  1. jay22s3
    jay22s3 2nd gear sorts em out
    195
    i know these cars say they are 4wd but which wheels actually drive the car the most as i put some new tyres on my car the front ones just before christmas and the rears in january and the rears are on the markers allready on the inside not sure if the cars got a fast road set up but im a bit pissed they need changing allready. could the four wheel allingment be out ? any advice please
  2. ShaunS3
    ShaunS3 Yorkshire & Humber Rep. Regional Rep VCDS Map User
    1,164
    214
    The S3 is predominantly a FWD car until it senses that there is too much power in the front wheels and begins to lose grip. The Haldex unit then kicks in and transfers a proportion of the power to the back wheels, making it 4WD. The S3 is not a permanent 4WD.
    That's the easiest/simplest way to explain it.
  3. jay22s3
    195
    that answers part of my question then so is my allingment out ?
  4. ShaunS3
    1,164
    214
    Without seeing images of the tyre wear, I cannot comment on your alignment. However, if you have only replaced the front tyres recently, the rear ones will obviously reach their wear limit sooner. It would also be a good idea to let us know of your driving style as this may also affect your tyre wear.
  5. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Also is it lowered? you may need adjustable tie arms to combat the camber..
    slowcoach3 likes this.
  6. jay22s3
    195
    the rears where only renewed in januaray and the fronts before that and as i say the rears have worn out allready im not a boy racer but do like to give it some now and then whats the point of having one of these cars if you dont enjoy it :)
  7. russwuss
    russwuss Active Member
    546
    101
    43
    Is your car lowered? Sometimes when lowering the S3 it can cause negative camber... Which would cause wear on the inside iirc. There's no adjustment on the rears, unless you buy adjustable tie bars.
  8. russwuss
    546
    101
    43
    sorry dave, you beat me to it :)
  9. jay22s3
    195
    yes its on 30mm lowering springs
  10. ShaunS3
    1,164
    214
    Is it wearing on the inside edges of the tyres?
  11. jay22s3
    195
    cheers for the info guys
  12. jay22s3
    195
    yes it is
  13. ShaunS3
    1,164
    214
    In that case, camber will most likely be out causing uneven wear to the inside edge of the tyres.
    As stated above, you will need some adjustable rear tie bars to combat this, which will obviously need to be set up on an alignment system to bring back within tolerance. You may aswell go for a full 4 wheel alignment and make sure both front and rear are spot on.
  14. jay22s3
    195
    where can i get some adjustable tie bars from ?
  15. ShaunS3
    1,164
    214
    s3dave ;)
