3 into 2.5
ianh Apr 15, 2010
  1. ianh
    ianh Member
    62
    anyone know whether the backboxes of a 3 litre tdi cab will fit the 2.5tdi,along with the bottom apron? got behind a 3 litre today and looked much better than my 2.5.
  2. quattrojames
    14,050
    574
    The 3.0TDi is a B7 model so has a totally different rear bumper.
    I'm sure the back boxes would fit - but all you would need to do is a get a rear valance with the exhaust cut outs and weld some Powerflow tips on.
  3. A4 nut
    A4 nut Member
    351
    Arnt they the same as the 1.8T look at my avatar
    Ps james cabs did not change
  4. quattrojames
    14,050
    574
    Does the OP have a cab? It doesn't say so in his post unless I've misread it.
  5. A4 nut
    A4 nut Member
    351
    I read it as will the 3.0 fit the 2.5 take it as the same cab, but good question?
  6. ianh
    ianh Member
    62
    yep,mines the b6 cab 2.5.the apron on the 3 tdi maybe the same as the 1.8 but the exhaust isnt,they still point down as do mine but they are more noticeable as they protrude from the apron whereas mine are hidden.
  7. quattrojames
    14,050
    574
    Yeah you could be right, it could be read one of two ways! I'll sit back until it's confirmed :drag:
  8. A4 nut
    A4 nut Member
    351
    I would not mod to more downward facing pipes would be looking for some nice chrome tips think that james steps in here
  9. quattrojames
    14,050
    574
    Powerflow tips FTW! You can probably keep your existing valance then ??
  10. ianh
    ianh Member
    62
    rather the soot went straight down rather than annoy people behind me :)
  11. quattrojames
    14,050
    574
    Does yours throw out smoke then? I've got a remapped 2.5 (180) and it doesn't throw out any soot......
  12. ianh
    ianh Member
    62
    under heavy acceleration it throws a bit out yes but most of the time i nurse it so when on the occasions i do boot it obviously it shows its a diesel.
  13. A4 nut
    A4 nut Member
    351
    No problems then! new tips should be the cheapest and best looking way to go.:)
  14. ianh
    ianh Member
    62
    guess i will look out on ebay for a apron then,are the b6 and b7 the same or do i have to stick to the b6?
  15. Turkster
    Turkster Bro.Paul 2.5TDI Quattro Sport
    2,797
    47
    cant you just chop off the down pipes and weld on new chrome tips? change the apron?
  16. ianh
    ianh Member
    62
    need to change the apron as mine doesnt have cutouts for the exhausts,dont want to attack it with a saw and make do,would rather buy the correct item.
  17. Woorlord
    Woorlord shifting to Hyperspace... . VCDS Map User
    951
    15
    Get yourself a new cut-out valance and then visit a Powerflow delaer - old ends cut off and new ones welded on - quality job over some cheaper DIY bolt-on ones from the high street or retail park!
    They have a choice of sizes - I went for the 100mm to fill the valance hole - be careful with small children - they can fall in if not properly supervised!!
    Other Saloon pictures.....<<Linked Here>>
  18. ianh
    ianh Member
    62
    that looks a lot better than this and is the kind of look i am after................
  19. ianh
    ianh Member
    62
    dont suppose anyone knows what the part number is for the valance with cutouts for the cab is?even better is if someone has got one knocking about that they want shut of.
