3 days till REVO!!!
A3ster Dec 16, 2009
  1. A3ster
    A3ster Member
    87
    Hi All,
    I spotted a deal on AGU revo maps from a company in Kimbolton so thought I would give them a ring and have a chat.
    Well, I rung the guy up and got no answer, so tried the mobile number. Turns out he is at the track with a customer performing testing (also turns out they do far more than just remaps on road cars) Anyway I ask if he can fit me in this saturday and he says it will be tight but will ring me back :(
    At this point im not holding much hope, and I said to myself if I cant get this saturday I will spend the money on a new guitar instead.
    Anyway rings back and can fit me but with one hitch, a new rolling road is being put in that day!!! The original offer included before and after readouts, so im thinking OK this is sounding like its not meant to be untill he gives me an offer I couldn't refuse
    £200 plus VAT!!!!!!!!!! :rock:
    So im in there like swim wear and will write a small review when I get back etc. Sounds like a great deal, obviously would have been better with the rolling road but I cant see any problems occuring from this unless anyone can think of anything? And I assume if you are a REVO distributer then it doesnt matter one you go to they will all be the same"ish"?
  2. voorhees
    voorhees Moderator Staff Member Moderator Team V8 Audi S5 s tronic
    16,246
    2,069
    Yes all Revo Dealers supply the same software,good call on the price.
    RR isn't no big deal you'll feel the increase right away,ask about uprgrading the DV to a Forge 007p and also ask advice on coilpacks.
    Revo all the way baby :)
  3. A3ster
    A3ster Member
    87
    Thanks for the reply voorhees,
    In the respect of the DV mine is only 3 months old(replaced by myself and OEM) will it "break" sooner than later or can It wait till January till I get a 007P?
    On the coil packs, from searching the forum I am aware that the remap may show up any weak points that are already there so have put money aside for 4 new coil packs if needed :scared2:
    My only other issue is can you explain to me or point me in the direction of a good 1.8T diagram with all the hoses etc. I fell if I increase the power over standard I should know whats going on in there.
  4. S3KO4
    S3KO4 Member
    850
    I would replace the induction hose, from the air box to the turbo, I know with peak boost under load it will collapse especially in the higher gears.
  5. Pat
    Pat Member
    515
    Mines going in tomoz be have revo stage 3 put on.. quite interested to see what the outcome will be..
  6. A3ster
    A3ster Member
    87
    Is that the TIP, do you have a product number for that?
  7. A3ster
    A3ster Member
    87
    Pat,
    where are you going to?
  8. Pat
    Pat Member
    515
  9. voorhees
    16,246
    2,069
    Ask the tuners they will put you right about the DV.
  10. A3ster
    A3ster Member
    87
    Thanks voorhees,
    Is there a key to the numbers on the diagram :)
  11. voorhees
    16,246
    2,069
    1 - Fuel Tank Breather
    2 - Charcoal Filter
    3 - One Way Valve
    4 - Turbo.... Duh!!
    5 - Wastgate Actuator
    6 - Diverter Valve
    7 - Brake Servo
    8 - One Way Valve
    9 - N75 Valve
    10 - MAF
    11 - Air Box
    12 - pressure regulating valve
    13 - N249 vacuum reservoir
    14 - SMIC
    15 - Fuel Pressure Regulator
    16 - Throttle Body
    17 - Inlet Manifold
    18 - Crankcase Breather Valve
    19 - One Way Valve
    20 - N249 Valve
    21 - One Way Valve
    22 - SMIC
  12. A3ster
    A3ster Member
    87
    Quick update,
    After digging my car out of a blizzard at 6:30am and making a slow and quite frankly un-nerving drive to get the A3 remaped it turns out that my port doesnt work :rolleyes:
    It will read but not write. So a little tip for people, check you have coms on an channels before you travel 100 miles in a blizzard to get your car remaped.
    He said he will order a harness and bench flash it so I still get the remap and will have a look at the port at the same time to see if we can get it working for the future. All credit to the dealer he tried his best and coffee and chocolate was flowing, explained a few things along the way such as how dry sumps work etc. They also had a rather tasty clio touring car there and a race spec Elise!
  13. Prawn
    11,639
    3,633
    sadly mate, the tunner should have warned you this was possible before you went!
    AGU's seem to be very hit and miss with regards to OBD mapping. some can be flashed via the obd port, and some need to be bench flashed. Really early ones need opening up and a new chip soldering in
  14. ex_scoobydoo
    ex_scoobydoo Member
    179
    i have decided to leave mine std without re maps, they are quick enough, and from most posts i see once re mapped people have problems with clutches fault codes etc etc etc i could do without the hastle, im happy as it is :)
  15. Westy
    Westy Well-Known Member
    17,443
    1,105
    If you've come from a scooby I'll give you a maximum of 6 months before you consider mapping your S3 :)
  16. ianysm
    ianysm Active Member
    1,002
    If you've come from a scooby, i'm quite suprised you think its fast enough in standard form. I mapped mine two weeks after buying it, now its much more like it! I'd still like it faster but at least i can now say 'its fast enough as it is'!
  17. Westy
    17,443
    1,105
    Exactly. I came out of a 1.4 corsa (but did come from faster cars previously) and got the S3 remapped after 2 months and its still slow.
  18. ianysm
    1,002
    Its not as fast as my M3 but faster than all the other mapped turbo's i've owned...Perhaps his Subaru was standard which wouldn't be far off a standard S3?
  19. ex_scoobydoo
    ex_scoobydoo Member
    179
    i know what you mean guys, but im happy as it is, my days of throwing cash into cars os over, the s3 is nippy enough i had my fun with the scooby and it bankrupt me at the same time lol, 14000 it owed me on a p reg sti sold for pennies, so im just happy now with some comfort and a little bit of speed when needed, some decent shocks and springs, set of tt wheels and thats enough for me.
    sti was around 300bhp just lightend flywheel polished headers that was it for mods. 2 re builds etc etc blah blah blah lol
