8J 18 wheels offset 32 with 235/40R18 tyres - will this be OK on 2010 S3?
Braveheart May 17, 2012
  1. Braveheart
    Braveheart New Member
    20
    As per title, would I have any issues with this? Standard set-up is 7.5J 18 ET54 so with slightly wider wheel that's about an extra inch wider per corner. Would this be too much? Car is standard height but thinking about H&R -25mm springs as well.
  2. MartayMcFly
    MartayMcFly Booooooost VCDS Map User Gold Supporter
    2,766
    355
    Someone (N8) needs to make a chart or something of what size will fit our cars.
    I'm not 100% on 18s, but ET32 sounds too low. 28mm wider (a little over an inch, like you said). I'd also say that 235s will be too wide on an 8J when lowered, go for 225/35 or 215/35, maybe 225/40 for a shade more side wall.
  3. moag
    moag she's no d-turbo
    821
    35
    Wheel size is fine but the wheel offset isn't great for the A3/S3.
    It could work, but you'll need to run a skinnier tyre, 215/35 or 225/35.
    235/40/18 will rub badly, and even more so when lowered obviously
  4. Braveheart
    20
    Thanks guys, saw this set on ebay, will give it a miss!
