58 reg A4 3.0 lt Quattro Faults?
bbeegl Sep 17, 2012
  1. bbeegl
    bbeegl New Member
    Hi all new here,
    My son's thinking of buying a 58 reg 3.0 tdi A4 quattro se 6 spd manual with 108k on the
    clock, it's got FSH, i'm a retired mechanic and was wondering if their is anything common
    fault wise to check for.
    thanks in advice all for any info
    Alan.
  2. Audi Dynamik
    Audi Dynamik Well-Known Member
    2,218
    308
    Im not sure about that, Somebody soon will come up with an answer :)
  3. Bigslope
    Bigslope Member
    44
    Think the Op says he is a mechanic not the previous owner. It's like anything, something can go wrong no matter how well it is looked after. I find as long as it has been serviced and had regular oil changes then usually it is only minor things that pop up every now and then.
  4. Audi Dynamik
    2,218
    308
    My Bad, i was rushing reading it as i was in a rush to watch a T.V Programme haha !
  5. Pyeman
    Pyeman Member VCDS Map User quattro Audi A6 Audi Avant Owner Group TDi
    183
    20
    DPF is the only thing that i cam think of.
    It should be ok if it been looked after.
  6. johnnythepie
    johnnythepie Well-Known Member
    2,242
    75
    That really helped the guy .:wtf:
  7. a6_chris
    a6_chris Well-Known Member
    1,883
    160
    Didn't it just!
  8. trance
    trance New Member
    29
    DPF, clutch/flywheel, egr cooler - loss of coolant.
    Have had bother with them all apart from the DPF so far!
  9. Jeff Cooper
    Jeff Cooper New Member
    15
    Ive had a few now and only thing Ive had issues with is inlet manifold motor which is quite common on the 3.0 and 2.7, when they go wrong it puts the management light on, car still drives fine but light is annoying, they can be taken off and serviced which sometimes is a fix.
