4 wheel alignment Birmingham or Manchester area
bantam1 Feb 26, 2008
  1. bantam1
    bantam1 Member
    529
    As per topic need 4 wheel alignment asap in either Birmingham or Manchester area (live in Birmingham but up in Manchester fri through sun).
    Have tried awesome and they can't fit me in. Any other reliable options for an alignment on a lowered S3 that I might try?
    Cheers in advance.
  2. Aky
    Aky Aky
    1,512
    Now then Bantam - Haven't seen you floating around here for a while.
    I know it might be a tad more expensive, but as a last resort how about using a stealer?
    Rotherham at home tonight!
  3. bantam1
    bantam1 Member
    529
    Have lurked occasionally but not been here as often as I used to. Just do not trust the stealers with my car unfortunately so can't bring myself to do that. It will be nice and clean but the wheels will be at right angles no doubt.
    Is your mate still trotting out for the mighty bantams? They keep stuttering on and off this season. Need an almighty run to make the play offs.
    There must be somewhere in greater manchester / birmingham that can make my S3 feel right again.
  4. S3 Dave
    S3 Dave Now running on Heavy Oil
    432
    Midland VW!??. Birmingham Audi?? The stealer's kit is the dogs for alignment just cost you a bit of arm and a slither of leg.
  5. Nilz
    11,329
    876
    Im sure Lodge tyres in Nechells do it, they are just opposite Fletchers, if you know where that is....in Brum by the way.
  6. adcooper
    adcooper Audi A6 C6 Avant 3.0tdi Le Mans S-Line
    319
    9
    Chemix in Halesown did mine for me
  7. jim s3
    jim s3 Member
    321
    yep chemix did mine to but in stourbridge as halesowen couldnt get my car on the ramp. stourbridge have a flat ramp built into the ground.
  8. 20valver
    20valver New Member
    24
    I'd recommend Awesome GTI in Manchester, they've done mine recently and have all the gear a dealer would have.
  9. bantam1
    bantam1 Member
    529
    Just an update in case anyone needs the same in this area. Had it done at Chemix in stourbridge. Great service, spent loads of time going through the readings and options for set up, cheap (£58) and the car feels great again. Highly recommended.
