4 to 3 spoke steering wheel
tonya4 Oct 5, 2011
  1. tonya4
    tonya4 TDi Powerrrr
    408
    does anyone know how to swap a 4 spoke to a 3 spoke steering wheel?Its the right wheel for my age car.Is it plug n play?Also,is anyone going to adi that could help,if I bring some tools?
    thanks in advance
    tony
  2. rasA4
    rasA4 Four Rings Mafia Specialist Team V6 Audi A4 saloon
    3,287
    119
  3. tonya4
    tonya4 TDi Powerrrr
    408
    my car is a 2000 facelift,the 3 spoke wheel I haven't seen yet,but is for a 98 on,am picking it up from olds_kool at adi.So all I should need is a torx bit for the airbag,and a big torx for the wheel then?
    thanks
    tony
  4. rasA4
    3,287
    119
    yep
  5. tonya4
    tonya4 TDi Powerrrr
    408
    great,thanks mate
    tony
  6. rasA4
    3,287
    119
    np see you at ADI iirc the large torx for main bolt is a M12 torx
  7. aragorn
    18,485
    855
    Its M12 ZXN not torx.
  8. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    assuming the wheel you get has an airbag fitted then you are fine.
    be careful buying airbags to fit to wheels as some of them have different horn ring contacts.
    I bought an alcantara wheel without a horn ring and had to buy a TT wheel and strip the ring out as it was different to the one that is the stock item
    still easy, just make sure you remove the ignition keys as a precaution when removing the bag.
    I have taken mine off many times and never once removed the battery as suggested
