312mm brake conversion
macca Sep 7, 2006
  1. macca
    macca Member
    525
    Sorry for asking something thats been discussed quite a bit already, but i'm just putting in a new engine into a A4 1.8T Sport (FWD-1998) i have just aquired, as it has been standing for about a year i thought it maybe wise to replace brake discs and pads as they are fairly corroded, calipers seem ok. While looking at this forum i notice 312mm discs from b6 a4 3.0 Q fit with new caliper carriers, will this setup fit under the std 16 inch wheels? also has anyone seen x-drilled 312mm discs? i was originally going to order zimmerman x-drilled std sized from GSF car parts, but couldn't see any 312mm x-drilled.thanks, hope to meet some of you in the near future.Macca
  2. jcb
    jcb Active Member VCDS Map User
    4,132
    13
    would have thought that would involve buying quite new parts and work out expensive. you could probably get RS4 B5 parts for the same price or stump up some cahs and get porsche calipers and A8/RS4 discs
  3. james0808
    james0808 Active Member
    3,548
    I got my B5 RS4 front brakes for £120.Straight fit and much better than the 312mm.They look alot better also.
  4. Olly_K
    Olly_K Administrator
    2,678
    james, what exactly did you get for 120 ?
    Im gonna be selling mine soon after the upgrade
  5. silver75
    silver75 Big Ron
    3,265
    cross drilled discs offer no benifits over standard or just grooved discs, in fact i have heard they make them weaker
  6. james0808
    3,548
    I got everything,callipers,carriers,really good discs and pads,flexi pipes,splash guards even the bolts.
  7. macca
    macca Member
    525
    thanks everyone for the quick replies, basically i will go down a porsche/AP Racing big brake kit eventually (once larger wheels etc are on car) but in the mean time i was looking at what i could do for not much more money than replacing with std size parts. i appreciate x-drilled aren't always better and sometimes are more prone to cracking, i have used zimmerman in the past on my track day cars and not had a problem when mixed with ferodo ds2500 pads.
    where do you get the rs4 setup from, i take these are 2nd hand, whats needed and any mods involved? do they fit under the 16 inch wheels?
  8. Dan Gliballs
    Dan Gliballs Active Member
    1,568
    I recently paid £250 for a rear set of RS4 brakes (great condition).
  9. kris_tdi
    kris_tdi Member
    164
    rs4 front brakes wont fit straight on a b5. you will need to change hubs etc...
    basically for the 312mm conversion you need discs from a b6 3.0q and carriers from any of the following:
    s3, tt, golf v64mo, octavia vrs.
    while you are at it, if yours is a pre face lift it will be worth getting the new design brake disc shields, they help in wet weather as the b5 has poor wet braking without them.
    And yes, the 312 fits under standard 16's.
  10. macca
    macca Member
    525
    perfect, spot on, that's exactly what i wanted to know, 312mm discs are the way forward for now, thanks kris tdi.
  11. jcb
    4,132
    13
    didn't think rs4's were a straight fit on B5. James0808, what did you need to do to fit them. lots for sale on RS246 as anyone with an RS4 gets a bit nervous when running 500bhp on an uprated motor on stock brakes
  12. madkebab
    madkebab Member
    420
    From the pic it looks as though James has a B6 A4.
  13. jcb
    4,132
    13
    aha, well spotted
  14. johnie72
    johnie72 Member
    68
    Quote by Kris_tdi
    "rs4 front brakes wont fit straight on a b5. you will need to change hubs etc...
    And yes, the 312 fits under standard 16's."
    Will I be able to run the b6 3.0q discs with standard b5 2.8 calipers until I can afford upgrades? Obviously I would change the carriers as suggested above.
  15. kris_tdi
    kris_tdi Member
    164
    yes, this is exactly what i have done.
