3rd brake light removal
hewy Jul 14, 2012
  1. hewy
    hewy New Member
    22
    hi , i wondered if anyone could tell me how to take the third brake light out so i can get to the main light , cant seem to get surround off from parcel shelf , thanks ......:thumbsup:
  2. aragorn
    18,539
    865
    iirc you need to remove the parcel shelf, then you can unscrew the light.
  3. hewy
    hewy New Member
    22
    Had a look at that , can't seem to see where its fixed to car at. ?? Is it a pain to do ?
  4. aragorn
    18,539
    865
    theres three sort of pop clip things along the front edge, then it just slides forward. You need to fold down or remove the seat back thouhg.
  5. hewy
    hewy New Member
    22
    Sounds easy enough , thanks bud ,
  6. olds_kool
    olds_kool Active Member VCDS Map User
    1,094
    15
    The cover slides backwards to remove then there's 2 or 3 screws and wiring plug accessed from underneath to remove light unit
    No need to remove shelf
