>
    21,016
    3,780
    My rears have been on for not much more than that and have lived through 2 sets of fronts... I am on my third set of fronts now and the rears are close to the wear marks... I reckon they haven't done much more mileage than yours tbh 24k ish at a guess...
    Fronts wearing concerned me more but I put that down to my my driving style... I like to carry as much of the speed the limit allows around corners as my car handles well so the fronts take a pounding with 1.5 tonnes of vehicle asking that of them...
  11. jimmp
    jimmp Member
    194
    oh right- thanks for that lads...
    no- the car is totally standard- it has had all the rear end replaced in terms of rolls bars/bushes and springs in the time I've had it so mabey it rides a little bit harder than a softened up '01 plate...?
    That's splitting hairs though by the sounds of it!
    Somebody at a local tyre outfit was telling me I couldn't mix tread patterns on the car as it affected "rolling circumference" and would cause a differential issue. Audi agreed with that when I mentioned it to them but honestly, what do they know about 10 year old stuff now?!
    MOT place told me that was ****- what do you think??
    JimP
  12. DaveA3
    DaveA3 Audi A-Trizzle!
    2,370
    15
    wtf anything over 20k in 2 years is brilliant!
  13. <tuffty/>
    21,016
    3,780
    Its plausible but really dependent on the tyres... a 225/45/17 'should' have similar rolling diameter as any other and lets be realistic fronts and rears wear at different rates so that in itself presents as a difference between fronts and rears..
    the problem you would potentially have is the difference affecting the speed measurements from the ABS sensors which could at worse case throw a fault up for the ESP...
    I would not mix on axles though and I would replace tyres in pairs... this may not be the most practicle solution for some people maybe but I can see where the tyre outfit are going with this... mixing tread patterns across the axle can lead to unpredictable handling... if you find a limit going around a right hand corner it may not be the same going around a left hand corner...
    Anyhoo... its sensible advice to keep all the tyres the same on all 4 corners, replace in pairs unless changing to a new trye manufacturer/tread pattern in which case replace all 4 and sell the good ones on ebay..
  14. Alex C
    3,261
    357
    My personal opinion based on not alot is that that is bull. I am sure the wear rate across the front to rear would cause more of a disparity between rolling circumferences, but we dont worry about this. But when it comes to tyre brand we all worry that we must have exactly the same front to back....I dont know, maybe i am missing the point here
  15. Alex C
    3,261
    357
    doh.... Tufty has written much the same
  16. Welly
    Welly VX220 SC Driver :)
    10,696
    127
    lol, same here dude.
  17. Madeley
    Madeley Member VCDS Map User
    125
    You got a monster quatro/truck tuffty lol
  18. <tuffty/>
    21,016
    3,780
    DOH!... S3 Allroad lol... edited :)
  19. Broken Byzan
    13,237
    465
    yeah damned torsion has eaten a set in 10-12k miles
  20. DavidW
    DavidW Member
    211
    Mine recently ate a set of Dunlop rears in less than twelve months/approx 10k but the front Bridgestones, replaced about a month after are still ok, worn but not virtually bald like the rears. Either something is amiss or Dunlop Sport 01's are very soft.
  21. Perplexer
    Perplexer Member
    236
    My rear tyres on my S3 are due for replacing. They were fitted on 12/09/2007 and have covered 35K miles. :) (Michelin PS2's)
