3, 5, 8mm silicone tubing......
Dani_B19 Feb 12, 2011
  1. Dani_B19
    9,258
    379
    Evening gents.
    I need to know if 3, 5 and 8mm silicone are the correct sizes for replacing all the rubber hoses in the engine for the expansion tank, charcoal canister, boost lines etc?
    I know the boost lines, like dv are 3mm but what about the rest.
    Dan :).
  2. coyle
    coyle From Show... to GO
    435
    I got 3,5 and 8mm and replaced it all,so yep!
    Ohh, and some 25mm from charge pipe to DV if you wanted to do that too :)
  3. Dani_B19
    9,258
    379
    Thought so mate.
    Yeah im good for the DV, running a coldside relocation kit :).
    Where did you get your silicone from?
  4. talentwalsh
    talentwalsh Member
    139
    8 mm will do a lot of it. I bit the bullet and got the forge replacements and got the silicone lenghts at the same time. Just to note I ordered a length of 13mm hose to replace the pipe under the DV but it arrived as a 13mm outer dia not inner, so be carefull if your ordering any other bits.
  5. coyle
    435
  6. metricspaces
    metricspaces Member
    661
    I've had all the hoses available for Forge replaced on my S3.
    How much of 3, 5, 8mm should I get to do the rest?
    Is it just straight hoses I need, or any elbows?
    Roughly how many jubilee clips? What sizes?
    So, the shopping list would look something like:
    * 3mm Vac Hose (1 metre) 3mm Silicone Vac Hose Boost Dump Valve BLACK 1M on eBay (end time 20-Feb-11 12:02:31 GMT)
    * 5mm Vac Hose (1 metre) 5mm Silicone Vacuum Hose Pipe Silicon BLACK 1 Metre on eBay (end time 20-Feb-11 12:22:54 GMT)
    * 8mm Vac Hose (1 metre) 8mm ID VACUUM TUBING SILICONE HOSE SILICON RED 1 METRE on eBay (end time 27-Feb-11 11:09:11 GMT)
    * 8mm Straight Silicone (1 metre) (5/16") 8mm ID BLUE STRAIGHT SILICONE HOSE 1 METRE on eBay (end time 17-Feb-11 17:23:21 GMT)
    * Two lines to fuel rails (8mm fuel resistant) 8mm 5/16" Silicone Fuel & Oil Hose Flouro 1 Metre Blue on eBay (end time 25-Feb-11 16:17:56 GMT)
    * Pipe under the DV (1m of 13mm straight silicone) 13mm 1/2" Silicone 1 Metre Straight Hose Silicon Black on eBay (end time 04-Mar-11 10:33:47 GMT)
  7. Y83OLK
    Y83OLK Hulk Smash!
    841
    wonder if that 13mm stuff would do the hockey puck valve to tip too.
  8. Dani_B19
    9,258
    379
    Nar, that 19mm if i remember correctly, tbh though, normal silicones fine for that, it's not like its got constant oil running through it.
  9. coyle
    435
    I got 2metres of 3mm
    3metres of 5mm
    2metres of 8mm
    1metre of 8mm fuel silicone
    A 90degree angle of 25mm for charge pipe to DV
  10. metricspaces
    metricspaces Member
    661
    Cheers! Was your 3mm,5mm, and 8mm all Vac Hose? Or was the 8mm the straight silicone stuff?
  11. Dani_B19
    9,258
    379
    Anyone know what the charcoal and expansion tank tubing is?
  12. s3dave
    s3dave TFSI Hybrid Supporter
    10,110
    736
    Charcoal is around 5mm i squeezed some 3mm on but its to tight really....
  13. metricspaces
    metricspaces Member
    661
    What's the charcoal?
  14. s3dave
    10,110
    736
    charcoal canister/evap thing that lives by the coolant expansion tank
  15. Dani_B19
    9,258
    379
    Cheers dave, you know what the expansion tank is?
  16. talentwalsh
    talentwalsh Member
    139
    Its the coolant bottle by the charcoal canister
    By the way I made a mistake, it WAS the pipe between the hockey puck and TIP that was the 13mm I/D pipe not the DV..my bad
  17. Dani_B19
    9,258
    379
    Yeah mate it is.
  18. talentwalsh
    talentwalsh Member
    139
    :laugh: im very sorry!!!
  19. Crazypete00
    Crazypete00 Active Member Audi S3 Audi A4
    495
    61
    anyone got any pictures?
  20. coyle
    435
    8mm hose from the expansion
