6,000 revs - stuttering - cutting out - what now!!
ash_s3 Feb 12, 2008
  1. ash_s3
    ash_s3 Active Member
    1,016
    Came across another fault on my S3 today
    Was giving it a bit of throttle down the dual carrigeway and when the revs reached about 6k in all gears (i think) the engine stuttered and jerked. Then changed gear and it was fine up until about 6k in the next gear then the same thing again.
    Could it be the TIP collapsing, ive searched old posts but lots of people dont tell the symptoms and the cure which is a problem.
    Can anyone help?
    Ash
  2. Stewart
    Stewart Member
    705
    10
    Possibly but unlikely, TIP collapse occurred on earlier TIPs (later TIPs had steel ribs/banding) and at peak torque. Torque will have tailed off quite a bit at 6krpm...
    You need to be logging with VAG-COM to try and pinpoint whats happening.
  3. ash_s3
    1,016
    Didn't realise this, thanks Stewart
    Any ideas at all? MAF, temp sensor, n75, DV etc...
    I love S3's....
    ....sometimes!!
  4. Stewart
    Stewart Member
    705
    10
    Could be a number of things, could be coil pack breaking down, could be plug/s breaking down, MAF, lambda
    You NEED to VAG-COM first, at least to see what if any error codes are being thrown up...
  5. golf
    golf ***** rent boy VCDS Map User
    1,556
    You need to run it through Vag-Com, it could be so many different things like Stewart mentioned.
    If your ESP light is permanently stuck on, it's a good bet that your MAF has had it.
  6. Ballcrusher
    Ballcrusher NO CAT JUST 3" STRAIT THREW
    347
    i had this when i first bought my s3 and crazy it sounds but turned out to be 2 of the coil packs for some reason they wer beaking down after 5500rpm all the time.
  7. Stewart
    Stewart Member
    705
    10
    Did VAG-COM report intermittent misfires on the relevant cylinders?
  8. Ballcrusher
    347
    didnt use vag com as i spoke to a friend who said it could be the above problem so i replaced all the coil packs one by one bit of an **** job and turned out to be the first to coil packs from the drivers side
  9. simch
    simch Active Member
    2,028
    Be very careful ash. There are a couple of guys on TT forum in January who reported similar, 4500 revs though, and two weeks later boht their motors chucked rods.
    I would get it on vagcom today and drive it steady til its sorted...
  10. ash_s3
    1,016
    Cheers Simch
    no management lights on at all
    Il get it plugged in asap!
    Cut out on me today in traffic for no apparent reason, stuggled to re-start but was fine once it was started again and was fine for the rest of the day, wierd!
    ash
  11. simch
    simch Active Member
    2,028
    it seems a common thread on here where someone is buying an s3 and a few weeks in is having problems! It makes me worry about why they are up for sale tbh!
    Hope you get it sorted.
  12. Stewart
    Stewart Member
    705
    10
    Indeed! And why do the problems never show themselves on extended test drives!
