3 more breakages to the old girl :-(
Oranoco Dec 14, 2013
  1. Oranoco
    Oranoco Well-Known Member
    3,957
    404
    1. Started car first thing to find the starter motor has started to screech on cracnking over from cold :( 2. Few miles from home I found my screenwash level sensor had also died. Foolishly I'd left it until the light came on so promptly ran out, schoolboy error. Any idea how to change this or how expensive the part is? 3. Got back home and then found the passenger window switch has eaten itself. Good going for 3 hours
  2. PAULF
    PAULF Active Member VCDS Map User
    712
    66
    :ohmy:
  3. spartacus 68
    spartacus 68 Active Member quattro Audi A2 Audi Avant Owner Group
    375
    57
    Screen wash reservoir and sensor can be accessed by removing passenger side inner wheel arch, held in place with multiple stainless steel torx screws. Door window switch is also easy fix. The starter motor - not sure if Audi do exchange service?
  4. Oranoco
    3,957
    404
    They are all pretty straightforward forward, just annoying that all 3 where discovered in the same morning.. Cheers. for advice. on screenwash. sensor, will attack that next weekend.
  5. spartacus 68
    375
    57
    Know how you feel. Just repaired the rear screen-wash last weekend, now away to replace the front suspension arms. If I won the lottery I wouldn't replace the car, I'd just get a garage I could get into, with an open fire with piping hot coffee on tap! Good luck with the repairs.
