"56" plate RS4 Fault Codes
wuzie123 Jul 25, 2012
  1. wuzie123
    wuzie123 New Member
    Hey my girlfriend and i have just bought a nice rs4 only problem that i have with it is the flat tyre warning light is on. i have tried resetting it on the dash with no joy so i popped along to my mates garage and put it on his diagnostics it came up with a couple fault codes being
    "ERROR CODE : 1521 (tyre pressure sensor (ATT))"
    "FAULTY ERROR CODE : 1833 (antenna for rear tyre pressure supervision (ATT))"
    Anyone got info on these as i dont know what needs replaced... or can i turn this system off???
    thanks doug king
  2. hades-
    9,481
    646
    what did you scan it with ?
    you can turn it off via VCDS
  3. g12
    g12 Member
    43
    There is also an option in VCDS coding - under Tire Pressure to select the correct Antenna frequency (theres 2) - Mine was on the wrong setting causing the flat tyre error to come on.
  4. wuzie123
    wuzie123 New Member
    thanks for the reply not been on for a while
    i scanned it with a texa digagnostic tool at my work but it didnt seem to be able to do much
    will see if i can find a vcds tool around aberdeen
    if not how do i go about getting one??
    cheers doug
  5. Administrators
    Administrators Administrator Staff Member Administrator Audi A4 TDi
    3,976
    587
    Hi Doug
    If you go to the VCDS map you might find someone... Or drop into the Scottish section here and have a chat to Sandra or one of the team and see if they can help you.
    A
