3 dooor front seats
steve184 Aug 22, 2007
  1. steve184
    steve184 Active Member
    1,138
    Does anyone else find that when driving on your own that the passenger seat wobbles about a lot and makes a lot of minor noises? mines leather and i find that noises are more apparent on leather interiors as leather reflects sound instead of absorbing it like cloth does.
    Also does the slide mechanism on the seats (for slding forward and back) only lock on the outer slide rail? My passengr seat seems to as when its locked you can still see a small amont of movement on the inside slider even when its locked but the outer rail is locked solid.
  2. JamS3
    JamS3 Active Member
    2,258
    20
    Not noticed this on mine mate, may be worth while getting it checked out.
  3. Boydie
    Boydie Guest
    I notice it moves but it makes no noise - but my seats in the clio moved also so I guess its common
  4. emzino
    emzino Active Member
    1,231
    I got the leathers but don't get any moving around or minor noises =/
  5. cathaloneill
    cathaloneill New Member
    21
    mine does the exact same, same noise on the passanger side seat and the seat does not lock in place fully after you adjust it on some occasions. scared the sh1t out of me once when the seat started to slide forward under heavy breaking, it slid a bit before the locking mechanism clicked in.
  6. emzino
    1,231
    Same thing along those lines happened to me too cathaloneill, i moved it back abit, started driving then out of nowhere, it goes back and locks into position, very scary because it's quite sudden!
  7. h5djr
    9,376
    1,725
    This was the only thing that annoyed me about my previous A3. We used to change the drivers seat position depending if I or my wife was driving and after some time it would slide back a notch or two even though I had tried to make sure it was locked by rocking backwards and forwards.
    I solved the problem with my current A3 Sportback by specifying electric control on the driver's seat. Not only does this stop it happening but also gives a greater range of adjustments. The front and back of the seat can be raised and lowered independently of each other.
