60mm lowered a4's
9 below zero Oct 8, 2009
  1. 9 below zero
    9 below zero Member
    76
    I've been debating as to how low i go on my A4. 40mm or 60mm. Has any one got some pictures of an A4 lowered 60mm on 18" wheels?
  2. Siena
    Siena Active Member
    2,626
    Before giving a definite answer - why do you want to go 60mm lower? Is it quattro or FWD? Is it a Sport or regular model?
    You don't say what engine your car has either, and if it's auto or manual.
  3. Geeman
    Geeman Low Life
    1,318
    Mine's much lower than 60mm, but still on 18's...
  4. 9 below zero
    9 below zero Member
    76
    It's a standard 1.8 manuel audi a4 front wheel drive. I'm going to put 18's on it and i don't want it to look like a monster truck
  5. 9 below zero
    9 below zero Member
    76
    Hi that looks good but i don't think i want it that low because of speed bumps and takng people in the back. Do your wheels rub at all?
    Here is my car as it is now
  6. Mäki
    Mäki Guest
    Here's mine black A4 with 18" rims and 30-40mm lowering (not sure because I bought it lowered, but it looks like my last car that I lowered 40mm).
  7. aragorn
    18,665
    880
    i dont really think you need to go that low.
    http://www.lr90.org/gallery2/main.php?g2_itemId=288
    Thats a "30mm" lowering kit on Craigs S4 (although S4's are already lowered 20mm from the factory, so its the equivalent of 50mm lower than your SE).
    This is marks quattro on "40mm" springs:
    http://i38.photobucket.com/albums/e123/audimad/TQS/100_4724.jpg
    Go much lower and it will start to affect the handling the the ride quality will be out the window. Craigs car though rides just as well as it did when standard, and i'll assume marks does too, but i've never been in it.
  8. 9 below zero
    9 below zero Member
    76
    To be honest i think i'll stick with the idea of 60mm springs.
  9. Broken Byzan
    13,244
    468
    What shocks?
    Please don't say the original ones
  10. 9 below zero
    9 below zero Member
    76
    The orignals?
  11. Broken Byzan
    13,244
    468
    Oh !! you will be lucky if they last longer than a few thousand miles. Std shocks cannot simply dae with the loadings imposed by such low and hard springs especially as they are probably past their best at ten years old. Unless you also reset the arms you may get premature wear there too
    Good luck with it
  12. jcb
    jcb Active Member
    4,132
    13
    IMO if you can't get your horizontal finger between the top of the tyre and the edge of teh wing it is too low.
    IIRC 60mm will bury your 18" tyre in the arch and put many aspects of your suspension past the horizontal into inverted like this 0\_/0 instead of 0/-\0
  13. 9 below zero
    9 below zero Member
    76
    Haha nice example!
    yeah i've slept on it and i think 60mm might be too low, safety wise. All i'm after is a standard look, i don't want it too high but on the other hand i don't want it to have that "slammed" look.
    So will it be ok to put brand new 40mm springs on standard suspension? I know the best result will be on new shocks but i dont put my foot down around corners and i'm not after performance...
  14. 9 below zero
    9 below zero Member
    76
    are they 40mm springs on standard shocks Mäki? I can remember you said they were H+R springs
  15. sam4191
    sam4191 If In doubt, Flat out!
    417
    Hi mate,
    To be honest. I'd change the shocks too. I didn't listen to these guys when I put some -40mm springs on my origional shocks. Within 1000 miles, the rears were totalled. lol. (admittadely, the car had done 126000 ish).
    up to you at the end of the day though. =D good luck either way!=)
  16. 9 below zero
    9 below zero Member
    76
    yeah I think i will to be honest, i've seen these but don't know what make they are...
    Does anyone have any ideas as to what make they are?
  17. Oranoco
    Oranoco Well-Known Member
    4,011
    414
    If in doubt leave it alone mate. No point putting potential tat on the car. I lowered mine 40mm on the stock dampers and the back now has developed a rude noise. I'm now going to spend the money again to put Wetec coilovers on after Christmas
  18. RadCap
    RadCap Member
    33
    OMG! Sweet ride mate :icon_thumright:
  19. Cruz
    Cruz Member
    74
    I have recently fitted a set of eibach pro springs to my avant dropping it by 30mm on standard shocks which still offers a very comfortable ride, much better handling and imo looks just right.
  20. 9 below zero
    9 below zero Member
    76
    I know it could be tat but i think it's worth a shot at £80.00 for the lot
