3" Downpipe & Sports Cat & Relentless Manifold turned up wooop
s3gazz Sep 13, 2012
  1. s3gazz
    s3gazz Well-Known Member
    1,383
    105
    Well here they are i cannot believe how helpful relentless was when i emailed them about there v3 mani, downpipe and sports cat god carnt everyone be like that thank u so much relentless i ordered these last friday and came within 4 days spot on.
    if anyone is looking for these email sam or relentless on ebay.
    the quality is great compared to my v1 one i had and cannot wait to get these fitted come on rods hurry up. They also came with two copper plates and two gaskets and some extra pipe on the sports cat so u can cut it where ever u like, well packed.
    here are the pics.
    enjoy and come on guys u all need these in ya life well done relentless.
    [h=3][/h]
  2. James TQ
    James TQ Member
    561
    Where. An I buy the Mani for the a3 tqs? Had a look online but couldn't find it. But yours looks lush!!
  3. s3gazz
    1,383
    105
    thanks pal ill send u a pm ye of someone to contact
  4. badger5
    9,638
    2,073
    whats with the copper looking gaskets (spacers)
    dont use their other gaskets... they will dissolve
  5. s3gazz
    1,383
    105
    Cheers bill but iv already bought oem gaskets anyway so they'll be used.
    Copper Spacers I think not shore pal to be honest ill ask Sam
  6. jezzy
    jezzy Member
    768
    one piece of advise only.
    TAKE THE HEAD OFF
  7. s3gazz
    1,383
    105
    Don't worry pal my engine is it bits ha
  8. Prawn
    11,719
    3,764
    Hmmmmmmmmmmmmmmmmm. Are these the copper spacers I've heard about to aid clearance issues with certain parts? I'd bolt it all up on the bench very carefully gaz and see what does and does not clear
  9. Reesy
    Reesy Well-Known Member VCDS Map User
    3,640
    148
    You can't get one of these for the k03s, the stock one flows pretty well anyway.
    The downpipe is epic though, and I know someone *cough cough* who is selling one.
    :sign_plug:
  10. s3gazz
    1,383
    105
    Hi prawn yes mate this is what there for pal to get to tho tricky nuts and stuff and I'll be doing that tomoz pal
  11. <tuffty/>
    21,968
    4,246
    As mentioned before gazz... I wouldn't be using the copper things for anything...
  12. James TQ
    James TQ Member
    561
    im pre facelift so its ko3 :)
  13. s3gazz
    1,383
    105
    Why tuffty won't they last
  14. <tuffty/>
    21,968
    4,246
    They are a **** solution to a problem that shouldn't exist... as mentioned by Bill... dry build off the car first... see what clearences are and where adjustments need to be made... if nothing fits properly then sling it back...
    the manifold should fit to the head using a std OEM gasket and clear everything like the charge pipe fittings etc and you should be able to bolt on the turbo with a std OEM gasket and be able to fit the DP on again with an std OEM gasket..
    Do not use the copper ones or the silvery ones that were supplied as you will end up not having a good day...
  15. s3gazz
    1,383
    105
    Thanks tuffty I'd use oem anyway for that kind of stuff but I'll be dry building this up tomoz or Saturday with turbo se how things go carnt wait just need bottom end building up then
  16. sambryant
    sambryant stage 2+ mk2 seat leon cupra
    167
    12
    Relentless have informed me they have up rated the gaskets, s3gazz can you check these are not gaskets instead of spacers???
  17. s3gazz
    1,383
    105
    there copper spacers mate got the other gaskets too when are u bringing the mani to turbo bolt and nut conversion out pal
  18. s3gazz
    1,383
    105
    built the head mani turbo and downpipe up today looks great and only one problem that is u have to grind few mil off the mani plate at the top as it catches on the help other than that great dont need spacers or owt.
  19. s3gazz
    1,383
    105
    pics wont upload for some reason ill try latter
  20. firestorm
    firestorm Member
    371
    How's it going ? I've just received the DP and cat, don't fancy my chances at removing the head to put the manifold on.
  21. jezzy
    jezzy Member
    768
    i just fitted the v2.
    if i did it again i would take the head of.
    Tools for the job (cutting down spanners and so forth) was my main problem
  22. s3gazz
    1,383
    105
    Ye it's a head off job in my eyes as its a pig to get to nut 2 and 7
  23. possyoo
    possyoo Member
    who u contact about the down pipe and cat
  24. Gops
    3,198
    666
    I'm getting the DP and cat after my insurance.. Does bill fit these? I have no space to do anything in my garden ATM! :mad:
  25. <tuffty/>
    21,968
    4,246
    Of course he does :)
  26. Gops
    3,198
    666
    You guys boil the kettle, ill bring the samosa's! Getting these (and possibly a miltek) after my insurance! :)
