330 BHP A4 Ebay
Markey Mar 10, 2008
  1. Siena
    Siena Active Member
    2,626
    Unfortunately, modified cars DO lose a fair bit of money, come resale time. Modified cars tend to appeal to a narrower audience. Regardless of how much you've spent on it.
    My car so far, has cost £7,000 in OEM RS4 parts, £2,100 in wheels and tyres, £420 in suspension, £400 S8 Brembo calipers, £3,000 in bodywork labour / paint.
    But realistically, I won't get anywhere near that amount if I ever wanted to sell her. I've also just purchased an S8 4.2 V8 motor for £900 delivered, yet to fit.
    The best I can advise with a modified car, is to enjoy her, drive her till the wheels fall off. Not very likely with an Audi, or find someone in the narrow market your car appeals to, and then you're most likely to get close to what you want, in terms of price.
    Good luck!
  2. smitch
    smitch Active Member
    1,588
    Considering you can buy an S4 of the same age for about 7k, you'd be lucky to get 4.5-5k i would've thought.
  3. GregC
    GregC Member
    278
    I've been offered £4,500 and a guy is considering £5,000 as we speak - I think finding the right buyer is the key. I'll let you know if it goes :)
  4. smitch
    1,588
    I think that would be it's top money but if someone is actually considering a conversion it makes for a pretty good deal.
    Good luck! :icon_thumright:
  5. John@ECM-TECH
    John@ECM-TECH Owner Site Sponsor
    305
    79
    do you still have this m8?
  6. dummi
    dummi smoking a6
    1,210
    20k for 330bhp?? looks like he's changed everything I suppose that was built to last
  7. On a slightly different note, how does a B5 with a 4.2 compare to a 2.7T with equal BHP? Is the engine heavier or lighter with the use of alloys? What difference is there to handling?
  8. Siena
    Siena Active Member
    2,626
    The 4,2L V8 is lighter than a fully dressed 2,7L V6 Biturbo.
    With a 1,5L advantage, it'll have the edge, with low-down grunt the V6 won't match.
    No substitute for cubic inches.
    With a good suspension set-up, it'll handle as well as the slightly shorter, but heavier V6.
  9. But I am guessing that the increased displacement means more internal friction due to the more contact area between rings and sleeves and, therfore, less MPG?
  10. bahnstorm.net
    bahnstorm.net Member
    50
    25k!!i could have built something with 1500bhp for that money,a 2.7tt with correct mods does slaughter a v8 rs4,i tried it earlier:whistle2:
  11. Siena
    Siena Active Member
    2,626
    We're talking a V8 and V6 with similar outputs, and similar modifications applied.
    The extra cc's will have the edge. The laws of physics says so.
    Sure, an RS4 V8 is 420, and a modified Biturbo V6 is a different issue, and power output could vary.
    Turbo power delivery is very different to N/A. So, a direct comparison would be an RS6 Biturbo with stock 450PS, and a modified RS4 Biturbo with the same output.
    The smaller V6 will need at least an extra 30PS to have a definite edge over the V8, as torque is a major ingredient for acelleration through the gears.
  12. bahnstorm.net
    50
    thats true,not sure on my torque output yet but from a rolling start in second with an extra 100 odd bhp more than the rs4 v8,he was well behind,3rd gear even more so
  13. Siena
    Siena Active Member
    2,626
    That's the very point I'm trying to get across. So, your car's about 520PS.
    RS4 V8 = 420PS
    S4 V6 = 520PS-odd
    Hardly comparable really. Almost like comparing a stock RS4 B5 to an A8.
    RS4 V6 2,7L 30V biturbo = 380PS
    A8 V8 4,2L 40V, n/asp. = 300PS
    Now, this is a bit different...
    RS4 V6 2,7L 30V biturbo, modified = 460PS
    RS6 V8 4,2L 40V biturbo, standard = 450PS
    In the above examples, no way will the RS4 'slaughter' the RS6, the hypothetical 10PS advantage the RS4 has over the RS6, even combined with the lighter weight advantage will not give the RS4 the edge.
    Torque rules, not to be confused with diesel torque, due to the derv engine's limited rev range.
  14. bahnstorm.net
    50
    torque does indeed rule and the rs6 has bucket loads,mind you audi i5 engines can give out huge torque figures with the right set up
  15. dummi
    dummi smoking a6
    1,210
    agree with you Siena would rather have NA than turbo and the weight difference on a ally block is great, but the 2.7 is much stronger and can have enormous output, and the torque curve for it can be altered to give it an advantage, on k03's it has a lot of low down grunt.
    I have had big cubes in a buick before currently downsized to 5.0, with fuel prices probably take another step down , so yes I know the imense torque low down, but little turbo's fill the cylinders surprisingly quick on small capacity
    not trying to take away from anything you have said, I've read your 4.2 conversion and you obviously know your stuff
