4dr MKV coilovers fit A3?
~RS~ Jan 6, 2011
  1. ~RS~
    ~RS~ Active Member
    1,466
    22
    Been offered a set of coils 55mm strut same as my A3's, but they're off a MKV golf TDi - kerb weights are within similar, also I know certain springs are listed as being compatible with a few VAG cars too. I've been told that they will fit but just wanted a second opinion on whether there will be any issues... Most other bits are transferable between the VAG range so maybe he's right??
    Any help guys?
  2. martinivw
    martinivw :)
    442
    24
    Will fit ok, I used to have h&r cup kit from a mkv golf fitted to my sportback with NO probs
  3. ~RS~
    ~RS~ Active Member
    1,466
    22
    Cheers mate, that post might have saved me a few hundred £ :)
  4. jungleman
    jungleman Well-Known Member
    2,035
    42
    they should be fine as long as they are both FWD, dont think there is a difference between 3&5 door, could always be worth pm'ing damien at DPM, hes been really helpful with stuff like this before
  5. martinivw
    martinivw :)
    442
    24
    Double check that spring loads are the same as I think DSG boxes might be heavier than a manual!!!!!!!!
    PM sent
  6. Lee_R
    Lee_R Active Member
    2,499
    12
    I looked into this and yes TDI+DSG = one heavy front end! Defo worth considering as most of the good manufacturers list different rates for just spring kits between petrol/TDI. The cheaper ones dont so whether its a major issue or not is anyones guess!
  7. N8
    17,163
    718
    Yes it needs to be either manual/DSG specific.
