3" MAF Unmapped Car
WorkInProgress Apr 22, 2013
  1. WorkInProgress
    WorkInProgress Member
    253
    Just won a 3" alloy MAF pipe line on Ebay, is there any benefit to fitting this to an unmapped car or should I just hang on to it until mapping time?
  2. Prawn
    11,413
    3,302
    If you fit it unmapped you'll under fuel like crazy and side lots of damage and problems matey. Don't do it!
    larger mafs should only be fitted for mapping, not before.
    WorkInProgress likes this.
  3. WorkInProgress
    253
    Cheers Prawn :thumbsup:
  4. Grale1
    Grale1 Active Member
    795
    44
    Could i run a 3" MAF on my stage1 map prawn? As I'm wanting to go stage2 I also have saab red top injectors to go in at some point.
    sorry for the thread jump btw
  5. Jay A3
    Jay A3 #because Racecar Team Daytona Audi A3 Manual
    2,120
    353
    Niki told me when I did mine if im jus fitting the maf then dont, but if your fitting injectors at the same time then it would be ok as a temp as this will help stop it under fueling.. Better to leave it and fit the same week as you get mapped if not on the day of the map
  6. <tuffty/>
    20,900
    3,708
    No...
  7. Prawn
    11,413
    3,302
    definitely not the same week dude! Not even the morning before you leave! It only takes one journey running dangerously mean to blow it up.
    In theory, by fitting the larger MAF it'll under fuel by 38% or there abouts, the d u can compensate up to 25%, but that still leaves a 13% miss match to deal with. Adding merger maf AND injectors as you say is technically safer, but its a non calculated bodge at best, you know you've not got enough fuel, But you don't know how much, so you add injectors to add more fuel, but again, you don't know how much!
    It's of guesswork, crossed fingers, and hopes and prayers involved on that one. Better to just leave it id say!
  8. badger5
    9,401
    1,944
    alloy maf - no flow straightener
  9. WorkInProgress
    253
    Is this a bad thing Bill? (excuse my ignorance)
  10. Prawn
    11,413
    3,302
    Yes. Logs will show you increased airflow, and you'll think that your gained, but in reality the airflow isn't smooth enough and I think bills dyno testing showed losses despite the airflow gains.
  11. badger5
    9,401
    1,944
    unstable (non laminar) across sensor element which in turn may well mess with the fueling
    likely a bad thing.. Not had +ve experience of non screened larger MAF tubes personally - It reads "higher" yet inaccurate airflow
  12. WorkInProgress
    253
    Would something like this help matters: -
