50/50 haldex mod
beachbuggy Jun 26, 2013
  1. Pedrosousa
    Pedrosousa Member
    175
    But if you want to run at 50/50 you can use the switch to chance from 4wd to 2wd... Or you have to find the ideal point of ajustement and run like that
  2. Andrew@A.L.D
    3,879
    617
  3. Sam_
    Sam_ Down under
    3,038
    480
    Where would you mount that :/
  4. MexxT
    MexxT Member
    31
    If you can get a steppermotor to fit, it would be awsome! Adjustment from inside the car :D
  5. Andrew@A.L.D
    3,879
    617
    In the boot
  6. Andrew@A.L.D
    3,879
    617
    The haldex ready runs a stepper motor, you just need to find a way to control it
  7. Andrew@A.L.D
    3,879
    617
    How do I go about setting up a group buy if these work out well?
    these will cover all pre+post face lift S3's, TT's, R32's, 1.8T Q's anything that runs a first generation Haldex
  8. kwistof
    kwistof South East Events Moderator Regional Rep
    2,434
    538
    Surely this needs to be done first...
    Before this...
    From my very limited knowledge of watching Dragon's Den and The apprentice - doesn't it take quiet a while for a patent to get fully set up and accepted?
  9. Andrew@A.L.D
    3,879
    617
  10. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    Are these tested yet?
    Just im guessing its not cheap getting a patent on things and fighting the legal cases that may follow if somebody steps on your toes if you later revise the design making it not covered by the original patent?
  11. ScottD3
    ScottD3 I want your faulty electronics Supporter Team V6 quattro Audi A8 Audi S8 saloon Team Akoya TDi
    15,165
    1,124
    That's a catch can right?
    You'd have to drill holes in the boot floor and route pipes up through?
  12. S3 Paul
    2,825
    107
    I thought that too.
    Also as the haldex unit has a breather pipe so im told ( will check friday) fitting then extra oil above the unit would it not just be sucked through into the unit and out of the over flow?
  13. Andrew@A.L.D
    3,879
    617
    It's a modified catch can with a drain that goes to the breather in the haldex. The breather will be in the top of the catch can now so you have to top it up from the catch can but keep the level half way in the can
    its a very popular in Fords to increase the capacity of the diff oil in some 4x4 with little space
    ScottD3 likes this.
  14. S3 Paul
    2,825
    107
    I hope all this works but the testing could be costly?
    I would want to know the test car had been used daily and on motorways and tight parking and things like that.
    If you can cover all that in testing it will be very interesting to see how it will compair to stock and Blue controlers
  15. Andrew@A.L.D
    3,879
    617
    You don't have to run the haldex on full lock. You can adjust it back to standard.
  16. S3 Paul
    2,825
    107
    I understand that but i Love fit and forget mods.
    Maybe im lazy but with my car being a daily i want to keep it in a state where only the wheels realy need any faffing if i was to track it
  17. Andrew@A.L.D
    3,879
    617
    You want to ask someone that's done a haldex conversion on a mk1/2/3 Golf then as most people just done a manual conversion rather than all the electronics.
  18. jojo
    28,998
    3,652
    Let's get the R&D sorted with some feedback first, then once we are sure it's all good, contact one of the mods, and we should be able to assist with the group buy Andy.
  19. Andrew@A.L.D
    3,879
    617
  20. Gops
    3,198
    666
    The car being tested will be used everyday for work on the a45 at 60mph, then at work I have a carpark which is bluddy tight! Will be testing the haldex on gravel or if it snows then that's a bonus! Ill take pics and outside videos to show! I'm trying to take before and after videos to show the change but it's proving hard because I finish work so late, I can't make the video during the day!
    StaceyS3, Westy and Andrew@A.L.D like this.
  21. Andrew@A.L.D
    3,879
    617
    Sending the first one out today. You should get it by the weekend Gops
    Gops likes this.
  22. Andrew@A.L.D
    3,879
    617
    Gops got the part today people so it shouldn't be long before he can give his review
  23. chaz20vt
    chaz20vt Member
    428
    21
    That's good to hear Andrew
    Let the testing begin. .......
  24. badger5
    9,600
    2,060
    I wont be able to dyno your car gops if its permanent 4wd remember
  25. Andrew@A.L.D
    3,879
    617
  26. micky2 not 1
    micky2 not 1 Member
    59
    didnt know that....i always thought they did the full loom swap
  27. Andrew@A.L.D
    3,879
    617
    Not every conversion does the full loom swap
    You can just disable it so it runs 50/50 all the time or just a manual adjuster that replaces the haldex unit completely.
  28. Gops
    3,198
    666
    I've got it!! Will be popping it into the new haldex I have lying around waiting to be fitted! This helps with pictures as its off the car!! Here is the magic!
    Pedrosousa and Andrew@A.L.D like this.
  29. chaz20vt
    chaz20vt Member
    428
    21
    When will you be fitting gops
  30. Andrew@A.L.D
    3,879
    617
    Still after a haldex controller with a 17mm screw in insert,if anyone has on I would like to borrow it please.
    Still working on the adjustable ones and should hope to have one fitted soon.
  31. JUS3IN
    JUS3IN 14.0 @ 98mph 2s 60ft
    1,159
    102
    gops pull your finger out!-)
    cammage08 likes this.
  32. Andrew@A.L.D
    3,879
    617
    gops doesn't have it any more
    i have it and it needs a few mods
  33. JUS3IN
    1,159
    102
    ah ok, andrew pull your finger out lol....
  34. g60leigh
    g60leigh Well-Known Member
    1,674
    207
    I've just had a haldex blue fitted and makes a real nice difference. If even half as good as that they will be a real bonus. Shame one I removed was no good Andrew.
  35. Gary_808
    Gary_808 Member
    166
    Just to bump this,
    Looking at your adjustable one, does the fluid flow from the two bigger outside holes to te smaller one? And the screw/plunger is the restriction?
    If that's correct, what's to stop you fitting a plate that's tapped to take some fittings, run some -3 braided hose to a hydraulic flow valve in the boot? Easily adjustable in the boot then, obviously it'll try and siphon back, but I reckon If you mounted the catch can idea in the boot as well it'd counter act this.
  36. Andrew@A.L.D
    3,879
    617
    The screw does restrict flow
    You need to look into how the hydraulic system works in the haldex a bit more Gary
  37. Gary_808
    Gary_808 Member
    166
  38. dj_rzn
    dj_rzn Member
    82
    So, any news about this? Is it reliable?
    Really looking forward to this mod, one of the best for this car!
  39. Roadtrain
    Roadtrain Audi S3 8L 225 "BAM" from Italy :)
    224
    32
    I always think about the best mod for ours S3 8L should be a REAL 4x4: does this 50/50% mod can brake tranismission? Or is it "safe"? Thank you :)
  40. Stuart B
    Stuart B Well-Known Member
    1,940
    351
    someone on here recently installed the valve and commented he believes it has contributed to understeer. I cant find his thread.
    Roadtrain likes this.
