4 cylinder 20V engines - why no more???
C_Audiboy Jan 15, 2007
  1. C_Audiboy
    C_Audiboy Vroom Vroom
    822
    I was just wondering why Audi (VAG more to the point) seem to have dropped the 5V per cylinder configuration on the new 4 cylinder engines?
    I'd have assumed that it was 5V for a good technical reason and I assumed it to be an improvement over 4v per cyl. But we are now back to 4V per cylinder in the new 16V FSI units.
    Anyone know the reasons behind this?
    I don't claim to know **** about how engines work....... I'm just curious!!!
    :beerchug:
  2. icenutter
    icenutter Member
    596
    They probably found that the benefits didn't outweigh the costs (weight and money). You can get away with any old rubbish if you are turbocharging an engine ;)
  3. smitch
    smitch Active Member
    1,588
    Dunno, but i used to have a 90 20V which was 5 cylinder with 4 valves per cylinder and wondered why they went to 4 cylinder with 5 valves per cylinder!?!?!?! :think:
  4. Ess_Three
    Ess_Three Active Member
    5,383
    I seem to recall that in order to get the FSI injector into the head, there wasn't room for all 5 valves...so they reverted to 4 valve heads, plus a direct injector and a central single spark plug.
    At least I think that's the reason...
    BYW...this 5 valves are better than 4 is bullshit anyway...on a road engine with properly designed heads, there is no reason why a 5v flows more than a 4v...so don't go looking at it as a backward step, 'cos it isn't.
  5. Beerzo
    Beerzo Masa'warty 3200... Talk To Me!
    1,242
    Yup plus the valves maybe bigger now, so they may not have needed the 5.
  6. Ess_Three
    5,383
    The inlet valves will be larger...they were pretty small on the 5v heads.
  7. Caesium
    Caesium My BM is fixed! VCDS Map User
    4,879
    5 valves per head is no better than 4 if the 4 are designed properly. The use of turbos on a lot of cars now also negates the need for the extra valve.
    Also the extra engineering needed has clearly been dropped as it offers no more in the way of performance or economy.
  8. joost
    joost Active Member
    1,169
    And there's me thinking there might have been a shortage of valves...
