3rd Gear logs for Chaz20vt - Limp Mode
Alex C Sep 21, 2012
  1. Alex C
    Alex C Well-Known Member VCDS Map User Audi S3
    3,267
    360
    I've just been out logging a mapped (think MTM) for chaz20vt
    As far as i am aware it is a stage 1 map with a FMIC and a DV (full recirc)
    The complaint was that the car was accelerating and then felt flat/limp. The logs below show the requested boost dropping back after ~3500rpm correlating with timing pull that starts on cylinder #2 (8.3!) and then all 4 cylinders are being pulled
    What is likely to be causing these issues for him? What else should be logged?
    There was one fault code on the car:
    16795 - Secondary Air Injection System
    P0411 - 35-10 - Incorrect Flow Detected - Intermittent
    Thanks in advance for help/advice
    1st Log
    Code:
    [TABLE="width: 715"]
    [TR]
    [TD]Group A:[/TD]
    [TD]'003[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group B:[/TD]
    [TD]'115[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group C:[/TD]
    [TD]'031[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]Engine
    Speed[/TD]
    [TD]Mass
    Air
    Flow[/TD]
    [TD]Throttle
    Valve
    Angle[/TD]
    [TD]Ignition[/TD]
    [TD][/TD]
    [TD]Engine
    Speed[/TD]
    [TD]Engine
    Load[/TD]
    [TD]Boost
    Pressure[/TD]
    [TD]Boost
    Pressure[/TD]
    [TD][/TD]
    [TD]Lambda
    Control[/TD]
    [/TR]
    [TR]
    [TD]TIME[/TD]
    [TD](G28)[/TD]
    [TD]Sensor (G70)[/TD]
    [TD][/TD]
    [TD]Timing
    Angle[/TD]
    [TD]TIME[/TD]
    [TD](G28)[/TD]
    [TD][/TD]
    [TD](specified)[/TD]
    [TD](actual)[/TD]
    [TD]TIME[/TD]
    [TD]Bank 1
    (actual)[/TD]
    [/TR]
    [TR]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD] g/s[/TD]
    [TD] %[/TD]
    [TD] °BTDC[/TD]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD] %[/TD]
    [TD] mbar[/TD]
    [TD] mbar[/TD]
    [TD]STAMP[/TD]
    [TD] V[/TD]
    [/TR]
    [TR]
    [TD="align: right"]0.3[/TD]
    [TD="align: right"]840[/TD]
    [TD="align: right"]2.97[/TD]
    [TD="align: right"]1.6[/TD]
    [TD="align: right"]5.3[/TD]
    [TD="align: right"]0.6[/TD]
    [TD="align: right"]19.5[/TD]
    [TD="align: right"]990[/TD]
    [TD="align: right"]1010[/TD]
    [TD="align: right"]0[/TD]
    [TD="align: right"]0.21[/TD]
    [/TR]
    [TR]
    [TD="align: right"]1.2[/TD]
    [TD="align: right"]3.06[/TD]
    [TD="align: right"]3[/TD]
    [TD="align: right"]1.5[/TD]
    [TD="align: right"]0.9[/TD]
    [TD="align: right"]0.485[/TD]
    [/TR]
    [TR]
    [TD="align: right"]2.1[/TD]
    [TD="align: right"]4.5[/TD]
    [TD="align: right"]2.4[/TD]
    [TD="align: right"]1.8[/TD]
    [TD="align: right"]0.685[/TD]
    [/TR]
    [TR]
    [TD="align: right"]3.3[/TD]
    [TD="align: right"]2.7[/TD]
    [TD="align: right"]0.08[/TD]
    [/TR]
    [TR]
    [TD="align: right"]3.9[/TD]
    [TD="align: right"]3.03[/TD]
    [TD="align: right"]4.2[/TD]
    [TD="align: right"]3.6[/TD]
    [TD="align: right"]0.71[/TD]
    [/TR]
    [TR]
    [TD="align: right"]4.8[/TD]
    [TD="align: right"]5.1[/TD]
    [TD="align: right"]0.09[/TD]
    [/TR]
    [TR]
    [TD="align: right"]5.7[/TD]
    [TD="align: right"]6[/TD]
    [TD="align: right"]5.4[/TD]
    [/TR]
    [TR]
    [TD="align: right"]6.6[/TD]
    [TD="align: right"]6.9[/TD]
    [TD="align: right"]6.3[/TD]
    [TD="align: right"]0.085[/TD]
    [/TR]
    [TR]
    [TD="align: right"]7.5[/TD]
    [TD="align: right"]7.8[/TD]
    [TD="align: right"]7.2[/TD]
    [TD="align: right"]0.12[/TD]
    [/TR]
    [TR]
    [TD="align: right"]8.39[/TD]
    [TD="align: right"]2.94[/TD]
    [TD="align: right"]8.69[/TD]
    [TD="align: right"]18.8[/TD]
    [TD="align: right"]8.1[/TD]
    [TD="align: right"]0.705[/TD]
    [/TR]
    [TR]
    [TD="align: right"]9.29[/TD]
    [TD="align: right"]9.59[/TD]
    [TD="align: right"]8.99[/TD]
    [TD="align: right"]0.075[/TD]
    [/TR]
    [TR]
    [TD="align: right"]10.19[/TD]
    [TD="align: right"]2.3[/TD]
    [TD="align: right"]10.49[/TD]
    [TD="align: right"]9.89[/TD]
    [TD="align: right"]0.67[/TD]
    [/TR]
    [TR]
    [TD="align: right"]11.09[/TD]
    [TD="align: right"]2.86[/TD]
    [TD="align: right"]11.39[/TD]
    [TD="align: right"]10.79[/TD]
    [TD="align: right"]0.675[/TD]
    [/TR]
    [TR]
    [TD="align: right"]11.99[/TD]
    [TD="align: right"]12.29[/TD]
    [TD="align: right"]11.69[/TD]
    [/TR]
    [TR]
    [TD="align: right"]12.89[/TD]
    [TD="align: right"]13.19[/TD]
    [TD="align: right"]12.59[/TD]
    [TD="align: right"]0.715[/TD]
    [/TR]
    [TR]
    [TD="align: right"]13.79[/TD]
    [TD="align: right"]2.83[/TD]
    [TD="align: right"]14.09[/TD]
    [TD="align: right"]13.49[/TD]
    [/TR]
    [TR]
    [TD="align: right"]14.69[/TD]
    [TD="align: right"]2.81[/TD]
    [TD="align: right"]14.99[/TD]
    [TD="align: right"]18[/TD]
    [TD="align: right"]14.39[/TD]
    [TD="align: right"]0.1[/TD]
    [/TR]
    [TR]
    [TD="align: right"]15.59[/TD]
    [TD="align: right"]2.56[/TD]
    [TD="align: right"]10.5[/TD]
    [TD="align: right"]15.89[/TD]
    [TD="align: right"]15.29[/TD]
    [/TR]
    [TR]
    [TD="align: right"]16.49[/TD]
    [TD="align: right"]16.79[/TD]
    [TD="align: right"]16.19[/TD]
    [TD="align: right"]0.065[/TD]
    [/TR]
    [TR]
    [TD="align: right"]17.39[/TD]
    [TD="align: right"]17.69[/TD]
    [TD="align: right"]17.09[/TD]
    [/TR]
    [TR]
    [TD="align: right"]18.29[/TD]
    [TD="align: right"]3.8[/TD]
    [TD="align: right"]18.59[/TD]
    [TD="align: right"]17.99[/TD]
    [TD="align: right"]0.7[/TD]
    [/TR]
    [TR]
    [TD="align: right"]19.19[/TD]
    [TD="align: right"]2.89[/TD]
    [TD="align: right"]0.8[/TD]
    [TD="align: right"]19.49[/TD]
    [TD="align: right"]18.89[/TD]
    [/TR]
    [TR]
    [TD="align: right"]20.09[/TD]
    [TD="align: right"]920[/TD]
    [TD="align: right"]4.86[/TD]
    [TD="align: right"]3.5[/TD]
    [TD="align: right"]21[/TD]
    [TD="align: right"]20.39[/TD]
    [TD="align: right"]1160[/TD]
    [TD="align: right"]26.3[/TD]
    [TD="align: right"]19.79[/TD]
    [/TR]
    [TR]
    [TD="align: right"]20.99[/TD]
    [TD="align: right"]1200[/TD]
    [TD="align: right"]3.11[/TD]
    [TD="align: right"]2[/TD]
    [TD="align: right"]27[/TD]
    [TD="align: right"]21.29[/TD]
    [TD="align: right"]14.3[/TD]
    [TD="align: right"]20.69[/TD]
    [TD="align: right"]0.74[/TD]
    [/TR]
    [TR]
    [TD="align: right"]21.89[/TD]
    [TD="align: right"]9[/TD]
    [TD="align: right"]22.19[/TD]
    [TD="align: right"]16.5[/TD]
    [TD="align: right"]21.59[/TD]
    [TD="align: right"]0.055[/TD]
    [/TR]
    [TR]
    [TD="align: right"]22.79[/TD]
    [TD="align: right"]2.92[/TD]
    [TD="align: right"]23.09[/TD]
    [TD="align: right"]22.49[/TD]
    [TD="align: right"]0.06[/TD]
    [/TR]
    [TR]
    [TD="align: right"]23.69[/TD]
    [TD="align: right"]23.99[/TD]
    [TD="align: right"]23.39[/TD]
    [TD="align: right"]0.785[/TD]
    [/TR]
    [TR]
    [TD="align: right"]24.59[/TD]
    [TD="align: right"]24.89[/TD]
    [TD="align: right"]24.29[/TD]
    [/TR]
    [TR]
    [TD="align: right"]25.49[/TD]
    [TD="align: right"]5.5[/TD]
    [TD="align: right"]4.3[/TD]
    [TD="align: right"]21.8[/TD]
    [TD="align: right"]25.79[/TD]
    [TD="align: right"]30.1[/TD]
    [TD="align: right"]25.19[/TD]
    [TD="align: right"]0.095[/TD]
    [/TR]
    [TR]
    [TD="align: right"]26.39[/TD]
    [TD="align: right"]1920[/TD]
    [TD="align: right"]13.28[/TD]
    [TD="align: right"]8.6[/TD]
    [TD="align: right"]29.3[/TD]
    [TD="align: right"]26.69[/TD]
    [TD="align: right"]1840[/TD]
    [TD="align: right"]36.8[/TD]
    [TD="align: right"]26.09[/TD]
    [TD="align: right"]0.81[/TD]
    [/TR]
    [TR]
    [TD="align: right"]27.29[/TD]
    [TD="align: right"]1440[/TD]
    [TD="align: right"]10.56[/TD]
    [TD="align: right"]7.1[/TD]
    [TD="align: right"]27.59[/TD]
    [TD="align: right"]1280[/TD]
    [TD="align: right"]40.6[/TD]
    [TD="align: right"]1020[/TD]
    [TD="align: right"]26.99[/TD]
    [TD="align: right"]0.69[/TD]
    [/TR]
    [TR]
    [TD="align: right"]28.18[/TD]
    [TD="align: right"]1000[/TD]
    [TD="align: right"]24[/TD]
    [TD="align: right"]28.48[/TD]
    [TD="align: right"]42.9[/TD]
    [TD="align: right"]27.88[/TD]
    [TD="align: right"]0.75[/TD]
    [/TR]
    [TR]
    [TD="align: right"]29.08[/TD]
    [TD="align: right"]11.72[/TD]
    [TD="align: right"]8.2[/TD]
    [TD="align: right"]25.5[/TD]
    [TD="align: right"]29.38[/TD]
    [TD="align: right"]1560[/TD]
    [TD="align: right"]28.78[/TD]
    [/TR]
    [TR]
    [TD="align: right"]29.98[/TD]
    [TD="align: right"]1880[/TD]
    [TD="align: right"]10.6[/TD]
    [TD="align: right"]27.8[/TD]
    [TD="align: right"]30.28[/TD]
    [TD="align: right"]2040[/TD]
    [TD="align: right"]46.6[/TD]
    [TD="align: right"]1030[/TD]
    [TD="align: right"]29.68[/TD]
    [TD="align: right"]0.125[/TD]
    [/TR]
    [TR]
    [TD="align: right"]30.88[/TD]
    [TD="align: right"]2400[/TD]
    [TD="align: right"]23.61[/TD]
    [TD="align: right"]14.5[/TD]
    [TD="align: right"]31.18[/TD]
    [TD="align: right"]2600[/TD]
    [TD="align: right"]52.6[/TD]
    [TD="align: right"]1060[/TD]
    [TD="align: right"]30.58[/TD]
    [TD="align: right"]0.695[/TD]
    [/TR]
    [TR]
    [TD="align: right"]31.78[/TD]
    [TD="align: right"]3000[/TD]
    [TD="align: right"]31.86[/TD]
    [TD="align: right"]17.6[/TD]
    [TD="align: right"]32.08[/TD]
    [TD="align: right"]2960[/TD]
    [TD="align: right"]31.48[/TD]
    [/TR]
    [TR]
    [TD="align: right"]32.68[/TD]
    [TD="align: right"]2360[/TD]
    [TD="align: right"]4.44[/TD]
    [TD="align: right"]9.8[/TD]
    [TD="align: right"]32.98[/TD]
    [TD="align: right"]2120[/TD]
    [TD="align: right"]1050[/TD]
    [TD="align: right"]32.38[/TD]
    [TD="align: right"]0.04[/TD]
    [/TR]
    [TR]
    [TD="align: right"]33.58[/TD]
    [TD="align: right"]1400[/TD]
    [TD="align: right"]11.28[/TD]
    [TD="align: right"]24.8[/TD]
    [TD="align: right"]33.88[/TD]
    [TD="align: right"]1320[/TD]
    [TD="align: right"]33.28[/TD]
    [/TR]
    [TR]
    [TD="align: right"]34.48[/TD]
    [TD="align: right"]65.5[/TD]
    [TD="align: right"]34.78[/TD]
    [TD="align: right"]1520[/TD]
    [TD="align: right"]80.5[/TD]
    [TD="align: right"]34.18[/TD]
    [TD="align: right"]0.835[/TD]
    [/TR]
    [TR]
    [TD="align: right"]35.38[/TD]
    [TD="align: right"]1680[/TD]
    [TD="align: right"]28.56[/TD]
    [TD="align: right"]76.5[/TD]
    [TD="align: right"]12.8[/TD]
    [TD="align: right"]35.68[/TD]
    [TD="align: right"]1760[/TD]
    [TD="align: right"]91.7[/TD]
    [TD="align: right"]1720[/TD]
    [TD="align: right"]1150[/TD]
    [TD="align: right"]35.08[/TD]
    [/TR]
    [TR]
    [TD="align: right"]36.28[/TD]
    [TD="align: right"]38.53[/TD]
    [TD="align: right"]84.7[/TD]
    [TD="align: right"]12[/TD]
    [TD="align: right"]36.58[/TD]
    [TD="align: right"]2000[/TD]
    [TD="align: right"]107.5[/TD]
    [TD="align: right"]1900[/TD]
    [TD="align: right"]1250[/TD]
    [TD="align: right"]35.98[/TD]
    [TD="align: right"]0.79[/TD]
    [/TR]
    [TR]
    [TD="align: right"]37.18[/TD]
    [TD="align: right"]2200[/TD]
    [TD="align: right"]50.36[/TD]
    [TD="align: right"]90.6[/TD]
    [TD="align: right"]11.3[/TD]
    [TD="align: right"]37.48[/TD]
    [TD="align: right"]2280[/TD]
    [TD="align: right"]124.1[/TD]
    [TD="align: right"]2100[/TD]
    [TD="align: right"]1410[/TD]
    [TD="align: right"]36.88[/TD]
    [TD="align: right"]0.825[/TD]
    [/TR]
    [TR]
    [TD="align: right"]38.08[/TD]
    [TD="align: right"]2520[/TD]
    [TD="align: right"]67.36[/TD]
    [TD="align: right"]96.9[/TD]
    [TD="align: right"]38.38[/TD]
    [TD="align: right"]2640[/TD]
    [TD="align: right"]142.9[/TD]
    [TD="align: right"]2270[/TD]
    [TD="align: right"]1640[/TD]
    [TD="align: right"]37.78[/TD]
    [TD="align: right"]0.82[/TD]
    [/TR]
    [TR]
    [TD="align: right"]38.98[/TD]
    [TD="align: right"]2880[/TD]
    [TD="align: right"]97.06[/TD]
    [TD="align: right"]99.2[/TD]
    [TD="align: right"]8.3[/TD]
    [TD="align: right"]39.28[/TD]
    [TD="align: right"]3040[/TD]
    [TD="align: right"]180.5[/TD]
    [TD="align: right"]2370[/TD]
    [TD="align: right"]2010[/TD]
    [TD="align: right"]38.68[/TD]
    [TD="align: right"]0.83[/TD]
    [/TR]
    [TR]
    [TD="align: right"]39.88[/TD]
    [TD="align: right"]3400[/TD]
    [TD="align: right"]136.31[/TD]
    [TD="align: right"]100[/TD]
    [TD="align: right"]40.18[/TD]
    [TD="align: right"]3560[/TD]
    [TD="align: right"]191.7[/TD]
    [TD="align: right"]2340[/TD]
    [TD="align: right"]2450[/TD]
    [TD="align: right"]39.58[/TD]
    [TD="align: right"]0.855[/TD]
    [/TR]
    [TR]
    [TD="align: right"]40.79[/TD]
    [TD="align: right"]3920[/TD]
    [TD="align: right"]154.67[/TD]
    [TD="align: right"]66.3[/TD]
    [TD="align: right"]41.08[/TD]
    [TD="align: right"]4080[/TD]
    [TD="align: right"]158.6[/TD]
    [TD="align: right"]1890[/TD]
    [TD="align: right"]2190[/TD]
    [TD="align: right"]40.48[/TD]
    [TD="align: right"]0.865[/TD]
    [/TR]
    [TR]
    [TD="align: right"]41.69[/TD]
    [TD="align: right"]4320[/TD]
    [TD="align: right"]126.42[/TD]
    [TD="align: right"]41.99[/TD]
    [TD="align: right"]4480[/TD]
    [TD="align: right"]156.4[/TD]
    [TD="align: right"]1820[/TD]
    [TD="align: right"]1770[/TD]
    [TD="align: right"]41.39[/TD]
    [TD="align: right"]0.86[/TD]
    [/TR]
    [TR]
    [TD="align: right"]42.59[/TD]
    [TD="align: right"]4680[/TD]
    [TD="align: right"]135.03[/TD]
    [TD="align: right"]42.89[/TD]
    [TD="align: right"]4800[/TD]
    [TD="align: right"]146.6[/TD]
    [TD="align: right"]1750[/TD]
    [TD="align: right"]1730[/TD]
    [TD="align: right"]42.29[/TD]
    [TD="align: right"]0.87[/TD]
    [/TR]
    [TR]
    [TD="align: right"]43.49[/TD]
    [TD="align: right"]5040[/TD]
    [TD="align: right"]136.5[/TD]
    [TD="align: right"]43.79[/TD]
    [TD="align: right"]5160[/TD]
    [TD="align: right"]144.4[/TD]
    [TD="align: right"]1700[/TD]
    [TD="align: right"]43.19[/TD]
    [/TR]
    [TR]
    [TD="align: right"]44.39[/TD]
    [TD="align: right"]5360[/TD]
    [TD="align: right"]145.56[/TD]
    [TD="align: right"]13.5[/TD]
    [TD="align: right"]44.69[/TD]
    [TD="align: right"]5440[/TD]
    [TD="align: right"]143.6[/TD]
    [TD="align: right"]1690[/TD]
    [TD="align: right"]44.09[/TD]
    [/TR]
    [TR]
    [TD="align: right"]45.29[/TD]
    [TD="align: right"]5640[/TD]
    [TD="align: right"]156.58[/TD]
    [TD="align: right"]15.8[/TD]
    [TD="align: right"]45.59[/TD]
    [TD="align: right"]5760[/TD]
    [TD="align: right"]141.4[/TD]
    [TD="align: right"]1710[/TD]
    [TD="align: right"]44.99[/TD]
    [TD="align: right"]0.88[/TD]
    [/TR]
    [TR]
    [TD="align: right"]46.19[/TD]
    [TD="align: right"]5960[/TD]
    [TD="align: right"]165.08[/TD]
    [TD="align: right"]15[/TD]
    [TD="align: right"]46.49[/TD]
    [TD="align: right"]5840[/TD]
    [TD="align: right"]63.9[/TD]
    [TD="align: right"]1950[/TD]
    [TD="align: right"]45.89[/TD]
    [TD="align: right"]0.885[/TD]
    [/TR]
    [TR]
    [TD="align: right"]47.09[/TD]
    [TD="align: right"]4840[/TD]
    [TD="align: right"]6.67[/TD]
    [TD="align: right"]47.38[/TD]
    [TD="align: right"]1120[/TD]
    [TD="align: right"]46.79[/TD]
    [TD="align: right"]0.66[/TD]
    [/TR]
    [TR]
    [TD="align: right"]47.98[/TD]
    [TD="align: right"]24.78[/TD]
    [TD="align: right"]14.1[/TD]
    [TD="align: right"]35.3[/TD]
    [TD="align: right"]48.28[/TD]
    [TD="align: right"]1080[/TD]
    [TD="align: right"]47.68[/TD]
    [/TR]
    [TR]
    [TD="align: right"]48.88[/TD]
    [TD="align: right"]4440[/TD]
    [TD="align: right"]16.36[/TD]
    [TD="align: right"]49.18[/TD]
    [TD="align: right"]1070[/TD]
    [TD="align: right"]48.58[/TD]
    [/TR]
    [/TABLE]
    re-log
    Code:
    [TR]
    [TD]Group A:[/TD]
    [TD]'003[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group B:[/TD]
    [TD]'115[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group C:[/TD]
    [TD]'031[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]Engine
    Speed[/TD]
    [TD]Mass
    Air
    Flow[/TD]
    [TD]Throttle
    Valve
    Angle[/TD]
    [TD]Ignition[/TD]
    [TD][/TD]
    [TD]Engine
    Speed[/TD]
    [TD]Engine
    Load[/TD]
    [TD]Boost
    Pressure[/TD]
    [TD]Boost
    Pressure[/TD]
    [TD][/TD]
    [TD]Lambda
    Control[/TD]
    [/TR]
    [TR]
    [TD]TIME[/TD]
    [TD](G28)[/TD]
    [TD][/TD]
    [TD]Timing
    Angle[/TD]
    [TD]TIME[/TD]
    [TD](G28)[/TD]
    [TD][/TD]
    [TD](actual)[/TD]
    [TD]TIME[/TD]
    [TD]Bank 1
    (actual)[/TD]
    [/TR]
    [TR]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD] g/s[/TD]
    [TD] %[/TD]
    [TD] °BTDC[/TD]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD] %[/TD]
    [TD] mbar[/TD]
    [TD] mbar[/TD]
    [TD]STAMP[/TD]
    [TD] V[/TD]
    [/TR]
    [TR]
    [TD="align: right"]3.58[/TD]
    [/TR]
    [TR]
    [TD="align: right"]3.69[/TD]
    [TD="align: right"]22.6[/TD]
    [/TR]
    [TR]
    [TD="align: right"]1.83[/TD]
    [TD="align: right"]-2.3[/TD]
    [TD="align: right"]2.2[/TD]
    [TD="align: right"]2.5[/TD]
    [TD="align: right"]0.145[/TD]
    [/TR]
    [TR]
    [TD="align: right"]2.8[/TD]
    [TD="align: right"]3.1[/TD]
    [TD="align: right"]880[/TD]
    [TD="align: right"]3.4[/TD]
    [TD="align: right"]0.665[/TD]
    [/TR]
    [TR]
    [TD="align: right"]3.7[/TD]
    [TD="align: right"]4.03[/TD]
    [TD="align: right"]4[/TD]
    [TD="align: right"]960[/TD]
    [TD="align: right"]23.3[/TD]
    [/TR]
    [TR]
    [TD="align: right"]4.6[/TD]
    [TD="align: right"]9.81[/TD]
    [TD="align: right"]4.9[/TD]
    [TD="align: right"]1040[/TD]
    [TD="align: right"]48.1[/TD]
    [TD="align: right"]5.2[/TD]
    [TD="align: right"]0.755[/TD]
    [/TR]
    [TR]
    [TD="align: right"]10.28[/TD]
    [TD="align: right"]5.8[/TD]
    [TD="align: right"]49.6[/TD]
    [TD="align: right"]6.1[/TD]
    [/TR]
    [TR]
    [TD="align: right"]6.4[/TD]
    [TD="align: right"]1360[/TD]
    [TD="align: right"]11.5[/TD]
    [TD="align: right"]6.69[/TD]
    [TD="align: right"]44.4[/TD]
    [TD="align: right"]6.99[/TD]
    [/TR]
    [TR]
    [TD="align: right"]7.29[/TD]
    [TD="align: right"]23.44[/TD]
    [TD="align: right"]18.4[/TD]
    [TD="align: right"]7.59[/TD]
    [TD="align: right"]2160[/TD]
    [TD="align: right"]67.7[/TD]
    [TD="align: right"]7.89[/TD]
    [TD="align: right"]0.745[/TD]
    [/TR]
    [TR]
    [TD="align: right"]8.19[/TD]
    [TD="align: right"]2720[/TD]
    [TD="align: right"]40.06[/TD]
    [TD="align: right"]8.49[/TD]
    [TD="align: right"]2920[/TD]
    [TD="align: right"]54.1[/TD]
    [TD="align: right"]8.79[/TD]
    [/TR]
    [TR]
    [TD="align: right"]9.09[/TD]
    [TD="align: right"]4.19[/TD]
    [TD="align: right"]9.39[/TD]
    [TD="align: right"]2080[/TD]
    [TD="align: right"]9.69[/TD]
    [TD="align: right"]0.035[/TD]
    [/TR]
    [TR]
    [TD="align: right"]9.99[/TD]
    [TD="align: right"]1240[/TD]
    [TD="align: right"]17.5[/TD]
    [TD="align: right"]10.29[/TD]
    [TD="align: right"]1480[/TD]
    [TD="align: right"]71.4[/TD]
    [TD="align: right"]1350[/TD]
    [TD="align: right"]10.59[/TD]
    [/TR]
    [TR]
    [TD="align: right"]10.89[/TD]
    [TD="align: right"]25.39[/TD]
    [TD="align: right"]71[/TD]
    [TD="align: right"]11.19[/TD]
    [TD="align: right"]1600[/TD]
    [TD="align: right"]87.2[/TD]
    [TD="align: right"]1110[/TD]
    [TD="align: right"]11.49[/TD]
    [TD="align: right"]0.72[/TD]
    [/TR]
    [TR]
    [TD="align: right"]11.79[/TD]
    [TD="align: right"]1800[/TD]
    [TD="align: right"]32.83[/TD]
    [TD="align: right"]80.4[/TD]
    [TD="align: right"]12.09[/TD]
    [TD="align: right"]96.2[/TD]
    [TD="align: right"]1190[/TD]
    [TD="align: right"]12.39[/TD]
    [/TR]
    [TR]
    [TD="align: right"]12.69[/TD]
    [TD="align: right"]43.25[/TD]
    [TD="align: right"]88.6[/TD]
    [TD="align: right"]12.99[/TD]
    [TD="align: right"]112.8[/TD]
    [TD="align: right"]1310[/TD]
    [TD="align: right"]13.29[/TD]
    [/TR]
    [TR]
    [TD="align: right"]13.59[/TD]
    [TD="align: right"]57.94[/TD]
    [TD="align: right"]94.1[/TD]
    [TD="align: right"]13.89[/TD]
    [TD="align: right"]2480[/TD]
    [TD="align: right"]129.3[/TD]
    [TD="align: right"]2220[/TD]
    [TD="align: right"]1490[/TD]
    [TD="align: right"]14.19[/TD]
    [/TR]
    [TR]
    [TD="align: right"]14.49[/TD]
    [TD="align: right"]77.81[/TD]
    [TD="align: right"]98.4[/TD]
    [TD="align: right"]14.79[/TD]
    [TD="align: right"]2840[/TD]
    [TD="align: right"]154.9[/TD]
    [TD="align: right"]2350[/TD]
    [TD="align: right"]15.09[/TD]
    [/TR]
    [TR]
    [TD="align: right"]15.39[/TD]
    [TD="align: right"]3120[/TD]
    [TD="align: right"]117.81[/TD]
    [TD="align: right"]15.69[/TD]
    [TD="align: right"]3280[/TD]
    [TD="align: right"]2290[/TD]
    [TD="align: right"]15.99[/TD]
    [/TR]
    [TR]
    [TD="align: right"]16.29[/TD]
    [TD="align: right"]3680[/TD]
    [TD="align: right"]156.97[/TD]
    [TD="align: right"]6.8[/TD]
    [TD="align: right"]16.59[/TD]
    [TD="align: right"]3840[/TD]
    [TD="align: right"]16.9[/TD]
    [/TR]
    [TR]
    [TD="align: right"]17.2[/TD]
    [TD="align: right"]4200[/TD]
    [TD="align: right"]124.17[/TD]
    [TD="align: right"]40.4[/TD]
    [TD="align: right"]1870[/TD]
    [TD="align: right"]1960[/TD]
    [TD="align: right"]17.8[/TD]
    [/TR]
    [TR]
    [TD="align: right"]18.1[/TD]
    [TD="align: right"]4560[/TD]
    [TD="align: right"]134.92[/TD]
    [TD="align: right"]153.4[/TD]
    [TD="align: right"]1810[/TD]
    [TD="align: right"]1790[/TD]
    [TD="align: right"]18.7[/TD]
    [TD="align: right"]0.875[/TD]
    [/TR]
    [TR]
    [TD="align: right"]19[/TD]
    [TD="align: right"]4880[/TD]
    [TD="align: right"]137.31[/TD]
    [TD="align: right"]19.3[/TD]
    [TD="align: right"]5000[/TD]
    [TD="align: right"]145.1[/TD]
    [TD="align: right"]1740[/TD]
    [TD="align: right"]19.6[/TD]
    [/TR]
    [TR]
    [TD="align: right"]19.9[/TD]
    [TD="align: right"]5240[/TD]
    [TD="align: right"]152.44[/TD]
    [TD="align: right"]20.2[/TD]
    [TD="align: right"]152.6[/TD]
    [TD="align: right"]20.5[/TD]
    [/TR]
    [TR]
    [TD="align: right"]20.8[/TD]
    [TD="align: right"]5560[/TD]
    [TD="align: right"]160.47[/TD]
    [TD="align: right"]21.1[/TD]
    [TD="align: right"]5680[/TD]
    [TD="align: right"]148.9[/TD]
    [TD="align: right"]1780[/TD]
    [TD="align: right"]21.4[/TD]
    [/TR]
    [TR]
    [TD="align: right"]21.7[/TD]
    [TD="align: right"]5880[/TD]
    [TD="align: right"]162.56[/TD]
    [TD="align: right"]22[/TD]
    [TD="align: right"]6000[/TD]
    [TD="align: right"]22.3[/TD]
    [TD="align: right"]0.89[/TD]
    [/TR]
    [TR]
    [TD="align: right"]6200[/TD]
    [TD="align: right"]171.53[/TD]
    [TD="align: right"]98.8[/TD]
    [TD="align: right"]22.9[/TD]
    [TD="align: right"]6280[/TD]
    [TD="align: right"]1620[/TD]
    [TD="align: right"]23.2[/TD]
    [/TR]
    [TR]
    [TD="align: right"]23.5[/TD]
    [TD="align: right"]6440[/TD]
    [TD="align: right"]163.03[/TD]
    [TD="align: right"]17.3[/TD]
    [TD="align: right"]23.8[/TD]
    [TD="align: right"]6520[/TD]
    [TD="align: right"]1610[/TD]
    [TD="align: right"]24.1[/TD]
    [TD="align: right"]0.895[/TD]
    [/TR]
    [TR]
    [TD="align: right"]24.4[/TD]
    [TD="align: right"]6640[/TD]
    [TD="align: right"]157.92[/TD]
    [TD="align: right"]54.9[/TD]
    [TD="align: right"]24.7[/TD]
    [TD="align: right"]6720[/TD]
    [TD="align: right"]130.8[/TD]
    [TD="align: right"]25[/TD]
    [TD="align: right"]0.91[/TD]
    [/TR]
    [TR]
    [TD="align: right"]25.3[/TD]
    [TD="align: right"]6840[/TD]
    [TD="align: right"]157.69[/TD]
    [TD="align: right"]25.6[/TD]
    [TD="align: right"]6920[/TD]
    [TD="align: right"]130.1[/TD]
    [TD="align: right"]25.9[/TD]
    [/TR]
    [TR]
    [TD="align: right"]26.2[/TD]
    [TD="align: right"]6080[/TD]
    [TD="align: right"]9.47[/TD]
    [TD="align: right"]26.49[/TD]
    [TD="align: right"]5520[/TD]
    [TD="align: right"]1180[/TD]
    [TD="align: right"]26.79[/TD]
    [TD="align: right"]0.795[/TD]
    [/TR]
    [TR]
    [TD="align: right"]27.09[/TD]
    [TD="align: right"]5.28[/TD]
    [TD="align: right"]27.38[/TD]
    [TD="align: right"]27.68[/TD]
    [TD="align: right"]0.01[/TD]
    [/TR]
    [TR]
    [TD="align: right"]27.99[/TD]
    [TD="align: right"]7.53[/TD]
    [TD="align: right"]28.29[/TD]
    [TD="align: right"]4920[/TD]
    [TD="align: right"]28.58[/TD]
    [TD="align: right"]0.005[/TD]
    [/TR]
    [TR]
    [TD="align: right"]28.89[/TD]
    [TD="align: right"]8.28[/TD]
    [TD="align: right"]29.19[/TD]
    [TD="align: right"]4720[/TD]
    [TD="align: right"]29.48[/TD]
    [/TR]
    [TR]
    [TD="align: right"]29.8[/TD]
    [TD="align: right"]7.81[/TD]
    [TD="align: right"]4.7[/TD]
    [TD="align: right"]30.08[/TD]
    [TD="align: right"]3640[/TD]
    [TD="align: right"]30.39[/TD]
    [/TR]
    [TR]
    [TD="align: right"]30.68[/TD]
    [TD="align: right"]2800[/TD]
    [TD="align: right"]4.89[/TD]
    [TD="align: right"]30.98[/TD]
    [TD="align: right"]31.28[/TD]
    [/TR]
    [TR]
    [TD="align: right"]31.58[/TD]
    [TD="align: right"]2560[/TD]
    [TD="align: right"]31.88[/TD]
    [TD="align: right"]32.18[/TD]
    [/TR]
    [TR]
    [TD="align: right"]32.48[/TD]
    [TD="align: right"]5.22[/TD]
    [TD="align: right"]32.78[/TD]
    [TD="align: right"]33.08[/TD]
    [/TR]
    [TR]
    [TD="align: right"]33.38[/TD]
    [TD="align: right"]5.06[/TD]
    [TD="align: right"]33.68[/TD]
    [TD="align: right"]33.98[/TD]
    [/TR]
    [TR]
    [TD="align: right"]34.28[/TD]
    [TD="align: right"]2440[/TD]
    [TD="align: right"]4.81[/TD]
    [TD="align: right"]34.58[/TD]
    [TD="align: right"]34.88[/TD]
    [/TR]
    [TR]
    [TD="align: right"]35.18[/TD]
    [TD="align: right"]2320[/TD]
    [TD="align: right"]35.48[/TD]
    [TD="align: right"]35.78[/TD]
    [/TR]
    [TR]
    [TD="align: right"]36.08[/TD]
    [TD="align: right"]36.38[/TD]
    [TD="align: right"]36.69[/TD]
    [/TR]
    [TR]
    [TD="align: right"]36.98[/TD]
    [TD="align: right"]4.33[/TD]
    [TD="align: right"]37.28[/TD]
    [TD="align: right"]37.58[/TD]
    [/TR]
    [TR]
    [TD="align: right"]37.88[/TD]
    [TD="align: right"]4.28[/TD]
    [TD="align: right"]38.18[/TD]
    [TD="align: right"]38.48[/TD]
    [/TR]
    [TR]
    [TD="align: right"]38.78[/TD]
    [TD="align: right"]39.08[/TD]
    [TD="align: right"]39.38[/TD]
    [/TR]
    [TR]
    [TD="align: right"]39.68[/TD]
    [TD="align: right"]3.92[/TD]
    [TD="align: right"]39.98[/TD]
    [TD="align: right"]40.28[/TD]
    [/TR]
    [TR]
    [TD="align: right"]40.58[/TD]
    [TD="align: right"]3.36[/TD]
    [TD="align: right"]-3.8[/TD]
    [TD="align: right"]40.88[/TD]
    [TD="align: right"]41.18[/TD]
    [/TR]
    [TR]
    [TD="align: right"]41.48[/TD]
    [TD="align: right"]-6[/TD]
    [TD="align: right"]41.78[/TD]
    [TD="align: right"]42.08[/TD]
    [/TR]
    [TR]
    [TD="align: right"]42.38[/TD]
    [TD="align: right"]42.68[/TD]
    [TD="align: right"]42.98[/TD]
    [/TR]
    [TR]
    [TD="align: right"]43.28[/TD]
    [TD="align: right"]680[/TD]
    [TD="align: right"]3.81[/TD]
    [TD="align: right"]20.3[/TD]
    [TD="align: right"]43.58[/TD]
    [TD="align: right"]760[/TD]
    [TD="align: right"]43.88[/TD]
    [TD="align: right"]0.78[/TD]
    [/TR]
    [TR]
    [TD="align: right"]44.18[/TD]
    [TD="align: right"]44.48[/TD]
    [TD="align: right"]44.78[/TD]
    [TD="align: right"]0.07[/TD]
    [/TR]
    [TR]
    [TD="align: right"]45.08[/TD]
    [TD="align: right"]3.42[/TD]
    [TD="align: right"]45.38[/TD]
    [TD="align: right"]45.68[/TD]
    [TD="align: right"]0.11[/TD]
    [/TR]
    [TR]
    [TD="align: right"]45.97[/TD]
    [TD="align: right"]3.89[/TD]
    [TD="align: right"]46.27[/TD]
    [TD="align: right"]46.57[/TD]
    [/TR]
    [TR]
    [TD="align: right"]46.87[/TD]
    [TD="align: right"]3.56[/TD]
    [TD="align: right"]47.17[/TD]
    [TD="align: right"]47.48[/TD]
    [TD="align: right"]0.63[/TD]
    [/TR]
    [/TABLE]
    Code:
    [TABLE="width: 766"]
    [TR]
    [TD]Group A:[/TD]
    [TD]'003[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group B:[/TD]
    [TD]'020[/TD]
    [TD][/TD]
    [TD][/TD]
    [TD][/TD]
    [TD]Group C:[/TD]
    [TD]'031[/TD]
    [/TR]
    [TR]
    [TD][/TD]
    [TD]Engine
    Speed[/TD]
    [TD]Mass
    Air
    Flow[/TD]
    [TD]Throttle
    Valve
    Angle[/TD]
    [TD]Ignition[/TD]
    [TD][/TD]
    [TD]Timing
    Retardation[/TD]
    [TD]Timing
    Retardation[/TD]
    [TD]Timing
    Retardation[/TD]
    [TD]Timing
    Retardation[/TD]
    [TD][/TD]
    [TD]Lambda
    Control[/TD]
    [/TR]
    [TR]
    [TD]TIME[/TD]
    [TD](G28)[/TD]
    [TD]Sensor
    (G70)[/TD]
    [TD][/TD]
    [TD]Timing
    Angle[/TD]
    [TD]TIME[/TD]
    [TD]Cylinder 1[/TD]
    [TD]Cylinder 2[/TD]
    [TD]Cylinder 3[/TD]
    [TD]Cylinder 4[/TD]
    [TD]TIME[/TD]
    [TD]Bank 1
    (actual)[/TD]
    [/TR]
    [TR]
    [TD]STAMP[/TD]
    [TD] /min[/TD]
    [TD] g/s[/TD]
    [TD] %[/TD]
    [TD] °BTDC[/TD]
    [TD]STAMP[/TD]
    [TD]°KW[/TD]
    [TD]°KW[/TD]
    [TD]°KW[/TD]
    [TD]°KW[/TD]
    [TD]STAMP[/TD]
    [TD] V[/TD]
    [/TR]
    [TR]
    [TD="align: right"]0.85[/TD]
    [TD="align: right"]3.67[/TD]
    [TD="align: right"]-4.5[/TD]
    [TD="align: right"]0.25[/TD]
    [TD="align: right"]0.55[/TD]
    [TD="align: right"]0.13[/TD]
    [/TR]
    [TR]
    [TD="align: right"]1.78[/TD]
    [TD="align: right"]9.08[/TD]
    [TD="align: right"]1.15[/TD]
    [TD="align: right"]1.45[/TD]
    [/TR]
    [TR]
    [TD="align: right"]2.75[/TD]
    [TD="align: right"]10.67[/TD]
    [TD="align: right"]2.15[/TD]
    [TD="align: right"]2.46[/TD]
    [TD="align: right"]0.455[/TD]
    [/TR]
    [TR]
    [TD="align: right"]3.65[/TD]
    [TD="align: right"]11.31[/TD]
    [TD="align: right"]9.4[/TD]
    [TD="align: right"]3.05[/TD]
    [TD="align: right"]3.35[/TD]
    [/TR]
    [TR]
    [TD="align: right"]4.55[/TD]
    [TD="align: right"]9.94[/TD]
    [TD="align: right"]3.95[/TD]
    [TD="align: right"]4.25[/TD]
    [/TR]
    [TR]
    [TD="align: right"]5.45[/TD]
    [TD="align: right"]14.89[/TD]
    [TD="align: right"]10.2[/TD]
    [TD="align: right"]4.85[/TD]
    [TD="align: right"]5.15[/TD]
    [TD="align: right"]0.62[/TD]
    [/TR]
    [TR]
    [TD="align: right"]6.35[/TD]
    [TD="align: right"]28.42[/TD]
    [TD="align: right"]20[/TD]
    [TD="align: right"]5.75[/TD]
    [TD="align: right"]6.05[/TD]
    [TD="align: right"]0.35[/TD]
    [/TR]
    [TR]
    [TD="align: right"]7.25[/TD]
    [TD="align: right"]3160[/TD]
    [TD="align: right"]53[/TD]
    [TD="align: right"]36.5[/TD]
    [TD="align: right"]22.5[/TD]
    [TD="align: right"]6.65[/TD]
    [TD="align: right"]6.95[/TD]
    [TD="align: right"]0.105[/TD]
    [/TR]
    [TR]
    [TD="align: right"]8.15[/TD]
    [TD="align: right"]3.72[/TD]
    [TD="align: right"]7.56[/TD]
    [TD="align: right"]7.85[/TD]
    [/TR]
    [TR]
    [TD="align: right"]9.05[/TD]
    [TD="align: right"]27.67[/TD]
    [TD="align: right"]8.45[/TD]
    [TD="align: right"]8.75[/TD]
    [/TR]
    [TR]
    [TD="align: right"]47.25[/TD]
    [TD="align: right"]34.5[/TD]
    [TD="align: right"]9.34[/TD]
    [TD="align: right"]9.64[/TD]
    [/TR]
    [TR]
    [TD="align: right"]10.84[/TD]
    [TD="align: right"]3080[/TD]
    [TD="align: right"]83.08[/TD]
    [TD="align: right"]10.24[/TD]
    [TD="align: right"]10.54[/TD]
    [/TR]
    [TR]
    [TD="align: right"]11.75[/TD]
    [TD="align: right"]3880[/TD]
    [TD="align: right"]72.14[/TD]
    [TD="align: right"]24.3[/TD]
    [TD="align: right"]11.14[/TD]
    [TD="align: right"]11.45[/TD]
    [TD="align: right"]0.84[/TD]
    [/TR]
    [TR]
    [TD="align: right"]12.64[/TD]
    [TD="align: right"]4.67[/TD]
    [TD="align: right"]12.05[/TD]
    [TD="align: right"]12.34[/TD]
    [/TR]
    [TR]
    [TD="align: right"]13.54[/TD]
    [TD="align: right"]28.72[/TD]
    [TD="align: right"]30.8[/TD]
    [TD="align: right"]12.94[/TD]
    [TD="align: right"]13.24[/TD]
    [/TR]
    [TR]
    [TD="align: right"]14.44[/TD]
    [TD="align: right"]61.94[/TD]
    [TD="align: right"]13.84[/TD]
    [TD="align: right"]14.14[/TD]
    [/TR]
    [TR]
    [TD="align: right"]15.34[/TD]
    [TD="align: right"]97.31[/TD]
    [TD="align: right"]14.74[/TD]
    [TD="align: right"]15.04[/TD]
    [TD="align: right"]0.815[/TD]
    [/TR]
    [TR]
    [TD="align: right"]16.24[/TD]
    [TD="align: right"]3480[/TD]
    [TD="align: right"]136.28[/TD]
    [TD="align: right"]15.64[/TD]
    [TD="align: right"]15.94[/TD]
    [/TR]
    [TR]
    [TD="align: right"]17.15[/TD]
    [TD="align: right"]4040[/TD]
    [TD="align: right"]159.56[/TD]
    [TD="align: right"]16.54[/TD]
    [TD="align: right"]16.84[/TD]
    [/TR]
    [TR]
    [TD="align: right"]18.05[/TD]
    [TD="align: right"]162.53[/TD]
    [TD="align: right"]17.45[/TD]
    [TD="align: right"]17.75[/TD]
    [/TR]
    [TR]
    [TD="align: right"]18.94[/TD]
    [TD="align: right"]158.5[/TD]
    [TD="align: right"]18.35[/TD]
    [TD="align: right"]18.65[/TD]
    [/TR]
    [TR]
    [TD="align: right"]19.84[/TD]
    [TD="align: right"]5280[/TD]
    [TD="align: right"]166.64[/TD]
    [TD="align: right"]19.25[/TD]
    [TD="align: right"]19.55[/TD]
    [/TR]
    [TR]
    [TD="align: right"]20.75[/TD]
    [TD="align: right"]5600[/TD]
    [TD="align: right"]168.78[/TD]
    [TD="align: right"]20.15[/TD]
    [TD="align: right"]20.45[/TD]
    [/TR]
    [TR]
    [TD="align: right"]21.65[/TD]
    [TD="align: right"]5920[/TD]
    [TD="align: right"]177.86[/TD]
    [TD="align: right"]21.05[/TD]
    [TD="align: right"]21.35[/TD]
    [/TR]
    [TR]
    [TD="align: right"]22.55[/TD]
    [TD="align: right"]172.89[/TD]
    [TD="align: right"]21.95[/TD]
    [TD="align: right"]22.25[/TD]
    [/TR]
    [TR]
    [TD="align: right"]23.45[/TD]
    [TD="align: right"]51.17[/TD]
    [TD="align: right"]22.85[/TD]
    [TD="align: right"]23.15[/TD]
    [/TR]
    [TR]
    [TD="align: right"]24.35[/TD]
    [TD="align: right"]5120[/TD]
    [TD="align: right"]4.94[/TD]
    [TD="align: right"]23.75[/TD]
    [TD="align: right"]24.05[/TD]
    [/TR]
    [TR]
    [TD="align: right"]25.25[/TD]
    [TD="align: right"]6.17[/TD]
    [TD="align: right"]24.65[/TD]
    [TD="align: right"]24.95[/TD]
    [TD="align: right"]0.725[/TD]
    [/TR]
    [TR]
    [TD="align: right"]26.14[/TD]
    [TD="align: right"]4600[/TD]
    [TD="align: right"]6.92[/TD]
    [TD="align: right"]25.55[/TD]
    [TD="align: right"]25.84[/TD]
    [/TR]
    [TR]
    [TD="align: right"]27.04[/TD]
    [TD="align: right"]8.22[/TD]
    [TD="align: right"]26.44[/TD]
    [TD="align: right"]26.74[/TD]
    [/TR]
    [TR]
    [TD="align: right"]27.95[/TD]
    [TD="align: right"]4360[/TD]
    [TD="align: right"]27.34[/TD]
    [TD="align: right"]27.65[/TD]
    [/TR]
    [TR]
    [TD="align: right"]28.85[/TD]
    [TD="align: right"]4280[/TD]
    [TD="align: right"]8.58[/TD]
    [TD="align: right"]28.24[/TD]
    [TD="align: right"]28.55[/TD]
    [/TR]
    [TR]
    [TD="align: right"]29.74[/TD]
    [TD="align: right"]4160[/TD]
    [TD="align: right"]8.86[/TD]
    [TD="align: right"]5.9[/TD]
    [TD="align: right"]29.13[/TD]
    [TD="align: right"]29.44[/TD]
    [/TR]
    [TR]
    [TD="align: right"]30.63[/TD]
    [TD="align: right"]9.06[/TD]
    [TD="align: right"]30.03[/TD]
    [TD="align: right"]30.33[/TD]
    [/TR]
    [TR]
    [TD="align: right"]31.53[/TD]
    [TD="align: right"]30.93[/TD]
    [TD="align: right"]31.23[/TD]
    [/TR]
    [TR]
    [TD="align: right"]32.43[/TD]
    [TD="align: right"]3.86[/TD]
    [TD="align: right"]31.83[/TD]
    [TD="align: right"]32.13[/TD]
    [/TR]
    [TR]
    [TD="align: right"]33.33[/TD]
    [TD="align: right"]5.31[/TD]
    [TD="align: right"]32.73[/TD]
    [TD="align: right"]33.03[/TD]
    [/TR]
    [TR]
    [TD="align: right"]34.23[/TD]
    [TD="align: right"]33.63[/TD]
    [TD="align: right"]33.93[/TD]
    [/TR]
    [TR]
    [TD="align: right"]35.13[/TD]
    [TD="align: right"]5.11[/TD]
    [TD="align: right"]34.53[/TD]
    [TD="align: right"]34.83[/TD]
    [/TR]
    [TR]
    [TD="align: right"]36.03[/TD]
    [TD="align: right"]2240[/TD]
    [TD="align: right"]4.97[/TD]
    [TD="align: right"]35.43[/TD]
    [TD="align: right"]35.73[/TD]
    [/TR]
    [TR]
    [TD="align: right"]36.93[/TD]
    [TD="align: right"]36.33[/TD]
    [TD="align: right"]36.63[/TD]
    [/TR]
    [/TABLE]
  2. chaz20vt
    chaz20vt Member
    428
    21
    Thanks again for doing the logs hope some one can point me in the right direction now
  3. Dani_B19
    9,320
    390
    It a apy s3? Mine showed the same fault and cleared it, never came back, relates to the sai, just removed mine, believe they can stick open and cause boost issues but not to the extent hes getting with the timing pull i dot think.
  4. Alex C
    3,267
    360
    yeah its an APY.
    Here is a plot of the boost request (blue) and actual (red) for the 2nd log
  5. Dani_B19
    9,320
    390
    Poss boost leak? What g/s did it make? The car standard? Did you clear the fault codes and did they come back?
  6. Alex C
    3,267
    360
    yeah i scanned for fault codes for him a few weeks ago and at the time it had the following fault codes
    Code:
                    Address 01: Engine       Labels: 06A-906-032-APX.clbControl Module Part Number: 8N0 906 018
      Component and/or Version: 1.8L R4 5VT      01 0003
               Software Coding: 05610
                Work Shop Code: WSC 06313
                          VCID: EED839A8AA91FF68439
    2 Faults Found:
    16486 - Mass Air Flow Sensor (G70)
                P0102 - 35-10 - Signal too Low - Intermittent
    Readiness: 0000 0000
    I cleared these fault codes
    I think the MAF error was an old fault code generated by a old split-R DV he used to have. But he has since replaced it with a full recirc DV and the fault has not returned
    Only the SAI fault reappeared
  7. Dani_B19
    9,320
    390
    What g/s it make?
  8. Alex C
    3,267
    360
    log #2 shows a peak g/s of 171 at 6200rpm
  9. <tuffty/>
    21,362
    3,927
    Too tired to absorb this tonight but I'll try and have a look through it tomorrow and let you know my thoughts...
  10. Dani_B19
    9,320
    390
    Sorry mate my iphones not displaying the info properly. Well thats only making 213bhp with the divide by 0.8 rule sonits under power for a stage 1, could be poss maf, when mine went on my apy it only showed the maf code once then never come back but the maf was dead, new one fixed it. Has he checked for poss boost leaks? Poss do a n249 and sai delete them check from their, simple and cheap todo on the apy motor.
  11. chaz20vt
    chaz20vt Member
    428
    21
    Hi I did try Another maf and it seem to run the same but the maf was not a new one it was from another car
    So you suggest I do the n249 bypass, is the SAI hard to do
  12. Alex C
    3,267
    360
  13. jezzy
    jezzy Member
    768
    Delete both, both quite easy and guides in the stickies section.
    I have apy and ditched both.
    i have also done pcv delete.
    This will basically simplify your vacuum system and update your old rotting pipes.
  14. jezzy
    jezzy Member
    768
    when doing the sai delete, the pump is a ***** coming out, but if hit the brackett from underneath with a hammer towards the drivers side the pump just drops out. easy
  15. Dani_B19
    9,320
    390
    Yes defo do both. Sai you can do it and leave the pump in situ i have until i get around to removing it. Also what state is the pcv system in as thats prone to leaking.
  16. chaz20vt
    chaz20vt Member
    428
    21
    Thanks for the advice ill get the SAI removed and the PVC system deleted I think
  17. jezzy
    jezzy Member
    768
    sorry mate not deleted i meant simplified (pcv)
  18. chaz20vt
    chaz20vt Member
    428
    21
    Ok what do you mean simplified
  19. jezzy
    jezzy Member
    768
  20. chaz20vt
    chaz20vt Member
    428
    21
    ok ill take a look thanks again appreciate every ones help
  21. Alex C
    3,267
    360
    what grade fuel do you use chaz?
  22. superkarl
    superkarl MAN OF STEEL
    9,494
    2,436
    i dont see a problem with that tbh.
    its just requesting alot early, which its never going to make. 1bar by 2000 rpm? turbo's only just spinning then lol.
    then after that its meeting it.
    the problem is after 3k boost request is poo, requesting 0.7bar at 5k, 6k, my standard map makes more than that lol.
    you sure its an mtm map? its a bloody bad one if its request is so low.
    i think that explains the low maf readings for sure.
    as for timing pull, that amount of timing pull will make the car feel flat, aswell as the drop in boost.
    to the owner: how much oil does it use? any found in the boost pipes, the intercoolers, and throttle body?
    p.s. log lambda values
  23. Alex C
    3,267
    360
    i was guessing that the map went into some sort of protection mode seeing high engine pulls and cut the boost request
  24. superkarl
    9,494
    2,436
    it should log a 'boost limit exceeded' type code and boost request for the map would still be what the map wants. actual would just be actuator pressure, if that was the case. actual would be about 0.35-4bar then.
    il leave the rest up to tuffty and other more experienced people. but i think the problem is ze map.
    edit: should have read you post more clearly, high engine pulls, not high boost. i think the car will just pull and pull it back, not affecting boost.
  25. Alex C
    3,267
    360
    Chaz - Do you have the paper work for the map telling you who mapped it?
  26. chaz20vt
    chaz20vt Member
    428
    21
    Sorry iv been working and only just got a break I only use normal unleaded fuel In the car and have done since iv owned it for a month now
    Iv searched through all of the receipts and I don't actually have paper work for a remap so its only what the guy who sold me it has said that its a stage 1 mtm map
    When I changed a couple of boost pipes and cleaned the throttle body there was a bit of oil in there but I though as I don't have a catch can that was normal
  27. chaz20vt
    chaz20vt Member
    428
    21
    This is a dyno grapth which is in the paper work I got
  28. Alex C
    3,267
    360
    you should use high octane fuel especially when mapped. If you look at the fuel filler cap i think the label says high octane? I use Tesco Momentum 99. Some times if i'm feeling flush i'll fill with Shell V-power
  29. chaz20vt
    chaz20vt Member
    428
    21
    So is it the fuel that I'm using making it not run right
  30. Alex C
    3,267
    360
    no, don't think so, but it wont help it either
  31. chaz20vt
    chaz20vt Member
    428
    21
    Ok ill start using better fuel
    Any ideas what's happening with it then Alex
  32. Alex C
    3,267
    360
    not sure tbh mate. Fueling looks lean during full load with lambda ~>0.88
    I think its supposed to be around 0.85 on boost?
  33. dancupra225
    dancupra225 Active Member
    667
    25
    when your down next i live in redruth log mine and compare mine to chaz's mine stage 1 by r-tech got a print out of 265bhp without forge tip on it holds boost better now as well..
  34. Alex C
    3,267
    360
    yeah sure, i never really plan to go that way but sometimes just go for a blast down there. Let me know when ever is good for you. I work during the week.
  35. jezzy
    jezzy Member
    768
    Hi mate
    i forgot to add, a few weeks ago i was changing the old pipes from the n75 valve.
    when i plugged it all back in, the car would boost crazily and car would take off and then hit limp mode.
    The cause was the n75 plumped in the wrong way.
    it gave a torque limit exceeded fault code.
    the small feed from the charge pipe to the n75 was actually plumped into my tip.
    Once changed back to the correct way it was all good.
    needless to say i will be experimenting once the rods are uprated
  36. chaz20vt
    chaz20vt Member
    428
    21
    Ok so do you think its my lamba I noticed today when I looked under my car iv got a decat pipe and the 2nd lamba is not there at all just a empty hole
    I just want the car to run right now im abit scared to drive it
  37. chaz20vt
    chaz20vt Member
    428
    21
    Any one shed any more light on this
  38. Dani_B19
    9,320
    390
    Thats fine mate, apy's only have one lambda sensor and thats just after the turbo, amk/bams have one just after the cat and with yours been an apy your fine.
  39. chaz20vt
    chaz20vt Member
    428
    21
    So it just being a whole there is fine yea
  40. Dani_B19
    9,320
    390
    What, its literally a hole in the exhaust? if so, no its not lol, you should have a bung for it to blank it off.
