345mm S3 disc upgrade
crunchie Dec 15, 2011
  1. crunchie
    crunchie Active Member
    880
    77
  2. Ash187
    7,444
    704
    links dont work
  3. crunchie
    880
    77
    Eh....yeah they do!
  4. tdi-man
    tdi-man Well-Known Member
    1,783
    64
    yes do for me to
  5. S3Alex
    10,374
    4,414
    Best man for brake issues is DaveB1970.
    Have you considered a proper big brake system as opposed to just discs?
  6. Ash187
    7,444
    704
    it wasnt working when i first tried it, works fine now :)
  7. S3Alex
    10,374
    4,414
    Even if you change the disc,you're still left with the OEM calipers,and a decent big kit will offer you far better results,such as the AP or VWR kits,if cost is not so much of an option.
  8. N8
    17,163
    718
    This is where its at:
    8 pot Gallardo calipers, with 362mm 2 piece AP discs along with TT-RS Master Cylinder :wub:
  9. Ash187
    7,444
    704
    you can buy another car with the same expense that goes into getting that brake setup :wub:
  10. N8
    17,163
    718
    What car?
  11. S3Alex
    10,374
    4,414
    I made do with the VWR kit on mine,which seems adequate,and as I said earlier,it's worth getting in touch with Dave for all Audi related brake issues,as he has a good selection of solutions to offer.
  12. crunchie
    880
    77
    Do you need spacers for the VWR or AP kits?
    I have std 8P3 wheels.
  13. S3Alex
    10,374
    4,414
    Not for the VWRACING kit as the bell mount takes that into account but you need a spacer for the AP kit which they can include.
    Both are good kits and will stop you far better than the stock system and without fade either.
  14. crunchie
    880
    77
    Would you suggest 10mm spacers on the rear then if you were to use VWR kit?
    The site shows the calipers in black but says red and special order R32 blue only?
    I'd prefer black rather than daft red ones!
  15. S3Alex
    10,374
    4,414
    You won't need rear spacers.
    The bell mount or spacer in the case of the AP is only about 2mm wider and just enough to clear the caliper.
    Mine are black.
  16. pinterovski
    pinterovski Member
    667
    88
    What will you buy if there was no big brake kits available?
    Will you stay with OEM or something else?
  17. crunchie
    880
    77
  18. S3 BUH
    S3 BUH Member
    355
    I can vouch for the AP kit got them on my S3 for normal road use there same bitting as standard and round brands hatch they where miles better than standard some serious stopping power and alot less fade go for a proper BBK like VWR or AP have heard a few good reviews on Forge's BBK which is around the same price
