8E Audi A4 Distance computer coding
Chris90 Aug 25, 2013
  1. Chris90
    Chris90 Active Member VCDS Map User
    609
    226
    43
    Hi
    Have a mate that has a 2007 A4 8E that he has installed the multi function wiper stalk onto to get the miles and all the distance related stuff on the clocks.
    I tried to code it today through Steering Wheel > Adaption and making sure board computer and Cruise control function were enabled but the stalk still didnt work.
    Does anyone have any ideas how to get it working?
    Is there something to alter in the Instruments section to tell the cluster it has a computer etc?
    Chris
  2. dualmono21
    dualmono21 Well-Known Member VCDS Map User
    1,138
    may possibly have something to do with the comfort module
    if this isnt able to be adapted he may have to buy one which is allready enabled
    similar problem on some s4,s which didnt come with cruise control
  3. hades-
    9,481
    646
    you also need to use 17-Instruments
    Adaption-10
    Channel 19
    31210
    save it and it should work
    depending if you got 16 Steering Wheel right
  4. hades-
    9,481
    646
    what codeing did you use in 16 Steering Wheel
  5. Chris90
    609
    226
    43
    02021 originally changed to 02041 with the board computer and cruise.
  6. Chris90
    609
    226
    43
    Anyone?
  7. hades-
    9,481
    646
    iv told you above you need to code 16 Steering Wheel right aswell
  8. Chris90
    609
    226
    43
    Correct, but is the coding above correct is what I meant :)
