3" maf senso/housing
a3dam Jan 18, 2013
  1. a3dam
    a3dam Member
    33
    I have got an Agu engine 1.8T a3 (1998) but at the min i running the standard maf sensor but i need to go upto the vr6 one but i not sure what part code is and dont have anymore info on it so was wondering if anyone would be able to give me a part number or info about what be the best place to try get one from?
    thanks
  2. <tuffty/>
    21,356
    3,923
    Need? this because you are fitting a larger turbo?
    Prawn should be able o give that to you if its not listed in his build thread somewhere
  3. a3dam
    a3dam Member
    33
    yes i need one as already fitted a bigger turbo before realising i would need one
  4. Prawn
    11,535
    3,475
    VR6 housing part number is 0 280 217 512
    What you need is just the sensor from an OBD2 mk3 VR6, engine code AAA I believe.
    Obviously when changing the MAF you'll need to have the map altered to suit.
    What bigger turbo have you fitted too? as the VR6 sensor maxes out at around 320bhp
  5. a3dam
    a3dam Member
    33
    cheers i have got a ko3s with k04 internals (a beachbuggy hybrid) but at the min its running 230.6 @ 5669 rpm and 296 ft-lbs @ 3690 at the flywheel but need to change maf, and get a 3" downpipe then get remap tweeked again to see what difference that makes to figures
  6. Prawn
    11,535
    3,475
    Ah right. Was this the jabba mapped one? Ko4-001 spec?
    at 230bhp you'll probably find your maf total maxed at 187gs. Vr6 maf will suit perfectly :)
  7. a3dam
    a3dam Member
    33
  8. a3dam
    a3dam Member
    33
