312mm Brake Upgrade - Same pad size same surface area??
sekenzo Feb 28, 2010
  1. sekenzo
    sekenzo Member
    102
    I have just done my front conversion from 288mm to 312mm. Quite an easy upgrade took me about 2 hours from start to finish...
    Maybe I am just being thick... I can't help but wonder... how is going to 312 going to give better braking if the pad size is the same, which effectively still covers the same friction area on the disc?
  2. adamss24
    adamss24 Well-Known Member
    4,550
    392
    More leverage me friend ! Caliper is spaced further away from the centre of the disc wich means you will have more stopping power for the same clamping force + better heat disipation.
  3. badger5
    9,311
    1,886
    as said leverage
  4. Prawn
    11,354
    3,191
    A force applied at a right angle to a lever, multiplied by it's perpendicular distance from the pivot point, is torque. By increasing the length of the lever, a greater torque is applied at the pivot for the same input at the levers end.
    So as Adam and Bill have said above, it's leverage :)
  5. sekenzo
    sekenzo Member
    102
    Thanks for the explaination chaps :icon_thumright:
  6. c_dog
    c_dog Member
    92
    So if you add bigger pads would you still get the increased leverage?
  7. JS1500
    JS1500 Howdy
    1,166
    10
    Not without bigger discs. It's the distance from the hub that equates to the leverage.
  8. SamiG
    SamiG On Boost, ish.
    233
    Do S3's come standard 288mm then? What motor does the 312mm's come from?
  9. Effect
    Effect Member
    469
    312mm is standard s3
  10. SamiG
    233
    Oh i see.
    What size is LCR?
    Thanks for info :)
  11. MikeA3
    MikeA3 Active Member VCDS Map User
    1,178
    LCR uses a brembo set up - 323mm if memory serves
  12. SamiG
    233
    Is the LCR setup a straight swap onto the S3?
    Thanks.
