5th gear "whine"
AshJS Apr 28, 2013
  1. AshJS
    AshJS New Member
    Hi all, i have a strange "problem" i own a 54 plate A3 2.0L TDI Sport, whenever i down shift from 6th to 5th or up from 4th to 5th, as i release the clutch i get a small "whine" noise, it only happens going into 5th gear.
    When i was at the Audi garage getting some parts i asked about it and the parts guy got one of their mechanics and he hadn't heard of the issue before and thought it was odd it only happens going into 5th, he suggested it is not something to worry about, that maybe the sync is slightly out but he would expect it to happen in all gears.
    He said it may be worth changing the gearbox oil to see if that helps and also look in the oil to see if any metal is inside and that would then be a problem. I was going to change the gearbox oil myself but from what i have seen online (very little) i need a special suction pump to remove the oil? I thought it would be possible to drain the gearbox oil in the same way you do for the engine oil?
    Any advice on how to change gearbox oil myself or if you have experienced the problem and know what it may be would be very gratefully received.
  2. AshJS
    AshJS New Member
    Anyone?
  3. pafcpilgrim
    pafcpilgrim New Member
    10
    Funny as I have this exact same problem and exactly the same car, year model etc. I was thinking an oil change from the gear box.
  4. audi5inline
    audi5inline Member
    64
    any updates on this problem ?
  5. crazyjay91
    crazyjay91 If in Doubt, FLAT OUT!
    192
    46
    Did anyone solve this issue? I've got exactly the same issue. I've also got the same car, year and engine..
  6. Orange225
    Orange225 Active Member
    987
    132
    43
    Another one here with the same year and engine. Mine whines when coasting in 5th only.
  7. crazyjay91
    192
    46
    My car has stopped the whining noise whilst changing into 5th. It all stopped after I had the car remapped (most like coincidental) Or pushing more power/dyno run may have done something?
  8. Orange225
    987
    132
    43
    Gonna try an oil change and see if that makes a difference.
