5 cylinder in a b5?
ian52 Oct 28, 2008
  1. ian52
    ian52 2000 a4 1.8tqs-yellow
    1,199
    has an engine from an s2 ever been put in a b5 a4?
  2. Siena
    Siena Active Member
    2,626
    I did consider that option, between my b2,7 biturbo and S8 motor, but the length makes it a not too attractive option.
    It's longer than a V8.
  3. jcb
    jcb Active Member
    4,132
    13
    it is also hewn from a solid block of extra heavy cast iron!!!
    I had a 90 Quattro and my god are they nose heavy!!
    even the 20v doesn't tune up as well as the much more advanced 2.7 V6 or 1.8t
    they are pretty bulletproof internals but a pain to work on
  4. Siena
    Siena Active Member
    2,626
    I wouldn't compare the I5 20V (7A) with the 1,8 / 2,7 turbo motors.
    Now the I5 20V turbo motors (RR, 3B, AAN, ABY and ADU) are more than comparable with the later 1,8 / 2,7 turbo versions.
  5. INA
    INA http://www.inaengineering.com
    72
    Yes but it was a track only vehicle and IMHO was not the smartest combination.
    If I were you I would find a VR5 from a B5.5 Passat and transplant that in.There are MANY options available for this motor stateside and the combination would be perfect.It might actually be in the next project car :D
  6. Siena
    Siena Active Member
    2,626
    Hi bro, I guessed it was you!
    Welcome aboard.
  7. Siena
    Siena Active Member
    2,626
    Yes, the V5 will be a direct bolt-in replacement.
    Will need to be boosted though, as it doesn't make loads of power as standard, or respond favourably to conventional tuning methods.
  8. INA
    72
    Its a boat anchor in stock form but nothing we do in stock anyway :D
  9. jcb
    jcb Active Member
    4,132
    13
    like it, think I will steal that description!
