4 bar fuel pressure regulator
djdougalno1 Oct 15, 2009
  1. djdougalno1
    djdougalno1 Member
    189
    dose the s3 come with a 4 bar fule presure reg as standard
  2. Dani_B19
    9,109
    346
    No 3 bar.
  3. Broken Byzan
    13,237
    465
    A4 1.8t's were 4 bar
  4. djdougalno1
    djdougalno1 Member
    189
    so will any 4 bar pressure reg fit or dose it have to be a vag one
  5. MintyS3
    MintyS3 Works 60% the time, Everytime.
    1,580
    Doesnt need to be fitted to an S3 with a k04 if your thinking about it.
    I would of thought a fpr is an fpr...
  6. Broken Byzan
    13,237
    465
    I am sure that as long as they bosch units then all good, but they are all different pressures so be aware of that. 4 bar from Audi A4s and Passats from 1995 to 2001 ish
  7. marcyp
    marcyp Only me
    126
    im sure the fuel reg on my qts is a 4bar :think:
  8. S3 Paul
    S3 Paul Well-Known Member Regional Rep
    2,823
    107
    I fitted a mk3 golf vr6 reg. its 4 bar and not too expensive.
  9. mattyboy199
    mattyboy199 Well-Known Member
    1,885
    will it do anything though going 4bar ?
  10. Broken Byzan
    13,237
    465
    Not unless your tune calls for it !
    No benefit just sticking one in randomly
  11. Ess_Three
    Ess_Three Active Member
    5,383
    14
    As Mark says...not unless your map needs it.
    I tested adding one when at the Dyno with my S3 and lost power due to running too rich.
  12. djdougalno1
    djdougalno1 Member
    189
    amd technik are goin to build a custom map when all the upgrades are done an they say it will need a 4 bar reg
  13. ceS3r
    ceS3r Member
    95
    I'm thinking of getting an mbc +diode mode.. But, I read that if I'm gonna add some psi I should fit a 4 bar fpr. Car is a S3 8L BAM. Does it comes with 3 bar or 4 bar?
  14. Scullies
    Scullies Well-Known Member
    1,543
    657
  15. Andrew@A.L.D
    3,873
    609
    Don't do it, none of it
  16. badger5
    9,401
    1,944
    bad idea
    get it mapped properly dont be so pikey unless you dont care about risking your engine
