55reg A3 S-Line - - Best offset
just017 Jun 4, 2009
  1. just017
    just017 Member
    436
    Going to buy some rims this weekend, the ones i'm looking at are:
    [FONT=Arial, Helvetica, Sans-Serif]Metal Type: [/FONT]Aluminium
    [FONT=Arial, Helvetica, Sans-Serif]Tyre Type: [/FONT]All-Weather
    [FONT=Arial, Helvetica, Sans-Serif]Rim Width: [/FONT]8J
    [FONT=Arial, Helvetica, Sans-Serif]Tyre Width: [/FONT]225
    [FONT=Arial, Helvetica, Sans-Serif]Rim Diameter: [/FONT]18 inches
    [FONT=Arial, Helvetica, Sans-Serif]Aspect Ratio: [/FONT]40
    [FONT=Arial, Helvetica, Sans-Serif]Offset: [/FONT]35
    [FONT=Arial, Helvetica, Sans-Serif]Load Index: [/FONT]92
    [FONT=Arial, Helvetica, Sans-Serif]Number of Studs: [/FONT]5
    [FONT=Arial, Helvetica, Sans-Serif]Speed Rating: [/FONT]Y: max 186 mph
    [FONT=Arial, Helvetica, Sans-Serif]Stud Diameter: [/FONT]100
    How will these look?
  2. N8
    17,163
    718
    Not sure if ET35 is not low on a rim 8J wide...
  3. Lee_R
    Lee_R Active Member
    2,499
    12
    They will stick out a bit too much for my liking on the front, 45mm is the lowest you should really go unless your after a bit of show car "poke"
  4. scottie123
    scottie123 (●̮̮̃•̃) (●&#
    1,972
    They wont fit for 2 reasons.
    1st is that they are the wrong pcd . You stud diameter 112 not 100
    the offset is wrong . you are looking at between 45-55 ideally
    hope this helps
  5. N8
    17,163
    718
    Well on a 9J rim, the lowest offset you can go is ET41 - I know that for a fact
  6. just017
    just017 Member
    436
    Ahhhh getting confused again lol.... in that case, these new rs6 wheels, not seen alot of people with them, is there any reason? i think they good good. But again the offset is 35:
    [FONT=Arial, Helvetica, Sans-Serif]Brand: [/FONT]NEW RS6 STYLE
    [FONT=Arial, Helvetica, Sans-Serif]Rim Structure: [/FONT]One Piece
    [FONT=Arial, Helvetica, Sans-Serif]Manufacturer Part Number: [/FONT]557
    Anyone got some RS4 reps with right stud diameter and offset for sale?
  7. Boydie
    Boydie S3 8V DSG VCDS Map User
    3,450
    588
    You can fit et35 but you will have to wear a stretched tyre!
    Ideally you want et50 - a happy medium!
  8. N8
    17,163
    718
    To be fair I think Nick from sweden had 19x8.5 BBS CH on his with ET35, I still can't believe how that is possible put he showed me pics
  9. just017
    just017 Member
    436
    wow seem harder than i thought finding the right rim and offset for the A3. Would you guys recommend 18" or 19"?
  10. Lee_R
    Lee_R Active Member
    2,499
    12
    You must be looking in the wrong places then, Replicas in 5x112 ET45 are the most common fitment you can get, just look at the pages of them on Ebay!
    18 or 19 will fit fine, although it will sit a little high on 19's so you will need to lower it. If you stick to 18's then you will be ok at normal height and the tyres are also a lot cheaper for the 18's.
  11. cameron1
    cameron1 Member
    56
    i'm getting some 18" reps from wheelbase. They are 45mm - 5 x 112 - nice and cheap, including the upgraded toyo tyres for £609
  12. just017
    just017 Member
    436
    Ahh i found a few now, what you rekon, new rs6 style or the new rs4 style?
  13. just017
    just017 Member
    436
    What you guys rekon on black rims on a lava grey car?
    I quite like the thought...
    Thinking somethink that look like these...
    But on this RS4 style alloy
  14. N8
    17,163
    718
    Go for the genuine TTs. Wanna start seeing more OEM on this forum rather than replica pot hole crumblers.
  15. just017
    just017 Member
    436
    I wish mate, thats listed as about £900 for the 1 wheel!
    If i could go 100% OEM i would, but i think alloys are the only thing over my budget
  16. N8
    17,163
    718
    Well by a 2nd hand set, wait a bit then get them refurbed, worth it in the long run! There is a genuine set on ebay for about £1100, he'll take £900 outside of the bay cash all day long.
  17. 10blazin
    10blazin HYPERDRIVE NEEDED
    3,301
    JUST017 reps aint to bad ive got 19s and believe me they have took some hard knocks and are fine..... i got mine from wheelbase to for about 700 with falcon tires
    but i like the black ones you posted there nice..... the rs6 reps i felt at wheelbase were really light though , felt like they would crumble when i got a grip of em id go for something else .....
  18. just017
    just017 Member
    436
    Yeah i'm thinking RS4 reps but powder coated either a matt black or a grey colour. But not sure how grey will lookk on a lava grey car.
