60mm gauge in centre vents
LeeT Aug 18, 2011
  1. LeeT
    LeeT Member
    429
    As per title, will a 60mm gauge fit into the centre vents or will it look stupidly big? Any pics?
  2. Bradderz_1988
    3,945
    235
    I reckon it will fit I've got a 52mm in mine and it looks fairly big
  3. LeeT
    LeeT Member
    429
    Thanks Bradderz, does anyone know for sure?
  4. mike-a
    mike-a Member
    103
    It'll look 8mm bigger than Bradderz'.Loads of room in a vent to fit a 60mm gauge.
  5. S4_dan
    S4_dan Fire up the Quattro! VCDS Map User
    2,699
    157
    This is what i fitted on my S4, think it's 52mm though. Although, can't 100% remember.
  6. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    personally think it looks daft.
    it should be sunk in more, 60 mm will be a stretch if that is 52mm
    never really understood why people have boost gauges all over the dash. how often do you look at them and what for?
    its only useful if there is a problem
  7. Bradderz_1988
    3,945
    235
    I had a look at mine and it looks as if there is around 6-8mm either side of the gauge to play with so I'd say it would be possible but will be a tight fit !!
  8. tangerinedream
    tangerinedream Member
    249
    mines mounted above the steering wheel in newsouths custom pod, not into all this hacking the vents about. i look at mine all the time lets you know if theres a problem before its serious also looks good !
  9. LeeT
    LeeT Member
    429
    Thanks for the replies. Ive bought it now so if looks too big for the vent, ill have to look into other options. Its handy to know what you are boosting at especially when you are at a high state of tune
