6 Disc Changer - Is it MP3?
N8 Dec 11, 2007
  1. N8
    17,163
    718
    Hi guys just wondering if the 6 disc changer I've ordered is MP3 compatible?
    Thanks:hi:
  2. MarcQuinlivan
    MarcQuinlivan Active Member
    2,539
    If it is the Audi glovebox one, then the short answer is no.
  3. N8
    17,163
    718
    Thanks Marc. :icon_thumright: Do you know if it has cd text though?
  4. MarcQuinlivan
    2,539
    not as far as I am aware. I believe CD Text and MP3 functionality was only introduced in the Gen II+ head units (and RNS-E).
  5. N8
    17,163
    718
    Well I have RSN-E my A3 will be a 2008
  6. MarcQuinlivan
    2,539
    then you can use the two SD card slots in the RNS-E instead of the six disc changer.
    I know they'll take 2GB ones - maybe even 4GB ones.
  7. N8
    17,163
    718
    Yeh I know. But I've got so much music I'll use it all. I might sell the audi one and get an mp3 changer from s8craig. Thanks for all your help marc
  8. Markm49
    Markm49 Member
    111
    Not sure on the 6 cd changer but my Symphony II+ upgrade which takes 6 cds via the front slot is MP3 compatible.
  9. N8
    17,163
    718
    Thanks for your help mark.
  10. PetrolDave
    PetrolDave Well-Known Member
    1,559
    85
    The RNS-E does NOT have CD text or MP3 from the external CD changer.
    Only the internal CD changer on the Symphony II+ can play MP3 CDs, not the external one.
    The only way to read an MP3 CD with an RNS-E is to put it in the internal DVD drive - and have no navigation since that's where the map DVD has to go!
    The only way to get track names on the RNS-E and have working navigation is to use the built-in SD card readers. Then you can use 2 x 4GB SD cards with the equivalent of 30 CDs worth of music on them.
  11. N8
    17,163
    718
    s8craig does external MP3 cd changer, so I'll swap mine and get that dave, did u get my pm?
  12. PetrolDave
    1,559
    85
    Good plan - though be aware that the external MP3 changer is NOT an Audi OE item (usually something like Sony or Panasonic) and you still won't get track names.
    The only Audi OE MP3 CD changer is for MMI cars (and if your car takes an RNS-E then you DON'T have MMI - despite the startup screen saying MMI, blame an idiot marketing person for that little piece of stupidity).
    PM replied to.
  13. N8
    17,163
    718
    AWWWWWWWWWWWWWWWWWWW. DOH. You're right it says mine is MMI but obviously not! SD Cards will have to do. So does mine display text??
  14. MarcQuinlivan
    2,539
    um, isn't that what I said?
  15. MarcQuinlivan
    2,539
    do what I did and go for the PhatNoise jukebox. 20GB HDD in the boot with voice menus to guide you through playlists\albums\tracks\artists. Better that the 6 disc changer anyway.
  16. Jo Sharp
    Jo Sharp Member
    131
    My solution to this problem was to buy the Symphony 2 headunit and have a TomTom satnav. I don't like the Audi fitted nav anyway; the TomTom is a LOT cheaper and I can take it with me into other cars if needed. The Symphony 2 works well with MP3 discs showing the track titles on the unit as well as on the instrument info panel.
  17. Marcyboy
    Marcyboy Member
    119
    Also Can confirm that the RNS-E Does not read MP3 CD's from the 6 Disc Changer - only the Map DVD Slot Reads DVD's.... No need really when you can have 2 x 2gb cards! complete with all the songs under the sun!!!
