50/50 haldex mod
beachbuggy Jun 26, 2013
  1. beachbuggy
    beachbuggy Well-Known Member
    1,931
    201
    Roadtrain likes this.
  2. <tuffty/>
    20,847
    3,687
    No centre diff will be an issue... haldex is designed to 'slip' to counter this (unless in a straight line of course)
    All it essentially does is lock the valve in the position where the haldex clutch is fully engaged... not sure but suspect the various control modules may have something to complain about... lol
    Not something I would want to use on the road as a daily tbh
  3. badger5
    9,373
    1,915
    straight lines only need apply
  4. [Dave B]
    [Dave B] Daddy
    2,027
    145
    I had this mod for a while without the use of a bolt....the haldex earth strap had snapped :ninja:
  5. Paradox1
    Paradox1 Active Member
    1,833
    88
    couldnt you just fit a 17mm bolt for less than £120+
  6. Scullies
    Scullies Well-Known Member
    1,543
    657
    Depending on the length of the pin at the end of the bolt, this mod actually might work in conjunction with the haldex electronics.
    My understanding is that the new bolt is going to relocate the valve a little deeper inside the oil gallery. This would cause the oil gallery to be closed off completely when the stepper motor moves the valve, giving you 50/50. On the other hand, I don't think the haldex will completely disengage as the valve would be restricting the oil flow. So you could be using anything from a 99/1 split to a 51/49 split when cruising.
    If the bolt is very long and keeps the haldex 50/50 at all times, then you can say bye bye haldex :crying:
  7. jezzy
    jezzy Member
    768
    50/50 constant.
    think the clutch in the haldex would wear super fast and i bet they aint cheap to replace
  8. Andrew@A.L.D
    3,872
    609
    Give me a old Haldex controller and i'm 100% sure i could make a adjustable one rather than a bolt like that for the same price as the above one
    Pedrosousa likes this.
  9. Dani_B19
    9,047
    337
    Anybody got a spare one for andrew?
  10. Andrew@A.L.D
    3,872
    609
    I know i can do it
    I'm sure someone has a damaged haldex
  11. superkarl
    superkarl MAN OF STEEL It's my birthday
    9,369
    2,367
    Ive got a spare you can use andrew.
    You can have it for experimentation
    Dani_B19 likes this.
  12. Andrew@A.L.D
    3,872
    609
    Empty your inbox superkarl so i can send you details
  13. Scullies
    1,543
    657
    What's your approach to this Andrew? Same bolt style as advertised but adjustable or control the haldex ecu with a controller inside the car?
  14. Andrew@A.L.D
    3,872
    609
    Thats it
  15. Westy
    Westy Well-Known Member
    17,442
    1,100
    Ooo interesting stuff.
  16. Scullies
    1,543
    657
  17. Dani_B19
    9,047
    337
    Ooh I like this. Andrew I thought your mate was developing one for you?
  18. Andrew@A.L.D
    3,872
    609
    He still is but his is like a piggy back ECU with a LED monitor showing the split
  19. Westy
    17,442
    1,100
    Would love one with an adjustable bias wheel on the dash.
  20. superkarl
    9,369
    2,367
    Inbox cleared.
    Are You saying it will be adjustable from stock to permanant 50/50? So when in stock mode it will do its own thing??
    Or a case of 100/0 to 50/50 fixed?
  21. Andrew@A.L.D
    3,872
    609
  22. superkarl
    9,369
    2,367
    :thumbsup: the SQS one is the one that gets most of my interest, so thats good!
    Sounds like your mate is trying to recreate what the monster performance s3 has, the bulgarian car, gtx42 etc...
  23. Andrew@A.L.D
    3,872
    609
  24. Jason.s
    Jason.s Active Member
    2,879
    348
    I've also got a spare from an R32 with only 40k on it that I was saving incase mine went pop.
  25. rhys1210
    rhys1210 Member Team Meteor Team V8 VCDS Map User Audi S5 quattro
    163
    23
    i just see that bolt damaging the standard controller.
    I brought the race controller (not the competition/blue)which is 50/50 all the time from the tt shop, this comes from haldex/borgwarner them selves, and i believe they uprate the piston in the controller as well as the software, for the higher pressure.
    just my 2p.
  26. TTazRS
    TTazRS New Member
    Any updates on this? I am very interested.
  27. Andrew@A.L.D
    3,872
    609
    I'm just waiting for someone to give me a busted Haldex
  28. superkarl
    9,369
    2,367
    Ive simply not had the time to get under the rear of the car to take mine off to give to andrew. Will do it as part of a fluid change.
    Getting the engine sorted has just been more of a priority with the little time i have.
    Andrew@A.L.D and Westy like this.
  29. jojo
    28,831
    3,485
    I wonder if Gops still has a broken one?
    Andrew@A.L.D likes this.
  30. s3gazz
    s3gazz Well-Known Member
    1,376
    99
    S3dave might be able to help with this shore he had a spare nocking about
  31. Andrew@A.L.D
    3,872
    609
  32. s3gazz
    1,376
    99
    Cool u think this will be a werth wile mod then
  33. Andrew@A.L.D
    3,872
    609
    Dave doesn't have one
    for sure it will be worth it, i think the haldex controller is worth it with high power s3
  34. Gops
    3,193
    662
    I still have the broken one in my garage Andrew! Ill have to dig it out but I'm pretty sure it's there if you want it?
  35. Andrew@A.L.D
    3,872
    609
    Please Gops
    as as soon as you get it please pm me
    Gops likes this.
  36. jojo
    28,831
    3,485
    You will be the fourth member on here to have owned this particular controller! lol
    s3dave and Westy like this.
  37. s3gazz
    1,376
    99
    Ill have your blue haldex then Andrew lol
  38. Jason.s
    2,879
    348
    I still have a controller in the garage that's only had 30/40k put on it. Was only taken off due to controller upgrade and given to me for nothing.
  39. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    Ive got a TT one on a rear diff unit i bought...
    Jason i would say save the one you have pal.
  40. jojo
    28,831
    3,485
    My Haldex controller just broke! :sob:
