50/50 haldex mod
beachbuggy Jun 26, 2013
  1. Andrew@A.L.D
    3,879
    617
    Sorry bit of a mix up
    facelifts should be a cir clip ( 2000 on )
    pre facelift should be threaded insert ( 1999/2000 ish )
    you will need to get under the car to find out
  2. Dani_B19
    9,336
    391
    So ill need the threaded one then.
  3. Andrew@A.L.D
    3,879
    617
  4. phil miller
    phil miller Well-Known Member VCDS Map User
    1,211
    166
    and i need a cir clip one :)
    Great stuff andrew
  5. jojo
    28,930
    3,585
    I'd like a switchable haldex from inside the dash, on or off. Can't be hard to wire the earth wire into the dash with a rocker switch. Call it the eco switch. :)
    Westy likes this.
  6. Westy
    Westy Well-Known Member
    17,443
    1,105
    This does sound like a good idea. Like a "race mode" or "snow mode" :racer:
    m19lte likes this.
  7. daz-20vt
    daz-20vt Well-Known Member
    2,835
    583
    Would 50:50 be ok with minimul road use? Or would a switchable unit still be better?
  8. phil miller
    1,211
    166
    Im liking the sound of this, maybe use one of the spare switch houses by the ESP switch
  9. Andrew@A.L.D
    3,879
    617
    It will be a switch altering the hydraulic pressure to the haldex clutch
  10. Gops
    3,198
    666
    Nice! :)
  11. phil miller
    1,211
    166
    Andrew any idea on price's yet?
  12. Andrew@A.L.D
    3,879
    617
  13. Gops
    3,198
    666
    Lets see what happens with this one first.. Jo, if you take your old haldex off, can I nick the wire? Saves me snipping my wire off again lol
  14. Andrew@A.L.D
    3,879
    617
    I've come up with a new idea that's like the YHW insert and will be much cheaper to make
    will be as cheap as £30 inc p&p the modified versions with a switch will be much more.
    jojo likes this.
  15. Westy
    17,443
    1,105
    Looking forward to some test results. Might even be able to get a decent 4wd dyno graph with 50/50 haldex.
  16. Sam_
    Sam_ Down under
    3,038
    480
    Nah, not if it's still electronically controlled. I've got the blue (so 50/50) and it still has a hissy fit on the dyno.
    This will be a nice cheaper alternative to the blue/orange controllers. Just hope it doesn't bind up at low speed like the orange or the insert.
  17. Andrew@A.L.D
    3,879
    617
  18. chaz20vt
    chaz20vt Member
    428
    21
    When will this be ready and tested then Andrew
    Believe i need the threaded type
  19. Westy
    17,443
    1,105
    Let's give Andrew a chance! This was only an idea till a few weeks ago and we've not even seen any test results. This could chew up a rear diff in 100 miles for all we know.
    Lets just sit back and wait for updates ;)
  20. Andrew@A.L.D
    3,879
    617
  21. Andrew@A.L.D
    3,879
    617
    50/50 isn't good for are cars for everyday use, race and drag really
    i do plan to make a simple mode that gives 70/30 split to save the diff and to make it better to drive at low speed
    also looking into a simple under car adjuster one
  22. Jason.s
    Jason.s Active Member
    2,879
    348
    Anything more for everyday use and there will be rear diffs sh!tting themselves all over the country. 60/40 at a push or 70/30 would be the winner i think.
  23. Andrew@A.L.D
    3,879
    617
    I can make my own sort of insert as a kit that gives you a option of 50/50, 60/40, 70/30
    Jason.s likes this.
  24. Westy
    17,443
    1,105
    Or pull the haldex fuse for FWD A3 mode....
    Sam_ likes this.
  25. Andrew@A.L.D
    3,879
    617
    good for burn outs to get heat into the tyres for 1/4 miles
    Westy likes this.
  26. Sam_
    Sam_ Down under
    3,038
    480
    So it's going to be locked at a ratio and no longer controlled?
  27. Sam_
    Sam_ Down under
    3,038
    480
    "Slayer" mode
    jojo and Westy like this.
  28. Andrew@A.L.D
    3,879
    617
    it will still be controlled but it will run at say 70/30 then you will floor it and the haldex will take over giving you 50/50 then return back to 70/30
    its a simple system hydraulic system with complicated electronics
  29. chaz20vt
    chaz20vt Member
    428
    21
    This sounds good to me
  30. boost-addict
    boost-addict Well-Known Member
    1,000
    39
    Typically german built!!
    All sounds interesting. Don't suppose a4 have this kind of adjustment?
  31. Jason.s
    2,879
    348
    A4 quattros dont have haldex..They have full time 4wd and a center diff.
  32. TDIQ
    TDIQ 8L > 8P > 8V
    777
    Very very interesting stuff. So the insert will give a 70/30 split and when the haldex would usually engage there'll be a 50/50 split? If so I'm definitely interested in purchasing one when available!!
  33. superkarl
    superkarl MAN OF STEEL
    9,553
    2,452
    Be interesting if 60/40 gives enough slip for cornering in the remaining 10%
  34. phil miller
    1,211
    166
    still very very interested in this, and as soon as its ready i will have one for sure
  35. jojo
    28,930
    3,585
    Unfortunately not Gops, I'm 90% sure it's a connector problem on my car(no comms on VCDS), and I want to keep the standard one as spare if the performance one decides to die on me.
  36. daz-20vt
    2,835
    583
    At the risk of looking thick. Ive never understood how you can split power say 70:30 . How does it work? How are the rears doing anything if the frontw have more power to them. Probably obvious but id love to understand this. Also persumably if you went for a 50:50 insert the haldex would lose any control? Thanks guys, daz
  37. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,825
    107
    Jojo... What issues do you have ?
  38. Scullies
    Scullies Well-Known Member
    1,543
    658
    Does anyone know what's going to happen to the haldex when its at 70/30 and you doing 140km/h.
    I read the OEM setup turns off after 100km/h.
  39. rhys1210
    rhys1210 Active Member Team Meteor Team V8 VCDS Map User Audi S5 quattro
    176
    25
    Surely if you have a 70:30 split this is causing the clutch plates in the haldex to continually slip, surely this will cause more wear?
  40. Andrew@A.L.D
    3,879
    617
    SQS Racing sell these that get rid of the controller completely and can be fine adjusted from 50/50 down to 100/0
    SQS Racing | Haldex Regulator
    I sure they would mention the problems of having it set on full down to 70/30 etc
    How to people go about the Haldex when fitting them into Mk1/2 Golfs and other car?
    I know you can over heat the Haldex pump if you run them constantly for long periods of time, Keeping the Haldex oil cool is a good start when doing this
