312mm brakes, parts list?
Oranoco Jan 13, 2009
  1. Oranoco
    Oranoco Well-Known Member
    3,996
    408
    Depending on the wifes sense of humour on payday I was thinking I might get on with it. What exactly do I need?
    312mm B6 discs (off what model)
    Carriers (off what and where from as VAGParts have gone)
    Anything else needed?
  2. Fraser
    Fraser Member
    584
    b6 S4 I believe are the following
    2 x 345mm discs from B6 S4
    2 x calipers from same vehicle.
    1 lt of brake fluid.
    1.5 m of braided line
    Re useable brake fitting to suit.
    you may need front caliper carriers, and the brake pad retaining spring - not too sure about this.
    I was looking at doing the above but found a full set of RS4 brakes for less overall
  3. aragorn
    18,579
    868
    b6 s4 calipers wont fit the B5 unless its an S4 or RS4 though
    you want B6 A4 312mm disks, the bigger engined models had them like the 1.8T 190 and the 3.0's
    you'll want new pads, just get standard b5 A4 ones though...
    carriers either new from audi (expensive) or from a breakers
    I spent a few weeks emailing people on ebay that were breaking TT's asking for the carriers and ended up getting a set for £50. The only issue is that some of the breakers are wise, and sell the calipers disks and pads together as an upgrade kit for golfs for ~£200, ive no idea why one would want to fit used disks and pads but there you go, means they wont sell the carriers alone.
  4. H2o-uk
    H2o-uk Member
    106
    Does anyone have the Audi Part number for the TT Carriers, I'm going to quiz my local dealer and see what they are offering them at.
  5. aragorn
    18,579
    868
    8N0615125 as far as i can tell from vagcat.
    Speak to Siena for a price, he'll be able to beat main dealers i would imagine.
  6. voteforpedro
    voteforpedro Member
    632
    I'd be interested in a price for the carriers and discs if the upgrade is that simple. :)
  7. aragorn
    18,579
    868
    i bought the disks at my local factors for £30 each, pads were around £15-20 for mintex branded ones
  8. voteforpedro
    voteforpedro Member
    632
    Do you have to replace the pads? Mine are nearly new. :(
  9. aragorn
    18,579
    868
    You really should replace the pads when fitting new disks.
  10. Oranoco
    3,996
    408
    I asked at the Stealers teh other day and was quoted £122 each for the carriers. VAG Parts were doing them at £98 for the pair iirc
